#1 |
City & State: Ayrshire
My Country: United Kingdom
Line Voltage: 240v 50/60hz United Kingdom
![]() Hi, Guys, I removed pu401 .3.3 volts power ic SY8208BQNC as it was getting hot and had no 3.3 volts on the motherboard but before i replace it on pin 5 vcc on the motherboard im getting continuity to ground is this normal i just want to double check before i put on the new power ic on .Thanks In advance
Your never to old to learn |
#2 |
City & State: paris
My Country: france
![]() pin5 SY8208BQNC not VCC it's LDO +3VLP check the cap PC412 or your output from the point is short, check pin2 also same voltage goes there
#3 |
![]() Thanks Techtiger for your help. i'm a bit confused according to the pin out on the datasheet which i have attached its says vcc on pin 5 second pin down.I will check what u have suggested and see if i can find the short. Thanks
#4 |
City & State: paris
My Country: france
![]() Yep as for the Dataset SY8208BQNC pin5 VCC or LDO
#5 |
![]() Aww i see now i was just going with what the pin said sorry. How will i find out where that pin goes as its just a wee silver dot on the other side of the motherboard to find the short . Thanks
#6 |
City & State: Valbonne, 06
My Country: France
![]() I've seen this mistake a lot recently but indeed this is very confusing.
Pin assignment of SY8208 is not the same on the A, B, C and D variants. Datasheet shows only A variant. Note that several Compal schematics have the wrong footprint for SY8208 (as it is the case here on Compal LA-B092P I think). Compal LA-9535P has the correct footprint for SY8208B and SY8208C. Also boardview for Compal LA-9535P is available if you want to make sure which pin is which on the chip.
OpenBoardView — https://github.com/OpenBoardView/OpenBoardView |
#7 | |
City & State: paris
My Country: france
![]() Quote:
#8 | |
City & State: Forbidden
My Country: Indonesia
Line Voltage: 220VAC 50Hz
![]() More info:
#9 |
![]() Thanks, guys for the information it was very helpful. piernov where can I get the board view for this motherboard I have downloaded board view software thanks for the link
#10 |
![]() Still in the process of repairing this motherboard anyone know where I can download the boardview for this model Compal LA-9535P Piernov said it is available ..Thanks
#11 |
![]() Boardview:
#12 |
![]() Just realised its the wrong schematic for my board bit it is similar tho mine is _la-b092p_r1.0_ anyway i couldn't find anything shorted so i injected 3.3 v on that line that was short to ground and it was the big chip that heated up is this my problem chip?
#13 |
City & State: paris
My Country: france
![]() Test pin 9 U11 for resistance ,Your SIO U11 getting heated up Remove it up from the Mob and test if the short is still there
#14 | |
City & State: Maputo
My Country: Moçambique
![]() Quote:
good afternoon, I really have defect what do I help me please ?? |
Thread Tools | |
Display Modes | |
