Hot Air Station - Air Pump Failing
  • caphair
    • Nov 2011
    • 1249
    I have a 852D+ hot air station combo with soldering iron. I believe it was around $70 at the time of purchase over 3 years ago.
    I like it for the price, however recently the air speed has declined and I've had to bump up the air. I have a feeling it'll decline until it won't blow air anymore.
    Does anyone know a replacement pump that would work or if there are any replacement parts for these?
  • Andrew F. Ali
    • Jan 2014
    • 2450
    • Trinidad & Tobago
    Re: Hot Air Station - Air Pump Failing
    It could be the Pump itself or the power supplying the pump. I would think it would be the power supply. If you could determine the supply wires to the pump you could power it externally to verify the pump is good. Keep the temp as low as possible, 100C. It is probably a 5.6-6.8Kohm 2W resistor on the Darlington power transistor speed control.
    • caphair
      • Nov 2011
      • 1249
      Would the resistor be the culprit? Would the pump have a voltage rating to try with external power?
        • 31256
        check the hoses for leaks - specially the bit where the wires enter the hose in the base.
        • caphair
          • Nov 2011
          • 1249
          No leaks that I could see
          • redwire
            • Dec 2010
            • 3912
            Two diaphragms in a pump; Replacement Diaphragm for 850A++, 852A++, 738H, 768, 908, 968, 968A+, 2702, 2702A+, 2703A+
            • caphair
              • Nov 2011
              • 1249
              Thanks for that. Would it compatible with my model though? Also are the pumps just variable voltage controlled with a potentiometer?
              • redwire
                • Dec 2010
                • 3912
                There are different spinoffs of the 852D+ but I think the pump is all the same. You'd have to take it apart and look.
                Pump is a mains AC motor with triac phase-control (light dimmer).
                Here are 852D+ schematics taken from Russian site http://aes.at.ua/publ/pajalnye_stanc...52d/37-1-0-249
                  https://www.badcaps.net/forum/showth...t=HOT+AIR+PUMP
                  • mmartell
                    • Oct 2013
                    • 3189
                    I clicked bud's link to find it was my thread on the same problem - which I never updated apparently...
                    I never found a resolution and shortly after chucked the entire unit replacing it with an 853d. This unit has a much better hot air wand (pump-in-handle) but the iron has a tendency when switched on to start heating at well over room temperature so when it reaches the preset temp it can't even melt solder. Ended up buying a ts100 which is nice but the supplied t12-i tip heats up nice everywhere but the tip.
                    Lol when will I learn...
                    • caphair
                      • Nov 2011
                      • 1249
                      Thanks for the link budm.
                      My problem is different though. The air speed seems to be slowly degrading. Have to crank it up to get same air speed as I once had on a lower setting.
                      How do you tell if it’s diaphragm related?
                      • Andrew F. Ali
                        • Jan 2014
                        • 2450
                        • Trinidad & Tobago
                        OK. I misread and was referring to the 858D Hot air Station. This unit does not carry the soldering iron station and is only hot air. I have one and my friend who has one also was giving similar problems. the 858D fan works with 24Vdc. I repaired it for him and the 5.6-6.8Kohm 2W resistor was open.
                        • caphair
                          • Nov 2011
                          • 1249
                          Was the issue decreased fan speed or no air at all?
                          • caphair
                            • Nov 2011
                            • 1249
                            If the air speed is controlled by a triac, would a bad cap on the trigger cause the speed to decrease or would it not work at all?
                            • caphair
                              • Nov 2011
                              • 1249
                              Finally had a moment to play around with it.
                              So I measured acv at the terminals leading to the pump (two black wires my finger is pointing to in pic) as I slowly increased the air speed. Seems to smoothly change voltage from 45vac (lowest air) up to 115vac highest setting.
                              I measure 118vac at the receptacle it's plugged into. So safe to say the circuitry is all good correct? More like an aging pump?
                                You need new pump then.
                                  • 31256
                                  but first, pull the output hose and see how much flow it has - and check the input isnt blocked.
                                  • caphair
                                    • Nov 2011
                                    • 1249
                                    They have it glued on with some white silicone type of glue. Input isn't blocked it had good suction when I put my finger over it
                                    • madan1
                                      • Nov 2016
                                      • 726
                                      • Bulgaria
                                      The answer is already in the thread - the diaphragms have to be changed. The pump design is so basic that almost nothing else can go wrong.
                                      The diaphragms are made of a silicone-like thingy, which after some time ( probably depends on the air qualities in your area ) degrades and stops doing what it is supposed to do - which is to keep the pump piston in the correct position and to displace air.
                                      The piston is centered between two solenoids in parallel and it will not move properly if the diaphragms are too soft and are not keeping it in place.
                                      Once you have the pump dissembled, of course do not forget to check if the valves are working fine.
                                      • caphair
                                        • Nov 2011
                                        • 1249
                                        Is replacing the diaphragms a straight forward thing? Never done one before.
                                        Anyone know if these pumps can be purchased assembled anywhere?
                                          ZD desoldering station pump rebuild
                                          by stj
                                          just did one.
                                          works great.
                                          so here's the discoveries.
                                          the pump "modules" have 4 parts, the main body, the outside bit, the inside bit - screwed to the main body, and the diaphram.
                                          the failure is the inside bit, it has a rubber coating for some reason that becomes tacky and breaks down - contaminating the diaphram.
                                          so you need to clean everything to get rid of all the tacky black stuff.
                                          then reassemble it.
                                          *BUT*
                                          you must put the 2 screws into the assembly only finger-tight.
                                          if you tighten it properly the valves dont work....
                                          08-21-2024, 05:59 PM
                                          HP Station de travail Z2 format tour G4 i7-8700 Specification for Upgrade or Repair
                                          This specification for the HP Station de travail Z2 format tour G4 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Station de travail Z2 format tour G4 boardview and Station de travail Z2 format tour G4 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...
                                          09-12-2024, 02:20 PM
                                          MSI Gaming GF66 11UG-820FR Katana Dragon Station Notebook GF Specification for Upgrade or Repair
                                          This specification for the MSI Gaming GF66 11UG-820FR Katana Dragon Station Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the GF66 11UG-820FR Katana Dragon Station boardview and GF66 11UG-820FR Katana Dragon Station schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note...
                                          09-07-2024, 05:20 AM
                                          HP EliteBook 840 G6 + UltraSlim Docking Station Notebook 800 Specification for Upgrade or Repair
                                          This specification for the HP EliteBook 840 G6 + UltraSlim Docking Station Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 840 G6 + UltraSlim Docking Station boardview and 840 G6 + UltraSlim Docking Station schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we...
                                          09-06-2024, 06:00 PM
                                          09-06-2024, 12:30 PM
