Bios_corrupted while updating G7-1135sd
  • pecrie
    • Nov 2011
    • 182
    Ok , so I started this thread on the 1st of November.But today I notice that this is the section , to ask for laptop bios.
    Ok , so I now had time to take out the MB and read the BIOS chip.I hope that it all was done in a good way.
    But I also notice that there is a new section , where you can ask for laptop bios files.
    Not sure though what to do now.
    Because now I want to put here the corrupted bios file from this laptop - and maybe someone can fix it.
    First the info : DAO R22 MB 6D1 - Rev : D - R 22
    Bios chip : Winbond 25Q16BV SIG / 1120
    • 21695
    Re: Bios_corrupted while updating G7-1135sd
    There are 3 different bios for the G7-1135sd, try them in turn .
    • pecrie
      • Nov 2011
      • 182
      SMDflea ,
      Thanks.I will try them and let you know the result
      • pecrie
        • Nov 2011
        • 182
        My efforts to restore the bios firmware :
        I initially tried to read and flash the bios chip , while it was still on the MB.
        It looked as if it was working , but it was not !!!
        I use the CH341A usb programmer - and using the cable with the clip.But I didn't see the manufacturer and the chip type in the left side of the flash program.After pressing the Detect button.
        It also did not see the available bit size and the Original bit size of this chip.
        So , at last I took the chip from the MB and I put it in the chip adapter.
        You then put this adapter in the USB programmer.
        With this , now it could detect the chip and it showed the manufacturer and chip name (although it detected the chip as Winbond - W25Q16V and not the VB version)
        I did this 2x with the same result.
        Furthermore , the led which shows if the chip is connected and if it is being read or flashed , was Always red on my CH341A.
        In some Youtube videos you can see that it turns green - when reading /writing / etc
        I used the top bios 0165CF6A and I verified after it was programmed and all was good.
        So , put the chip back onto the MB , and it is working .... !!!
        Now I need to fill in the UUID , system info , etc.
        Glad to have it working again ...
          • 21695
          Glad to see its working. The CH341A has its quirks,especially trying to get a clip working. Use NBDmifit to fill your DMI info https://www.badcaps.net/forum/showthread.php?t=69204
          • pecrie
            • Nov 2011
            • 182
            Hi SMDFlea ,
            Sorry for the late reply.But I could not get on this site several times - mayb too much traffic on the internet ??
            Yes , I have noticed that the CH341A has it quircks - but in the end it did the job ...
            And that link , I already got it , from another post from you ...
            Thank you for your help ....
            Greetzzz
            • macabook
              by macabook
              🧩 Initial Issue
              07-24-2025, 02:17 PM
            • Vesko356
              by Vesko356
              08-11-2023, 03:27 AM
            • jbonavita
              by jbonavita
              Some issues
              Things I tried
              04-29-2025, 09:38 PM
            • zenius
              by zenius
              12-08-2024, 06:13 AM
            • Wahaz
              by Wahaz
              10-30-2023, 08:42 PM
