help again, I cant determine what type of this IC, MU4LA
  • kazia
    • May 2015
    • 145
    • indonesia
    any one know?
    and what substitution for this ic?
  • kotnatan
    Banned
    • Apr 2014
    • 181
    • Ukraine
    Re: help again, I cant determine what type of this IC,
    which platform (marking) motherboard?
    • kazia
      • May 2015
      • 145
      • indonesia
      it's asus x450j.
      SV41 JN MB
      13320-1
      448.01P03.11
      only that printed on the board,
      and only one ic is bad the other one is work, I have switch that two ic's.
      that ic's is look like sy8208dqnc which code MU3XX, try it and not work.
      http://www.*****************/detail/...dqnc-1132.html
      • kotnatan
        Banned
        • Apr 2014
        • 181
        • Ukraine
        Pu4801 - sy8208bqnc
        • kazia
          • May 2015
          • 145
          • indonesia
          Pu4801 - sy8208bqnc
          I'll try it and report here if it work... thank's
          • kazia
            • May 2015
            • 145
            • indonesia
            Hi... already try sy8208bqnc from here :
            http://www.*****************/detail/...bqnc-1134.html
            but still not work,
            any suggestion...
            • meritosari
              • Oct 2010
              • 774
              • Indonesia
              what exactly your problem?
              -Doesn't react to power button and doen't charge the battery + led the adapter off immediately
              -Doesn't react to power button and doesn't charge battery
              -Doesn't react power button but the battery charging is working
              -Power up but the battery charging doesn't work
              -Power up but then shutdown immediately
              -Power up but doesn't display anything on the screen
              • kazia
                • May 2015
                • 145
                • indonesia
                * Power up but doesn't display anything on the screen
                only on that output ic's volt missing, one ic work and the other not. compare that two ic identically.
                • kazia
                  • May 2015
                  • 145
                  • indonesia
                  any one can help...
                  • meritosari
                    • Oct 2010
                    • 774
                    • Indonesia
                    didn't find schematic and datasheet the IC, if I see from kotnatan's pic the IC for PWR_1D05V rail
                    Did you get voltage on pin#1 pwr_1d05v_en?
                    try register on http://**************/load/noutbuki/306 you'll find boardview for this model, you should pass the test first. then search asus x450jn
                    • meritosari
                      • Oct 2010
                      • 774
                      • Indonesia
                      This part of schematic as reference that I hope would help you, taken from compal/lenovo G505s
                      • fzabkar
                        • Mar 2009
                        • 772
                        The SY8208 part was manufactured by Silergy (it was also the subject of a patent infringement case). AFAICT it has at least three versions -- adjustable (DQNC), 3V fixed (BQNC), 5V fixed (CQNC).
                        Note that the suffix is VERY IMPORTANT.
                        Page 38 of the following schematic shows a SY8208DQNC_QFN10_3X3:
                        https://cdn.badcaps-static.com/pdfs/...64b9172990.pdf
                        The Compal circuits show a SY8208BQNC_QFN10_3X3 on page 1 (PU401), a SY8208CQNC_QFN10_3X3 on page 1 (PU403), a SY8208DQNC_QFN10_3X3 on page 2 (PU701) & 3 (PU451):
                        https://www.badcaps.net/forum/attach...4&d=1450291182
                        More schematics ...
                        https://cdn.badcaps-static.com/pdfs/...334a2c1a25.pdf
                        The SY8208DQNC incorporates an adjustable step-down switchmode converter with a feedback reference voltage of 0.6V.
                        The SY8208BQNC appears to be a fixed 3V converter, and the SY8208CQNC appears to be a fixed 5V converter.
                        • kazia
                          • May 2015
                          • 145
                          • indonesia
                          Big Thanks to every one, problem solved,
                          yes the IC is sy8208DQNC adjustable not fixed voltage.
                          unfortunately bios is curupped to, that's why this board still not work.
                          after flash that dump bios, bord working perfectly,
                          • ktmmotocross
                            Boardkiller
                            • Feb 2014
                            • 3597
                            • slovakia
                            that could be problem on VGA DDR
                              Acer TravelMate X514-51T-50DY+ USB Type-C Dock Notebook X5 Specification for Upgrade or Repair
                              This specification for the Acer TravelMate X514-51T-50DY+ USB Type-C Dock Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the X514-51T-50DY+ USB Type-C Dock boardview and X514-51T-50DY+ USB Type-C Dock schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...
                              09-06-2024, 09:10 PM
                              Acer TravelMate X514-51-59AD+USB Type-C Dock Notebook X5 Specification for Upgrade or Repair
                              This specification for the Acer TravelMate X514-51-59AD+USB Type-C Dock Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the X514-51-59AD+USB Type-C Dock boardview and X514-51-59AD+USB Type-C Dock schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                              Acer TravelMate X514-51-54PC+USB Type-C Dock Notebook X5 Specification for Upgrade or Repair
                              This specification for the Acer TravelMate X514-51-54PC+USB Type-C Dock Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the X514-51-54PC+USB Type-C Dock boardview and X514-51-54PC+USB Type-C Dock schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                            • electronx
                              Questions About USB 3.2 Gen 2x2 and USB4 Designs: Type-A vs Type-C, MUX Requirem
                              by electronx
                              I’m currently learning about the USB protocol and designing a project, but I’ve encountered a few questions that I couldn’t find clear answers to. I’d really appreciate your input!
                              1. USB 3.2 Gen 2×2 with SuperSpeed Type-A Connector
                              According to the USB 3.2 specification, it states that USB 3.2 Gen 2×2 can support a SuperSpeed Type-A connector. This raises a question:
                              If we use a SuperSpeed Type-A connector, the system would only utilize 1 lane for data transfer, leaving 1 lane from the host unused. Is this configuration valid,...
                              06-26-2025, 03:27 AM
