Metco Model RP2416-B Flashing red light
  • Smokin House
    • May 2013
    • 31
    Hi all
    Ive been given a mobility scooter for the disabled lady I care for but have a problem with the charger for the battery. Ive been informed that the flashing red light I get before plugging it into the battery pack, means theres some kind of fault with the charger pack.
    Does anyone know if there is a way to fix this or is it just better to buy a new battery charger pack?
    Metco Model RP-2416-B
    Thanks for any information in advance.
    • 31262
    Re: Metco Model RP2416-B Flashing red light
    get a manual to verify what the light means - it could just mean the battery is faulty or not connected.
    also, post lots of foto's of it.
    • Smokin House
      • May 2013
      • 31
      I've found a manual for it.
      sadly it says nothing in there about a flashing red light.
      Not really sure what other photos I can post of it apart from this one.
      • R_J
        • Jun 2012
        • 9610
        Do you have a multimeter? Have you checked the voltage on the pins of the plug? looks like it should be 28.8 volts.
        If connected to the scooter what does the light do. Also what condition does DC the cord and plug look like, maybe the cord is shorted within the plug?
        • Smokin House
          • May 2013
          • 31
          I do have a multimeter. I will check the output at the three pin plug.
          It just connects to the battery and doesn't have to be plugged into the scooter when charging.
          The cord is on good condition. I can check the three pin connection as I believe its un-screwable.
          • eccerr0r
            Solder Sloth
            • Nov 2012
            • 8704
            How many flashes?
            Manual has this in it?
            Number of Flashes
            Indicated fault and Corrective Action
            1
            • Battery needs recharging or bad connection with batteries.
            Check connections, and recharge batteries.
            2
            • Bad motor connection. Request assistance from dealer
            who will check all connections between controller and motor.
            3
            • Short circuit between motor and battery connection. Contact dealer.
            4 & 5
            • Not used
            6
            • Controller inhibited from operation. Disconnect battery charger and check if
            this resolves the problem. Otherwise contact dealer.
            7
            • Throttle fault. Finger control levers must be in neutral (centred) position
            before key is turned on. Switch scooter off, centre levers, and switch back
            on. If fault persists, contact dealer.
            8
            • Controller fault. Inform dealer who will check connections & controller.
            9
            • Scooter left in freewheel or has a bad parking brake connection.
            Engage drive, and switch scooter of and on. If this fails to cure the problem, check parking brake and ensure it stops the vehicle. Inform dealer who will check brake and motor connections.
            10
            • Excessive voltage detected at controller. Check battery connections.
            • brispuss
              Ryobi 36V (aka 40V) 6Ah Faulty Battery Pack
              by brispuss
              Purchased a Ryobi 36V 6Ah battery pack maybe just over a year ago.
              Battery pack had been used on about 3 or 4 occasions for powering a cordless lawnmower. I was wanting to use this battery pack again recently, but on checking the battery charge state via the battery pack test button, there was no LED indication at all of charge state which suggested the pack was fully discharged.
              I found this to be odd as I usually fully recharge battery packs shortly after use. So either the pack developed some sort of fault which completely discharged the pack cells (after recharging),...
              12-28-2022, 02:58 AM
              Bauer tool battery pack charging with a HERCULES charger modification
              by sam_sam_sam
              The Bauer power tool battery charger just has to many issues with the charger over heating because I several HERCULES Hercules battery chargers that are 3 amp charge and because they have gone on quite a few times over the years before they came out with the fan cooling battery charger I going to modify one so I can charge Bauer battery packs faster than the crape battery charger that they have
              Here is how this modification is going to be done I taking a 1.5 amp hour battery enclosure and gutting it removing the battery cells and replacing some Ryobi 1.5 amp hour battery pack that...
              05-06-2023, 12:17 PM
            • coasterghost
              Lenovo T14 Gen 2 Type 20XK Model 20XK0069US Odd Charging Issues
              by coasterghost
              For Badcaps Readers, Please note that I am hopefully going to present this same message to Lenovo to see if they have any insight to the matter as well and figured to share the entirety here for clarification. The System is out of warranty as it is but does have the option to have it extended.
              Model Information: T14 Gen 2 (Type 20XK, 20XL) Laptop (ThinkPad) - Type 20XK - Model 20XK0069US
              Board: T14 Gen 2 (Type 20XK, 20XL) - Type 20XK.
              System Hardware:
              Processor: AMD Ryzen 7 PRO 5850U
              Memory: 1x 16GB DDR4 3200 (Soldered on Board); 1x Crucial 32GB DDR4...
              09-08-2025, 10:46 PM
            • CraigR
              Hp Spectra x360 Power light flashing, component id
              by CraigR
              Working on a hp x360 15-eb1043dx that will not turn on and the power light just flashes. It pulls 700ma when flashing. Under the thermocam I found a component I am unable to id that light up. If someone can help would be appreciated. I put the number that are on it in better test....
              05-07-2025, 11:06 AM
            • flat-earther
              ASUS X54H laptop thinks it's always charging even with charger unplugged
              by flat-earther
              The charging indicator light on my ASUS X54H laptop is always on even when the charger is disconnected.
              Windows also shows ''Plugged in'' when charger is not connected.
              This problem started year ago gradually, when unplugging the charger the charging light took several seconds to disappear, then minutes, and now almost always on even when unplugged for an entire day.
              Strangely, before sometimes immediately when plugging in the charger the charging light went away, and later came back with it connected.
              If I let battery run out and say it has 3% Windows will...
              06-24-2025, 09:32 AM
