blown VRM capacitors?
  • CCCA
    • Apr 2009
    • 7
    Recieved this dead system from someone i know. It doesn't boot, but the green LED at the bottom of the motherboard lights up when connected to power (ASUS).
    When i power it on, fans spin, and all seems fine except there is not video. Taking the CPU off, i all of the VRM capacitors had blown.
    All ten of them seems to be blown, so im guessing this is the problem. Besides, the user ran it 24/7 other than occassional restarts since 2005.
    Checking the specs of the capacitors, i found the following:
    'Elite' brand
    105C temp
    680uF
    4V
    it's also pretty stout (short enough to avoid hitting the heatsink fins)
    Unfortunately, i can't seem to find anything can is the same spec (different brands), other than DigiKey which overcharges like crazy.
    Is there any good substitute for this? Also, can i be pretty well assume the caps are to blame?
  • Toasty
    • Jul 2007
    • 4171
    Re: blown VRM capacitors?
    >>other than DigiKey which overcharges like crazy.<<
    I don't understand that statement at all. Overcharges for what or how? Please explain.
    Caps are 99.44% probably to blame.
    What SERIES are the Elite caps? Only way you can compare apples to apples. Look on side opposite values for a 2 letter code like EL, ED, EB, PS.
    What ASUS board is this?
    Check PSU also for similar problems. Its model & brand also.
    Toast
    veritas odium parit
    • CCCA
      • Apr 2009
      • 7
      Toast
      I don't mind paying for the caps, but 8 bucks for shipping is a little steep for me. Unless I am wrong that is, as I have only ordered once from a electronic component website. If 8 bucks is the standard for shipping from retailers, then I'll go for it. (Bah, why am I still complaining)
      For the type, it says something like EM(M)105C.
      It's on a ASUS P5P800, and I have tested it on different PSUs, and it all does the same.
      • Toasty
        • Jul 2007
        • 4171
        Depends on shipping method you choose. I think it defaults to UPS, and $8 is kinda standard to residential for them. By USPS Priority Mail, my last order was $5. Mouser was more, but the order was much larger.
        I was not asking if you had tested on different PSU's, I was asking you to check the PSU it WAS running on for 4 years. It may have similar issues and posting the model & brand helps. It needs to be opened and checked.
        >>For the type, it says something like EM(M)105C.<<
        series(tolerance)temperature = EM 20% 105°C
        EM Datasheet:
        They do not list a 4 volt cap in that series. Probably dropped it. Because of that, I'll need dimensions of diameter & height in mm's.
        I would likely replace all of those failed ones with solid polymer caps either 560uF or 680uF. Low ESR and superb ripple filtering. Look for 560uF or 680uF Sanyo OS-CON SEPC Polymers. Ask Topcat thru the online form here: https://www.badcaps.net/pages.php?vid=23
        Or, search eBay (careful of fakes) or Google -> Sanyo OS-CON SEPC Polymer
        What brand/series are the other caps on that board, particularly those near CPU & RAM?
        Toast
        veritas odium parit
        • CCCA
          • Apr 2009
          • 7
          I checked the PSU with a multimeter, both under load and idle, voltages are fine.
          The height of the caps are around 8-10mm, diameter is around 6mm
          The other caps surrounding the RAM and CPU are(they seem fine):
          1x OST 1500uF 6.3V RST 105C
          4x Elite 8B k(M) 105C 1000uF 16v
          Then i have 2 bulging ones around the northbridge:
          Can't really see brand (green and gold with oval logo), but it's LMB105 (M) 6.3v 820uF
          • kc8adu
            • Nov 2003
            • 8832
            • U.S.A!
            i use sanyo sepc 560@4v to replace those.all ost,elite and lelon/ltec need to go too.
            i have recapped a ton of these for customers and have yet to have one not work after recapping.cheap lytics onder the hsf being a very bad choice is an understatement!
            • shadow
              • Feb 2007
              • 732
              Yes you can say that again. One would think that under the heatsink, temperatures would be high.
              Having lytics there is bad, but cheap ones just adds salt to the wounds.
              • CCCA
                • Apr 2009
                • 7
                Can i replace 6.3V 820uF capacitors with a 6.3V 1000uF? Or is that out of tolerance level?
                • kc8adu
                  • Nov 2003
                  • 8832
                  • U.S.A!
                  yes.
                  i do this often.
                  • CCCA
                    • Apr 2009
                    • 7
                    Well, I bit the bullet, and ordered10 Sanyo SEPC caps (no spares, because I live life on the edge), and 5x 6.3v 1000uF capacitors last week. Now fast forward to this week, it arrived.
                    At first, I thought the main concern was the VRM capacitors, which i replaced promptly and tried to boot the mobo up... no POST... I was scared like s***less. Feeling hopeless, I replaced the other 2x 820uF capacitor as well(without much care), and much to my surprise, it booted up!
                    Now i have a living PC again thanks to you guys. And a lesson learned as well: the smallest details can make the largest difference.
                    • dragon3x
                      After updating motherboard capacitors, what to do next (Asrock K7VT2, SOLTEK SL-75FRN2L)
                      by dragon3x
                      Hi, I have some 32 bits computer motherboards that need repair, as they fail to
                      power on.
                      Here are some examples :
                      (N.B. "capacitors" indicated here are electrolytic capacitors located in the onboard
                      switching supply area).
                      (N.B. #2 : I could not find a 3300 microF aluminum-polymer with a higher voltage
                      than 6.3 V.)
                      1 - Motherboard #1 : this is an Asrock K7VT2 (socket A) that still works well. To put it on test
                      I replaced capacitors with aluminum-polymer.
                      3300 microF/6.3 V. x 4 replaced by 3300 microF/6.3 V. (KYOCERA...
                      03-21-2025, 02:46 PM
                    • cmlewis89
                      LG 47LB5DF blown power supply board
                      by cmlewis89
                      Hi folks,
                      I'm new to this forum. So my trusty 17-year-old LG 47" LCD recently died. As I was booting it up, I heard a hum followed by a loud bang, sounds of pieces flying around, and loss of power to the unit. Inspecting the PSU, I saw two obvious problems: a blown thermistor (bang + flung pieces) and a visibly bulging main cap. Inspecting as many components as I could with my Fluke MM, I diagnosed that the following components on the "hot side" of the board were also bad: one of the 2 main MOSFETs, main 8A fuse, small cap (25V 47uF) connected to main caps, and a blown...
                      09-03-2024, 07:50 PM
                    • slybunda
                      AA and AAA battery charger capacitors?
                      by slybunda
                      hey all, iv got my favourite battery charger here which iv had for many years probably 15 years now or maybe even more. it still works good but thought id open it up to clean the dust out of it, lots of dust inside but now its clean and noticed 4 capacitors inside it and wondered if i should replace them.
                      it has inside:
                      2 x 47uf 16v caps 105c branded as Su'scon (lol sounds sus to me)
                      2 x 470uf 16v LZ105c branded as G.Luxon
                      not heard of these brands are they any good?
                      iv attached photos of the charger and the board inside for an idea on the type of...
                      12-24-2023, 04:41 AM
                      Panasonic switching power supply daughter board has two 27uf @ 50 volt capacitors which I do not keep in stock
                      by sam_sam_sam
                      I did not have any 27uf @ 50 volt capacitors but one nice thing is that it has enough room for two capacitors in parallel a 22uf and a 4.7uf @ 50 volts 22 plus 4.7 equals 26.7uf which so very close to 27uf I will show some pictures of it sometime tomorrow
                      This is one of the shit est boards I seen in a very long time and it was the daughter board the traces just lifting off the board I had to use the capacitor leads to repair the the traces and the main board is not any better because I had to repair several traces for the daughter board to the main board
                      After all of...
                      07-13-2024, 08:14 PM
                    • Ady2017
                      Are there any datasheets available for Elna RJG capacitors?
                      by Ady2017
                      I have a 2007-era Panasonic VHS combo that is full of of Elna RJG capacitors. I am trying to test the capacitors to diagnose the machine and then select replacement capacitors but I can not find any datasheets for them. I did find a Elna catalogue from 2007-2008 but there is no mention of this capacitor series. Where these specially made for Panasonic and so not made available to the public? Any ideas what to find out what the ESR values should be without the datasheets? They are all between 10V and 50V and 47uF and 1800uF. None are leaking or bulged but I know that they need to be tested to be...
                      05-25-2025, 02:19 PM
