Help to identify IC on Linksys EA8500
  • xfox
    • Feb 2018
    • 84
    Hello folks, recently I got wireless router Linksys EA8500, half working.
    After visual board inspection I found one bad IC, cannot find anything in google,
    maybe someone can help me to identify it. Looks looks it's CPU voltage regulator.
    Marked as 208AB 627FL 2019 (UP8) - Voltage around IC - 0v
    On other side there is another one 208AB 627FM 2080 (UP12) Voltage 1.05V
    Photos in attach
    Re: Help to identify IC on Linksys EA8500
    208AB looks to be Dual-Buck switching regulator, the 209AB looks to be single Buck switching regulator.
    I have no luck finding any info on either one of them.
    • xfox
      • Feb 2018
      • 84
      I think I found similar it's SMB208ANT-2019L or SMB208A
      Now I have another problem, to find it in stock.
        • Jul 2011
        • 6070
        You might have another problem if I read this correctly it says that it digitally programmed now is that to mean that it has to be programmed before it installed
          • Jul 2011
          • 6070
          DIGITAL INTERFACE/NON-VOLATILE PROGRAMMING 2
          The built-in serial digital I C/SMBus compatible port and built-in non-volatile programming bring several benefits to power supply design with the SMB206A/7A/8A. Many external components are eliminated that would otherwise be used to set configuration and parametric values. Additionally, the digital interface allows for quick and easy development and debug without hardware changes. Finally, after the non-volatile power-up configuration, the serial port can be used to re-program the SMB206A/7A/8A by host software after the system is running. For quick programming development and debug use Summit’s prebuilt evaluation kit including a PC- based graphical user interface (GUI).
          This is what I am talking about earlier
          • xfox
            • Feb 2018
            • 84
            I think router's firmware doing that (IC programming/control), but anyway I was unable to find replacement, it's Qualcomm IC and there is no replacement, so body completely dead.
              • Jul 2011
              • 6070
              You can try this
              https://www.hkinventory.com/public/P...Code=&Qty=2562
              I have not used them before
              When I do an inquiry I ask if they take PayPal if they do not I will not use them
              That is just me
              • deep000
                Burned Voltage Regulator in Monitor – How to Identify and Repair?
                by deep000
                My computer monitor ASUS VP249H stopped working, and smoke came out of it.
                I opened it and found that a voltage regulator had burned out.
                The problem is that I can't identify its reference.
                I searched online for schematics or photos of similar boards that people are selling, but without success (no schematics, bad quality of the board or lack of the reference when it's a good quality 😅).
                How can I find its reference, and do you think it's repairable?
                Monitor: Asus VP249H
                Board reference: 0171 - 2271 - 6083
                09-08-2024, 01:13 PM
              • electroelef
                identify and buy a voltage regulator, Audj833
                by electroelef
                I am trying to identify and buy a voltage regulator.
                The casing is somewhere between SOT563 and SOT963.
                So it's 6-pin. Lenght of the capsule is about 1.2mm and the width 1mm.
                Codes on the capsules are:
                AUDJ833 or AUDM633 or AUDK897. All codes are used in the same model of device as a voltage regulator from +5v down to +3v3 so they should be interchangeable.
                pin2 is ground
                pin3 is Vin +5v
                pin6 is Vout +3v3
                pin4 is connected through an L to pin6
                I spent quite a while looking for a replacement to buy.
                Any help...
                07-20-2022, 06:47 AM
                HP ProBook 430 G7 + Linksys Velop Intelligent Mesh WiFi System Notebook 400 Specification for Upgrade or Repair
                This specification for the HP ProBook 430 G7 + Linksys Velop Intelligent Mesh WiFi System Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 430 G7 + Linksys Velop Intelligent Mesh WiFi System boardview and 430 G7 + Linksys Velop Intelligent Mesh WiFi System schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on...
                09-06-2024, 08:10 PM
                HP ProBook 450 G7 + Linksys Velop Intelligent Mesh WiFi System Notebook 400 Specification for Upgrade or Repair
                This specification for the HP ProBook 450 G7 + Linksys Velop Intelligent Mesh WiFi System Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 450 G7 + Linksys Velop Intelligent Mesh WiFi System boardview and 450 G7 + Linksys Velop Intelligent Mesh WiFi System schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on...
