I have 2 of these, one working, the other not so much
I know the large 100uf, 400v cap is good
i did test the 47uf startup cap, it did barely pass, but maybe i forgot to read the unit on the multimeter
i assume the capacitance will degrade over time so i probably should replace it, and i assume a EEU-FR1E471Y will be fine, but it is still within spec so the issue should be else where right? I have read this cap is a common cause of failure in these
my issue is i am getting 0.7v output, before testing those 2 caps i think i was getting 0.5v
none of the caps are showing any bulging or leaking
i attached a picture of the power supply i found with a google search
what part should i check next
