help HP 4720s dsc to uma convert
  • ala_borbe
    aka Donald
    • 1625
    • Malta
    hello guys
    can you help me
    i have 2x HP4720s with H9265-4 48.4gk06.041
    one spins fan but no image, no reaction to caps lock
    other starts and respods to caps lock or restart with ctrl+alt+del but no backlight and no image on screen
    one has i5 other i3 first gen with uma vga
    i have reballing machine and i know that problem is ati chip but can you help me to convert it to uma, cos it will last longer then reball?
    i tried on page 46 signal GFX_SEL to change resistors from R498 to R497 but it all remains the same
    any help please... at least to push me in right direction
    [MOD EDIT] Link to Schematic -> https://www.badcaps.net/forum/troubl...v-sd-schematic
    Last edited by SMDFlea; 01-02-2024, 04:29 AM. Reason: Moved schematic to new thread
    Im Back... sort of...
  • caspian
    • Oct 2015
    • 1591
    • Laptop
    Re: help HP 4720s dsc to uma convert
    only the second laptop seems to have graphics problem.
    • imranromi
      • Jan 2015
      • 1290
      • Pakistan
      I try 4530s and 4540s only remove graphic supply convert uma try this laptop maybe work.
      • khaahk
        • Dec 2013
        • 806
        • Estonia
        I think you need to check every part of schematic where DIS to UMA marked bold green. Meaning removing for example RN35 and installing it to RN31, R375 to R374 position and so on. Thats a lot of work to do.
        • mcplslg123
          • Jun 2015
          • 7262
          • india
          NO . For 4520s it doesnt work by removing gfx coil. I have never found any info regarding conversion for this model-might be -not possible to remake in uma.
          • ala_borbe
            aka Donald
            • 1625
            • Malta
            i allready tried removing L44 but it did not work, after that it would turn on but no reaction to caps lock, no image
            i will take closer look to componenets marked UMA to check are thay there
            • Francisco.s
              • 686
              • Spain
              I agree, this motherboard seems not to have a pch strap to switch to uma mode, like BOARD_ID0 (R836 & R837) as in quanta R23 or other capable mobos.
              • Stantechs
                • May 2011
                • 29
                • Nigeria
                I don't agree with you, on page 46 it has its "gfx sel", switch from dis to uma
                • stefanbs
                  Stefan
                  • Jun 2018
                  • 16
                  • Bulgaria
                  I confirm the successful conversion to UMA or HP 4520s (Wistron-S 48.4GK06.041).
                  There are a bunch of components that have to be aded\moved\removed acording to the schematics. Firmware also has to be flashed with the UMA version, ATI and Intel graphics has different BIOS files on HP site. Unless the firmware is correct, there is no picture on LCD after conversion to UMA, only backlight.
                  • abdulhalim933
                    • Oct 2015
                    • 14
                    • damascus
                    great
                    can you post convert info
                    thankyou
                    • Jamescl
                      • Feb 2017
                      • 28
                      • Bangladesh
                      Thans a lot
                      • datodati962@gmail.com
                        • May 2020
                        • 48
                        • alb
                        Please can you send conversation for 4520s,need to enable Uma,if you have schematic to make conversation please forward,thakns
                        • mci
                          • Nov 2021
                          • 0
                          • Ro
                          Was anybody able to perform the conversion?
                          This is what I found so far but didn't test them.
                          • mci
                            • Nov 2021
                            • 0
                            • Ro
                            +Files
                            • mohamedbalwe
                              • Jan 2021
                              • 51
                              • aleppo
                              follower
                              • mohamedbalwe
                                • Jan 2021
                                • 51
                                • aleppo
                                +Files
                                Thanks for help
                                Did you check it out?
                                • mci
                                  • Nov 2021
                                  • 0
                                  • Ro
                                  Originally posted by mohamedbalwe
                                  Thanks for help
                                  So far no, there are a few instructions that I am unclear of
                                  - Add (what?)
                                  - Shift (where?)
                                  - Add coil (what value?)
                                  • Rainbow
                                    • Aug 2005
                                    • 1375
                                    Anyone had success with the images posted above?
                                    I've compared them to the schematic and they are missing some parts:
                                    - move RN37 to RN23
                                    - move R375 to R374
                                    - move R498 to R497
                                    The discrete board is also missing U33 (PS8101) so there will be no HDMI output unless this chip is added.
                                    However, the most important missing part is entire VCC_GFXCORE supply on page 55. How is this mod supposed to work without VCC_GFXCORE for CPU?
                                    • btomce
                                      • Nov 2020
                                      • 70
                                      • lt
                                      Connect wire cpuGFXCORE from ati core power supply.
                                      • relmas1
                                        • Aug 2018
                                        • 1
                                        • turkey
                                        please translate this video
                                        https://www.aparat.com/v/J3Yyp
