Emerson LF391EM4 No Power
  • neilc6
    • Nov 2015
    • 1550
    Lots of repair kits for this model including FET and replacement fuse on the PS board, EEPROM, chip caps for the main board and repair service where you need to send both boards in.
    On my board there is no front LED. Fuse is not blown and I get 20V on P-ON+21V line. However, AMP+13V which powers main board measures 0V and is shorted to GND on PS board.
    Service manual with schematic is available and replacement PS board around $20USD on ebay.
    Will dig a bit further since I have a schematic before giving in and buying the PS board.
    Re: Emerson LF391EM4 No Power
    "AMP+13V which powers main board measures 0V and is shorted to GND on PS board." Is that resistance test done with the cable still connected between power supply and the main board?
    Look to see if the main board has cap designator C3214 or not.
    • neilc6
      • Nov 2015
      • 1550
      I am measuring the short on the power supply board directly with no other boards attached.
        1) If that 13V line shorted, it should have cause the power supply to squeal like crazy.
        Can we see the pictures of the whole top and bottom side of the board and also show the test points you use.
        2) The P-ON 21V line will not be at 20V unless it get the PS-ON from the main board, when in standby, the +20 will be about 12V, the 13 will be about 8V, they will go up to full Voltage when PS-ON is present, so there is something not right about the measurement some where.
        • neilc6
          • Nov 2015
          • 1550
          Haven't had time to investigate too much but here are the pics requested. Also verified short across C654 which goes from AMP+13V to GND.
          • neilc6
            • Nov 2015
            • 1550
            Pulled up C654 and C655 and they tested ok. Lifted one leg of both D655 and D653 and D653 is shorted. Schottky diode SB3A0BH. 100V 3A. Digikey substitute SB3100.
              Good job locating the bad part.
              • CapLeaker
                Leaking Member
                • Dec 2014
                • 8351
                those 100V 3A Shottky diodes are very often the culprit, but usually there blows more than just a diode. I've replaced these before too, but I put something better in it than a SB3100. I can't remember what it was.
                For reference here is a schematic.
                • neilc6
                  • Nov 2015
                  • 1550
                  Part arrived today and tv is working. The troubleshooting flowchart in the service manual is correct.
                  AMP+13V is not output. No-> Check D653, D655, C654, C655, C668 and
                  their periphery circuit. Repair it if defective.
                  Most service manuals would say replace the power supply board. I replaced both D653 and D655 since it's the same part.
                  • CapLeaker
                    Leaking Member
                    • Dec 2014
                    • 8351
                    sweet!
                    • Dani_2024
                      by Dani_2024
                      10-28-2024, 05:06 PM
                    • ygorsan
                      LG 55NANO77SRA TV – Menu scrolling by itself even after removing button board (Main Board EBU66792103)
                      by ygorsan
                      Hi everyone,
                      I’m looking for help with a persistent issue on an LG TV model 55NANO77SRA, which uses the main board EBU66792103 (also used in LG UQ80 and NANO75/NANO80 series).
                      🧩 Problem Summary:
                      • The TV keeps scrolling through the menu or selecting items by itself.
                      • I removed the physical button board (the entire panel with power and volume buttons) and also disconnected the flat cable (CN202) from the main board.
                      • The remote control is not in use (batteries removed), and the TV still shows the same behavior.
                      • I
                      07-28-2025, 08:34 AM
                    • jb_Bak
                      by jb_Bak
                      CN6401
                      Pin 01 NC
                      Pin 02 NC
                      Pin 03 "BL_ON": 0V
                      Pin 04 "N/C"
                      Pin 05 "STBY 3.3V": 3.5V
                      Pin 06 "GND": N/C
                      Pin 07 "AC_OFF"...
                      09-27-2021, 04:52 PM
                    • JDC
                      (SOLVED) - ONN 100012588 No Power, Then Rebooting After Main Board Change
                      by JDC
                      ONN 100012588
                      Issue: No Power, Then Rebooting After Main Board Change
                      Short answer: replace main board and power board
                      Technical answer: replace main board and Q306 & Q307 on power board.
                      Long answer:
                      TV wouldn't turn on. Power switch was fine which means the main board isn't processing the power on signal. Replaced main board. TV turns on now but randomly reboots. Bad main board? EEPROM? Tried to pull main board and got a shock touching the corner of the board. That's weird. C334 (450V 10uf) capacitor is still holding a high charge....
                      07-15-2022, 07:39 AM
                    • m1ch43lzm
                      by m1ch43lzm
                      05-12-2025, 08:37 PM
