bios password removal guide
  • ziggster
    • Feb 2019
    • 72
    • israel
    is there any guide on how to edit\remove password from bios dumps ?
    thanks
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: bios password removal guide
    google it, you will get a lot of tutorials. However, the easiest option is to replace the bios region with webupdate using uefi tool.
    • kodinabeel
      • Sep 2014
      • 66
      • saudi arabia
      please explain in detail
      • ziggster
        • Feb 2019
        • 72
        • israel
        can u link a good guide?
        i didnt really find how to edit the dump it self and remove the password.
        only loads of shitty guides on master passwords that never work lol and other specific exploits that may work on certain machines
        • mcplslg123
          • Jun 2015
          • 7262
          • india
          Here is how to do it
          01. open pass locked bios in uefi tool.
          02.Expand the file and right click on bios region.
          03.You will get 2 options, select "extract as is" and it will ask you to save it.
          04.Save this file as bios region pass.bin
          05.Now download the update file from vendor website and extract it.
          06.Check the file size of downloaded file and bios region pass.bin.
          07.it has to be exactly same in size(if size, differs then you need to edit the downloaded file in hxd and make it same size by cutting unnecessary data)
          08. If file size is same then open uefi tool again and open the bios dump with password.
          09.Again go to bios region, right click on it and select "replace as is" option.
          10.It will ask for path, browse it to the file downloaded file from web.
          11. Select "save file" and you will get a new rom file and its password cleared.
          PS: You will loose dmi data in the process which you may need to re-enter. There are several methods to clear password like editing $VSS entries only but this is the easiest option though i myself dont prefer this option.
          Hopefully, it will help someone who wants to try it.
          • ziggster
            • Feb 2019
            • 72
            • israel
            thanks u very much!
            but can u also explain about the dmi ?
            what software to use and how do i know what to re-enter ?
            thanks again !
              • 22276
              Originally posted by ziggster
              thanks u very much!
              thanks again !
              For HP use nbdmifit/wndmifit https://www.badcaps.net/forum/showthread.php?t=69204
              Search youtube videos lots of info about it, and just google for others .
              • Bark
                • Feb 2023
                • 1
                How do I download the BIOS as a file to open it in uefi tool? I have a BIOS-locked surface pro 4
                • wolf3d.exe
                  • Jan 2023
                  • 33
                  Thank you for this! Very valuable information here
                  • zenius
                    by zenius
                    12-08-2024, 06:13 AM
                  • traxformania
                    TONGFANG "GM7TG7P" Bios Password Problem?
                    by traxformania
                    I'm using TONGFANG "GM7TG7P" model laptop for over 3 years and i'm entering the same bios administrator password everyday. My laptop has Aptio BIOS (American Megatrends, AMI).
                    But today it's not accepting my password. I'm %100 sure i'm entering the correct password.
                    I'm trying to reset my bios without success.
                    I tried :
                    -I removed the BIOS battery and main battery. Waited for a long time but it didn't work. They already stated in the user manual that the password will not be reset even if the batteries...
                    11-15-2023, 07:32 AM
                  • touftaf7301
                    ASUS TUF A17 – BIOS password removal request
                    by touftaf7301
                    I have an ASUS TUF A17 (model TUF707NV-HX088W, motherboard NJS / DA0NJSMBAF0 Rev F) that is locked by an UEFI BIOS password.
                    I have already checked the BIOS guides, methods, resources and tools section but could not find a working method for this specific model.
                    Details:
                    – Make/Model: ASUS TUF A17 TUF707NV-HX088W
                    – Motherboard: NJS / DA0NJSMBAF0 Rev F
                    – Serial number: S7NRCX05W03829E
                    – Issue: UEFI BIOS password locked (no access to BIOS setup or boot options)
                    – BIOS dump attached below (read with RT809F)...
                    11-07-2025, 02:15 PM
                  • tlindi
                    Toughbook CF-18KHH65LE (Customer Special Configuration) Supervisor Password needed remove HDD locking and BIOS Access ...
                    by tlindi
                    Sublect line continuation: ... Jaguar IDS PC aka Panasonic
                    >Read BIOS guides, methods, resources and tools
                    Ack
                    >Try the method at BIOS guides, methods, resources and tools before requesting help
                    Ack
                    >Explain you were not able to succeed with the methods at BIOS guides, methods, resources and tools
                    python ./main.py "/mnt/c/temp/205605f9e1b60403a41787efeffe9cad-flas_maybe5.BIN" --output-dir "/mnt/c/temp/205605f9e1b60403a41787efeffe9cad-flas_maybe5.txt"
                    01-30-2025, 04:26 AM
                  • lucaszmn
                    Summary of BIOS Whitelist Removal Problem Lenovo Thinkpad T560
                    by lucaszmn
                    Problem:
                    I am attempting to remove the WWAN card whitelist from my Lenovo ThinkPad T560.
                    Initial Findings:
                    • My current BIOS version is N1KET58W (1.45).
                    • I have a CH341A programmer and have successfully created two full backups of my BIOS.
                    • I have the ability to use command-line tools on a Linux machine.
                    Troubleshooting Steps & Conclusions:
                    • I attempted to use several automated and manual patching methods on my N1KET58W (1.45) BIOS, including using hex strings. These attempts all failed.
                    • I concluded that the
                    08-12-2025, 03:01 PM
