Lenovo G50-70 - power on problem
  • DeniS182
    • Jun 2014
    • 328
    • Slovakia
    I have problem with this notebook - is totally dead, no lights, nothing. At first I changed KBC IT8586, because was hot. I ordered programmed chip from ebay. After soldering new chip I found another issue - shorted B+ . Problem was in one shorted capacitor. Now 3.3V and 5v ALW are present. I tried flash bios also. Nothing changed. Now I found bad crystal 27Mhz - YVG1 in schematic. I can't find anything else bad. Can someone help me with this? thanks.
    Motherboard: ACLU1/ACLU2 NM-A271
    I attached schematic.
  • caspian
    • Oct 2015
    • 1589
    • Laptop
    Re: Lenovo G50-70 - power on problem
    why did you find the crystal faulty? what was wrong with it?
    • DeniS182
      • Jun 2014
      • 328
      • Slovakia
      I take photo of the crystal.
      • caspian
        • Oct 2015
        • 1589
        • Laptop
        If the crystal is faulty, replace it. Only after that, you can decide on other components.
        • DeniS182
          • Jun 2014
          • 328
          • Slovakia
          I order it from ebay. I mean there is another problem.
          • DeniS182
            • Jun 2014
            • 328
            • Slovakia
            I replaced crystal with one from another board. Nothing changed.
            • homeless_cz
              • Oct 2017
              • 18
              • Czech rep.
              Is 3V_ALW_PCH present ? If yes then you have to check what happens on IT8586.
              Does it have +3VALW and +3VS ?
              Check this in ready state and then after pressing pwr switch:
              PWR SW on pin 110
              LID SW pin 109
              AC present pin 128
              PCH_PWR_EN pin 97
              PCH_PWROK pin 99
              PBTN_OUT# pin 86
              MAINPWON pin 79
              EC_LID_OUT# pin 2
              EC_RSMRST# pin 93
              • DeniS182
                • Jun 2014
                • 328
                • Slovakia
                3V ALW_PCH = 3.3V
                KBC - 3VALW = 3.3V, 3VS = 0.4V
                ready state
                PWR SW on pin 110 = 3.3V
                LID SW pin 109 = 3.3V
                AC present pin 128 = 3.3V
                PCH_PWR_EN pin 97 = 0V
                PCH_PWROK pin 99 = 0V
                PBTN_OUT# pin 86 = 3.3V
                MAINPWON pin 79 = 0.3V
                EC_LID_OUT# pin 2 = 3V
                EC_RSMRST# pin 93 = 0V
                after pressing pwr button
                PWR SW on pin 110 = 0V
                MAINPWON pin 79 = 0.1V
                I tried jump Q24 then 3VS=3.3V but still nothing changed.
                • homeless_cz
                  • Oct 2017
                  • 18
                  • Czech rep.
                  This means ITE hasn't met his requirements to power on the system.
                  LID SW is OK -> LID OUT is OK, AC present is OK. PWR sw is OK.
                  When you press PWR button, pin 110 goes down and 86 should go down too, then 97 high, 93 high, 79 high and all other SUSP# and SLP# signals should go high too.
                  Check the same way:
                  108, 71, 14, 111, 112,
                  If you have a oscilloscope, you should check pins 101,102,103,105 if there is some communication with SPI flash rom.
                  Does the laptop at least charge the battery? Is it indicated with charge LED?
                  • DeniS182
                    • Jun 2014
                    • 328
                    • Slovakia
                    Thanks for answer.
                    ACIN 108 - 0V
                    VR_CPU_PWROK 71 - 0V
                    WRST 14 - 3.3V
                    EC_ON 111 - 3.3V
                    VSTBY0 112 - 3.3V
                    I have analog oscilloscope and there isn't any communication.
                    101 - 3V DC
                    102 - 0V
                    103 - 3V DC
                    105 - 0 V
                    And no charge light when battery + charger is connected, but I don't know if battery is good.
                    • homeless_cz
                      • Oct 2017
                      • 18
                      • Czech rep.
                      Strange.
                      101 must be 0 to chip select, 103 is data output from SPI chip, 105 is clock for SPI chip
                      Is SPI chip OK?
                      Pin 71 is ADP_I from charge controller, shoul not be 0 but analog 0,7 to 2,7V I think depending on charge current.
                      And pin 80 PROCHOT?
                      Is ITE well soldered?
                      Anyway you should check page 53 of schematic. Check all mosfets.
                      • DeniS182
                        • Jun 2014
                        • 328
                        • Slovakia
                        PIN 80 = 0V
                        SPI chip is ok, I read bin from it.
                        I tried resolder ITE chip.
                        All mosfets from site 53 are fine.
                          • 20795
                          Check ITE pin 72 ADAPTER_ID
                          • DeniS182
                            • Jun 2014
                            • 328
                            • Slovakia
                            pin 72 = 0.3V
                              • 20795
                              According to this post on elvikom the voltage should be 0.9V with a 65W or 1.4V with 90W charger .Check the middle pin on the DC-IN jack .
                              https://www.elvikom.pl/lenovo-g50-70...in-t52478.html
                              • DeniS182
                                • Jun 2014
                                • 328
                                • Slovakia
                                I have two 65W chargers and I tried both and value is 0.3V.
                                Middle pin on the DC-IN jack is fine and on it is 0.3V too.
                                • homeless_cz
                                  • Oct 2017
                                  • 18
                                  • Czech rep.
                                  Originally posted by DeniS182
                                  PIN 80 = 0V
                                  That's the problem. PROCHOT# is signal of overheated CPU, overheated voltage regulator and under voltage protection. It can't be 0 for normal work.
                                  Check everything related to PROCHOT# and find what generates 0 and blocks normal work.
                                  On page 47 is nice diagram of power-on sequence.
                                  • piernov
                                    • Jan 2016
                                    • 4435
                                    • France
                                    Missing RSMRST# is more of an issue. Which usually requires the AC adapter identification to work.
                                    EDIT: on HP at least, may be the same on those Lenovo.
                                      • 20795
                                      PROCHOT# comes from PU1208 - RT9553A Datasheet:
                                      Should EC_ADAPTER be the same voltage as ADAPTER_ID_ON# ? Check PQ204
                                      • DeniS182
                                        • Jun 2014
                                        • 328
                                        • Slovakia
                                        PQ204 And PU1208 aren’t on pcb.
                                        • s_specialist
                                          Lenovo E15 Gen 2 GE4B0 GE5B0 NM-D011 Rev 1.0 sometimes not opening problem
                                          by s_specialist
                                          Recently, I have started to encounter a problem with Lenovo E15 Gen 2 models not opening. When you try to open the device, it gives a warning sound and does not display an image, when you apply light pressure on the keyboard, the image appears and works for a while, when you turn it off and on, the same thing happens again. Bios was tried, RAM slots were cleaned and soldered to the legs, the problem still persists. There seems to be a problem with the onboard processors, but since Lenovos glue the processor firmly from the sides, the paths are very damaged when removing it. Has anyone encountered...
                                          07-07-2025, 11:47 AM
                                        • perzyk23
                                          Lenovo T580 - LCD Panel problem - error 0288
                                          by perzyk23
                                          Good morning,
                                          I have a problem with Lenovo T580, which after error code 0288 suggests a problem with the display. I checked the display and it works on another laptop. I replaced the display cable with a new one. I programmed another BIOS (downloaded from this forum) and I still have the problem of a dead display - there is an image via HDMI, and the system does not detect the built-in LCD at all. The problem appears to be hardware. What can I check to confirm or disprove this? I found many threads on the Internet related to this problem 0288, but without specific solutions. Please advise....
                                          10-25-2024, 12:42 AM
                                        • konradx
                                          Lenovo Thinkpad T15 Touchscreen problem bios
                                          by konradx
                                          i have problem witch Lenovo T15, my LCD display was demaged, i buyed New LCD, Touch screen version. Problem is LCD Working but Touchcreen not working, i wrinted to seller . He sended to me another LCD, but still not working. I have to Lenovo T480s with touchcreen LCD and that display and touch work. I think that is somethink like whitelist support LCD in BIOS. Someone have the same problem?
                                          That is my DUMP.
                                          My device:
                                          SN: PF29Y4N6
                                          1s20S7S2WF00PF29Y4N6
                                          MB: GT4A0 GT5A1 GP4A0 GP5A1 GT4A2 NM-C931 REV 1.0...
                                          09-06-2024, 01:33 AM
                                        • madrali
                                          lenovo e15 gen2 bios ? problem
                                          by madrali
                                          Model: Lenovo ThinkPad E15 Gen 2 (Intel)
                                          20TD-50S0KU00
                                          Hi, my laptop suddenly shut down while it was running. When I try to turn it back on, the screen stays black and it emits a melodic beep.
                                          I used Lenovo's SmartBeep decoder and it returned error 0284:
                                          "TCG-compliant functionality-related error (possibly BIOS code validation failure)"
                                          I then tried to enter crisis BIOS recovery mode by pressing Fn + R at boot. The melodic error code changes, but nothing else happens regardless of whether a USB is inserted. I receive another...
                                          06-16-2025, 12:06 PM
                                        • Ziome3eknh
                                          Lenovo x1 carbon problem
                                          by Ziome3eknh
                                          Hello, I have a problem with this computer.
                                          After connecting the power supply, the keyboard lights up and the touch bar works, you can click on it and it even illuminates the keyboard. When the fan is turned on, it turns on and off. the processor heats up. I have tried different bios but with no success, the same signs. It doesn't charge the battery either. when starting, it takes 20v and about 0.650a, after some time it drops to 0.350a and 5.2w. Has anyone solved the problem with this model?
                                          Will it be a RAM or CPU problem?
                                          below is the computer details
                                          Lenovo x1 carbon...
                                          01-29-2025, 02:35 AM
