Asus ROG GL502VS bios needed
  • xrs
    • May 2019
    • 3
    Hello everyone!
    Does any of you have a BIOS dump for the Asus GL502VS?
    I found some similar posts (e.g. for the GL502VM or the GL502VSK), but I need the image for the Skylake version (with Nvidia GTX 1070).
    I also tried the official support page from Asus, but apparently the BIOS given there is only compatible with the WinFlash utility (maybe this is obvious to you, but I'm a beginner, so please bear with me here).
    My laptop is completely bricked, so WinFlash is not an option. I try to use flashrom from another Linux computer, accessing the Bios via a CH341A dongle, with a clip. I was able to read the existing (corrupted) image (which is attached to this post, in case it helps).
    The old dump has a size of 8388608 bytes, but for example the latest Bios from Asus is only 6162432 bytes.
    So...does anyone have a BIOS dump for this laptop, which would be compatible with flashrom?
    Thank you very much for your time!
    • 22424
    Re: Asus ROG GL502VS bios needed
    Try this bios .
    D 29000
    • xrs
      • May 2019
      • 3
      That worked! Thank you so much, SMDFlea...you made my day!
      • alshalami1970
        • May 2017
        • 5
        • jordan
        Please great my old bios to clear_me
        • alshalami1970
          • May 2017
          • 5
          • jordan
          MY LAPTOP IS THE SAME GL502VS-FY304T
          AND VERY THANKS MR SMDFlea
          • ellman605
            • Jul 2019
            • 3
            Bought a bricked GL502VS yesterday. Hoping this bios dump works for me.
            Is there a sticky anywhere that gives a rough rundown on flashing? I've got a few ideas/links but wanted to know if theres a good one here.
            • ellman605
              • Jul 2019
              • 3
              Well, I tried the above dump and had no luck. Screen remained black but the fans turned on at full blast. I've attached my bad bios dump. Any help?
                • 22424
                You have the VSK 7th Gen. Try this bios .
                • ellman605
                  • Jul 2019
                  • 3
                  What a stupid bunch of stickers on this laptop. Doesn't show VSK ANYWHERE. This worked sir. Thank you very much!!! Installing windows again as we speak.
                    • 22424
                    You`re welcome.
                    • down1nit
                      • Oct 2016
                      • 29
                      You`re welcome.
                      This helped me too SMDFlea! I've been getting a lot of Asus with overwritten BIOS because of a mess up during a windows update.
                      What is windows doing, updating people's firmware without a HUGE WARNING
                      • kappa11
                        • Aug 2019
                        • 4
                        • italy
                        hi, my gl502vsk has black screen, power and Caps key led on. can you help me?
                        • TheGiolly
                          • Aug 2014
                          • 8
                          • Italy
                          I have the same problem.
                          Can somebody help, please?
                          • tochix
                            • Feb 2020
                            • 4
                            • nigeria
                            How do i flash this dump back to a dead bios
                            • wonder888
                              • Sep 2023
                              • 1
                              • Philippines
                              how did you solve your problem? have the same issue
                              • asn_86
                                • Sep 2022
                                • 2
                                Hi everyone.
                                Can anyone please help me.
                                So i have a bricked GL502VS-GZ287 with 7.Gen and GTX 1070. I am trying to flash GL502VSK 7th Gen ME_CLEAN.zip, which i think is the right one in my case. The BIOS chip is W25Q80EWNIG, according to the research i made it has 8MB capacity with 1.8V. EZP2023+ is unable to detect the chip (i am using the 1.8V adapter, i have desoldered the chip and drivers are correct), so i am selecting it manually which i think should be W25Q80EW(1.8V) which has a size of only 1MB. It reads the chip, erases and writes normal, but the bios size is larger then 1MB. So i made multiple tests to be able to write up to 8MB. First i changed the selected 1MB to 8MB which doesn't do anything, second i changed the settings of W25Q80EW(1.8V) to 8MB - it reads, erases up to 8MB but when i write it completes every time but does not verify it and when i press to read to compare myself it has most of zeros written. Can anyone help me with the situation?
                                Thanks!
                                • Vesko356
                                  VIP Moderator
                                  • Aug 2018
                                  • 4386
                                  • Bulgaria 🇧🇬
                                  Originally posted by asn_86
                                  The BIOS chip is W25Q80EWNIG, according to the research i made it has 8MB capacity...
                                  No it's not 8MB, and no it's not the bios chip.
                                  https://www.badcaps.net/forum/troubl...09#post1662909
                                  Also read the rules before posting
                                  You MUST:
                                  Become a Badcaps supporter
                                  Thanks to all supporters.
                                  • asn_86
                                    • Sep 2022
                                    • 2
                                    You MUST:
                                    Thank you so much for the fast reply. You are right, the Bios chip was 25Q64FVS10. I did a backup of the original bios and flashed GL502VSK 7th Gen ME_CLEAN, and nothing changed. Actually the Laptop was freezing at boot Logo and sometimes at BIOS and i couldn't do anything, i tought that it was a corrupted BIOS but it seems to be not the case. If someone can still help or have any ideas about it, i would be thankful.
                                    Full specs are:
                                    Asus GLV502VS-GZ287 - GLV502VSK- on the RAM SLOT
                                    CPU:I7-7700HQ
                                    RAM:8GB DDR4
                                    GPU:GTX 1070
                                    S/N: H2N0CV19C660092
                                    VBIOS Version
                                    309
                                    86.04.54.00.0C.
                                    N098GL502VSKO.001
                                    - From the Bios itself wich is freezing after couple of seconds.
                                    • volinakis
                                      volinakis commented
                                      Editing a comment
                                      read again Vesko356's reply and provide serial number, also upload bios dump, the dump of 25q64
                                  • waakye
                                    • Dec 2018
                                    • 340
                                    • Electronada
                                    Hi Guys,
                                    could someone please clean this bios for me?
                                    Asus GL502
                                    GCN0CV07L21550E
                                    G502VS-GZ142T
                                    Thanks, in advance
                                    • qayyum786
                                      • Aug 2018
                                      • 1959
                                      • INDIA
                                      Originally posted by waakye
                                      Hi Guys,
                                      Asus GL502
                                      GCN0CV07L21550E
                                      G502VS-GZ142T
                                      Thanks, in advance
                                      ❤️YOU MUST:
                                      ❤️Provide the full machine model number, serial number (or Service tag, SNID)❤️
                                      ❤️Post what the problem is, be specific - black screen, no boot, running slow, password. Do NOT post "clean me", "clear bios", "clean bios", "fix bios", "bios need" or other such terms❤️
                                      • pirati
                                        by pirati
                                        10-27-2025, 04:20 PM
                                      • grimacelord
                                        ASUS TUF GAMING Z790-PLUS WIFI - BIOS Help
                                        by grimacelord
                                        I have spent the last hour on this and I guess this is just over my head, so here I am.
                                        I have an ASUS TUF GAMING Z790-PLUS WIFI motherboard here that needs to have the BIOS updated in order to accept the latest CPUs.
                                        The BIOS chips seem to come as a set of two: GD25B64ESIG and GD25B128ESIG. My guess is one of them is a fail-safe for the main BIOS? I really don't know. Or one of them is ME and other is BIOS? I don't know.
                                        Anyway, I took dumps of both chips and then downloaded the latest update for this motherboard from ASUS's website...
                                        07-10-2025, 02:52 PM
                                      • jbonavita
                                        by jbonavita
                                        Some issues
                                        Things I tried
                                        04-29-2025, 09:38 PM
                                      • throwaway327
                                        Asus ROG Ally X -RC72LA - changed hidden bios settings with 'Smokeless-UMAF', won't get past boot logo
                                        by throwaway327
                                        ASUS ROG Ally X - (Handheld Gaming PC)
                                        Model No: RC72LA
                                        Serial No: SBNVKD001014459
                                        Hi all, I've spent the past week digging through the forums and guides to try correct my foolish mistake of changing hidden settings while tinkering around, and to be honest my heads overloaded so I'm hoping you'll be able to help.
                                        I used a tool called 'Smokeless-UMAF' to access usually hidden settings in the bios. I tweaked one or two 'safe' things but made the mistake of tweaking a lot of settings under 'USB/Thunderbolt Configurations' when I didn't know what they did. For...
                                        06-18-2025, 05:52 PM
                                      • ArkzG
                                        [REQUEST] ASUS TUF A15 FA506NF (2021) - Clean BIOS dump needed (UEFI Password locked)
                                        by ArkzG
                                        Hey guys, I have an "ASUS TUF Gaming A15 FA506NF (2021)" that's locked with a UEFI password, I need to reprogram the BIOS chip but can't find a clean ".bin" file for this specific model, I've tried the official BIOS updates from ASUS support page, but they're 32MB updaters that don't extract to a usable 2MB .bin file for direct chip programming.
                                        What I currently have available:
                                        - Model: FA506NF (2021)
                                        - BIOS chip: GD25LQ16 (16Mbit/2MB)
                                        - Tools: CH341A programmer ready to use
                                        Does anyone have either a clean 2MB .bin dump of this model,...
                                        09-26-2025, 09:34 PM
