LA52A650A red standby light blinking, no clicks
  • syaoran123
    • Jun 2014
    • 178
    LA52A650A (LA52A650A1F)
    Wont turn on, red standby light blinking, no clicks, quiet squealing coming from the power supply not speakers.
    After replacing with another power supply, the same thing happens.
    I have now narrowed it down to the mainboard. I am getting 4.6 ohm reading on the 13V pin to GND and other pins tested fine. Im quite confident this is where the problem is. Can anybody tell me what component may need replacement? I cannot find the service manual online. Note the LN and LA lineup use different boards.
    Re: LA52A650A red standby light blinking, no clicks
    The 13V is for the audio amplifier so there is possibility that the Class D power amp may be bad. Try disconnecting the speaker connector to see if the resistance reading on 13V pin will change.
    Also try disconnecting all other connectors to see what if the resistance reading will change or not also.
    • syaoran123
      • Jun 2014
      • 178
      Oh the testing was made while the mainboard was out of the TV. So everything was already disconnected.
        There are service manuals here, you just have to download them to find out which one has the schematic that matches your main board.
        https://elektrotanya.com/showresult?...oria=&kat2=all
        • syaoran123
          • Jun 2014
          • 178
          PROBLEM SOLVED!
          Unfortunately, the link didnt contain a matching board to the one i have.
          Fortunately, I managed to trace the shorted 13V pin down to a shorted smd capacitor on the back of the mainboard. Just a single capacitor change solved the entire problem. It was C1174 with a value of 10uF replaced with an electrolytic capacitor of 50V rating.
          Hope this helps someone else.
          • mecha1166
            QN750Q8FNBFXZA Service Error Codes Needed - Error code 1-3-1-2 ? Dead set, only blinking standby light in repeating sequence
            by mecha1166
            I am working on a QN750Q8FNBFXZA. Dead except the standby light. It blinks what appears to be 1 3 1 2. 1 long blink, pause, 3 short, pause, 1 long, pause, 2 short, pause, repeat. A service manual would be very helpful, or if anyone knows these error codes. Thanks!
            03-28-2024, 08:31 AM
          • ChristianBr01
            LED TV Samsung The Frame 55 inch QE55LS03RAU Standby Light only
            by ChristianBr01
            I got a Samsung The Frame 55 inch TV for free from uncle cause it is not turning on anymore. I am in the second year of training as an electrician so I have knowledge already but I am far away from to be a pro.
            The TV has Standby but ist not turning on. A Friend of mine owns a 50 inch Frame TV so I checked the One Connect Box and the One Connect Cable there. Both are good and working normally. I have opened the TV case and measured some voltages on the Board.
            What I already found is that the 12.8V are not an the connector to the main board connector to the power...
            04-23-2025, 01:48 AM
          • YasaCh
            Sony kdl 40p5500 red light keeps blinking 3 times
            by YasaCh
            Hello...
            my tv almost 2 years not powerd on and when i turned it on nothing happened and only 3 red light keeps blinking
            i opened the back cover no sign of damage on the powery suply or motherboard
            when i plug in the power i hear the reley sound like tik first and another tik..after that only red keep blinking..
            another thing is even after i unplugged the power, The tv keeps red blinking 3 times for 2 almost 2 munites
            07-07-2025, 11:53 AM
          • GRANDGG
            LG 42lw4500 flashing red light , wight light , 2 clicks
            by GRANDGG
            Hi i have an issue with LG 42lw4500 wich after pressing the power button flashes red then goes solid white light 2 clicks and nothing , the weird thing is SOMETIMES if i leave the tv plugged in it would come on and fuction normally (i should mention that vertical rectangle going from the bottom to the top of the screen have some red dot artafacts it only appear in somthing like the tv input menu and any input i give like vga , but not in the system menu , i thought i should mention this , i cannot confirme if the tv had this issue when it was up and running in its previous owner . ) when checking...
            05-09-2025, 12:27 PM
          • brithepi2k
            Sony KD-65XE8596 no standby light
            by brithepi2k
            I’ve got a Sony KD-65XE8596 here that has no standby light coming on. I’ve tested the power board with the test meter, the TV needs 3.4 for the standby but only getting 2.4. Anything that I can change/check on the board to get it working? Pictures of the board are included.
            cheers...
            09-06-2025, 02:22 PM
