Panasonic SA-PT860 Stuck in Standby
  • Joeyrom
    • 9
    Hi, I've decided to try and take on a project. Probably not the best for a beginner but figure I might learn something.
    As in the title I have a surround sound system that was stored for some time and when it was checked to see if it worked before it was given to me it would't turn on.
    There is a red light indicating it has AC power but is completely unresponsive. I cracked it open to see if there was anything visually wrong with it, there was nothing I could see.
    However, on the SMPS P.C.B i can here a high pitched tune/whistle coming from what I suspect is the transformer (?) with the green and purple dot on it (see attached picture.) It could be a cap further down as it's hard to pinpoint. This whistle lasts for some time after unplugging too. I'm not sure if this is completely normal behavior or not.
    Just after some info so I can get a direction as to where to start problem solving.
    I only have a basic electrical tester at the moment, i'll be getting a multimeter asap. Thanks in advance.
  • R_J
    • Jun 2012
    • 9594
    Re: Panasonic SA-PT860 Stuck in Standby
    That is the standby transformer, it can make a bit of noise, thats normal. It is working because there is the red standy led. There is very little current drawn by the standby circuit so when you unplug the unit it takes a bit of time for the voltage (and the whistle noise) to drop off.
    start by measureing the standby voltage, it should be 6 volts, if it is a lot lower that could be the problem
    You can download the service manual here
    • Joeyrom
      • 9
      Thank you for your reply. I'm not 100 percent sure where I was supposed to test. I had a Google and a look through the manual. I tested at the switching regulator. It has 2 apparently. Both read at 0. As I was looking around I found what may be burnt connections and it appears the display screen may have burnt out too. I'd like to have your opinion on the former. I'll attach a photo. Thanks again.
      • Moreno83
        • Jun 2014
        • 2008
        • The Netherlands
        That is not burned , its probably flux.
        You could reflow those parts. But you need a schematic
        • R_J
          • Jun 2012
          • 9594
          on plug CN5802 Pin #2 (thats the picture in post #1) you should get 6 volts standby That is the SYS6V that supplies the micro that controls the power on PCONT line
          The display circuit requires +18 volts, that comes from the main power supply which at the moment is not turned on.
          The acin led does indicate that there is SYS6V but it might be too low for the unit to operate
          • Joeyrom
            • 9
            Thank you so much for your help so far. I tested and it has 6 volts. I assume I'd follow that line further along and see if there's a loss? I've found some other information on the Internet and will see if I find something until you get back to me with where else to look. If anything turns up that doesn't seem right I'll run it by you.
            • Joeyrom
              • 9
              Just to check I understand you correctly. The 6v line gives standby power to the main board which makes sure all conditions are met, such as no faults for instance. It then turns on the actual power at the power boards to run the rest of the hardware?
              • Joeyrom
                • 9
                Seems that the 6v is making it to the main board.
                • Joeyrom
                  • 9
                  I was wondering if there's anyway to bypass the standby? Kind of like short it somewhere so if all else is good it will start?
                  • Joeyrom
                    • 9
                    I worked out the last part. On CN5802 shorting Am_BP with Sys6v resulted in coming out of standby.
                    • Mooikuan
                      • Feb 2018
                      • 1
                      • Malaysia
                      Hi Joeyrom did you finally repair your Panasonic unit ? I have the same problem and was wondering did you find out what cause the unit stuck in the standby mode? Thanks
                      • stevebrowndog
                        • Jun 2018
                        • 2
                        I'm with you Mooikuan. I'm in the same position. Mine wont turn on. I'm keen to open it up and have a look. I see the plug, but I'm not sure what Joeyrom is saying that he shorted. How did you go?
                        • Moreno83
                          • Jun 2014
                          • 2008
                          • The Netherlands
                          On that connector there are pins and one of them is a Am_BP and the other one a Sys6v.
                          • stevebrowndog
                            • Jun 2018
                            • 2
                            Thank you, I read that, but what does it mean? How does a punter identify an Am_BP or a Sys6v??
                            • R_J
                              • Jun 2012
                              • 9594
                              Plug CN5802 on smps. Pin #2=SYS6V; Pin # 11=AM_BP pins should be labeled but if not pin 11 is closer to the edge of the pc board
                              • BobbyMJ
                                Panasonic TC-P60S30 - no standby voltage
                                by BobbyMJ
                                Hi All,
                                Wanting to learn some electronics repair skills.
                                I found a non working Panasonic TC-P60S30 and this is my first project / attempt.
                                So far I have found a blown cap on the main power supply board.
                                After replacing it there's still no standby power.
                                Poked around and found a resistor on the PSUB power supply board that measures open.
                                An online resistor calculator shows this is a 93k ohm resister.
                                My questions:
                                Is that correct, 93k ohms?
                                Is it a fusible resistor?
                                Lastly, how do I know what wattage?...
                                05-14-2025, 06:42 PM
                              • lepak06
                                TV LED 4K Selecline 65S18 ( T.MS3458.U801) stuck in Standby mode
                                by lepak06
                                Hello
                                I have an TV Led 4K Selecline 65s18 with mainboard T.MS3458.U801
                                The TV is faulty with stuck in Standby RED LED. Can't power the TV.
                                Before this problem , the TV stuck the picture with artefact , i unplug the AC cable and since the tv is stuck in standby .
                                All voltage are OK on PSU and main board for regulator. I tried flash firmware 25Q64 with many dumps
                                But the voltage on power button is 0.6V not 3.3V. When i press power button the voltage up to 0V. I tried to add 5V with Power Supply on 5V_STB and 3.3V on Power...
                                01-12-2023, 01:43 AM
                              • toty79
                                Hisense LTDN50K220WSEU stuck in standby
                                by toty79
                                Hello to all friends of the forum and well found, here I am asking for your help and sorry for my translated English.
                                As per Hisense tv title LTDN50K220WSEU stuck in standby
                                PSU rsag.820.5687 HLL 4855WF
                                Main rsag 7.820.5842
                                I enclose the psu diagram, after the first routine checks I find myself with a regular standby voltage of 3.3v blue light on steady when the power button is pressed nothing happens, psu disassembled and bench checked ... forced ignition by sending a signal 3 , 3v on the SW and PWM2 pins the psu turns on and delivers all the voltages...
                                05-01-2022, 04:39 PM
                              • lego1234567
                                LG 32LB1R - stuck in standby mode
                                by lego1234567
                                Hi. I have the following problem with my TV. After connecting to mains, the standby led (red) turns on, but TV is not responding to remote control or buttons on TV. After some measurements, I found out that +5 V standby voltage is present, but I dont have ON/OFF signal coming in to turn PSU on. It stays at zero volts. After looking at the schematic of the mainboard, I should get ON/OFF signal coming in at the R1402 resistor, but it stays around +3,5 V. So I removed it and I was able to turn on TV with buttons on TV, but not with remote control.
                                What could be the problem ? Thanks...
                                01-21-2024, 03:39 AM
                              • Stunt
                                Hp Laptop Stuck on Hp protected by hp sure start screen
                                by Stunt
                                Hi guys i've got an Hp laptop Zbook 17 g5 Stuck on Hp protected by hp sure start screen.
                                I have tried almost every bios available on various platforms about this laptop but the problem is still the same.
                                I even successfully build my own bios using the one from the Hp website but the problem the laptop still getting stuck there.
                                Even if i try to press Esc key nothing happens. I tried f10 it doesn't go to bios still stuck there i just saw entering setup menu on the bottom left corner of the
                                screen that's it and stuck there. I left it until the following day and i still...
                                09-02-2025, 01:51 PM
