Dell PowerConnect 2716 Switch PSU; low voltage
  • evilkitty
    • Nov 2017
    • 299
    I have 2 of these, one working, the other not so much
    I know the large 100uf, 400v cap is good
    i did test the 47uf startup cap, it did barely pass, but maybe i forgot to read the unit on the multimeter
    i assume the capacitance will degrade over time so i probably should replace it, and i assume a EEU-FR1E471Y will be fine, but it is still within spec so the issue should be else where right? I have read this cap is a common cause of failure in these
    my issue is i am getting 0.7v output, before testing those 2 caps i think i was getting 0.5v
    none of the caps are showing any bulging or leaking
    i attached a picture of the power supply i found with a google search
    what part should i check next
    • Jul 2011
    • 6070
    Re: Dell PowerConnect 2716 Switch PSU; low voltage
    You need to find the switching power supply IC chip on this board it is going to be any where from 4 to 8 terminal to it google the part number it could even be s surface mount IC chip ones you found that chip look for a capacitor near that chip replace it first before you do anything else
    Please post a photo of the bottom of this power supply board
    Some things to check the main board fuse also look for blown apart part or burn up parts and where they are on the board
    If fails to turn on the power supply then I change that chip
    Then if still does not want to work then we go from there
    I hope this helps
    I have had my own nightmare with an Ault 3.0 volt @ 5 amps power supply that was hit with a lighting surge
    Power supply one
    I found one open resistor that had a “0” ohm on surface mount chip also the optic sensor was blown apart and just the pin were there replace that and the power supply would power ON and OFF and just keep doing it
    On power supply two
    It had blown the main fuse on the board and did figure out why
    So I put in a box I will work on it later
    So I decided today to remove the switching IC chip from board # 2 and see what happens on board # 1 ( the optic sensor chip might be toasted on this board as well I am going to order some parts for both of these boards
    Well it did not go well it shot sparks out of the bottom of that chip but it did not blow the fuse on the power supply board that because I use a electronic fast acting fuse controller I built a long time ago it was set to .025 amps
    It has a range of .025 amp to about 6 to 7 amps and very quick to respond to over current
    I have had to repair this electronic fuse controller a few times in the past because things did not go so well on the device that I was working on
    I use it all the time on switching power supply so I know when one dose not work right
      i assume the capacitance will degrade over time so i probably should replace it,"
      So you did not test the ESR of the cap? You should replace it anyway, needed or not so you do not have to deal with it in the future.
      The primary section has been cooking for awhile as you can see the board is turning brown from the heat.
      Caps and diodes in the cold side tested fine for sure?
      • evilkitty
        • Nov 2017
        • 299
        Caps and diodes tested fine for sure?
        I tested the capacitance, it was i think -18% ish, from what i saw all Electrolytic have a 20% tolerance, does that +/-10% or +/- 20%?
        So if i use a working garbage cap i am going to replace from my other board do you think it may get it to put out 5v? obviously not intend to leave it in there, just to see if that cap is the issue
        • evilkitty
          • Nov 2017
          • 299
          Well the garbage cap worked, i just stuck it on a 1" lead made from Ethernet wire to the left over solder from removing the failed cap on the bottom of the board
          it lasted over a year and a half doing the same thing, so why not another 15 seconds?
          well it puts out 5v and it is able to power the switch up
          The stock 47uf cap tested at 39.27uf, my scrap one tested at 50uf
          • Stefan Payne
            • 1267
            wich still seems fine.
            Especially for high voltage caps the capacitance is on the lower side.
            Even for japanese ones...
              When you check the cap, you need to check ESR also not just capacitance. That 47uF more likely to have high ESR.
              • evilkitty
                • Nov 2017
                • 299
                How can i test ESR?
                i have 2 multi meters to work with
                craftsman 82008 - http://www.sears.com/craftsman-cm-cr...p-03482008000P
                southwire 21050t - http://www.southwiretools.com/tools/tools/21050T
                  You need cap meter that can also test ESR, not the typical meter that you have.
                  Just go to EBAY, for example:
                  https://www.ebay.com/sch/i.html?_fro...meter&_sacat=0
                  You can get meter that can do ESR, CAPACITANCE, and it can also test Transistor and DIODE, ETC.
                  • evilkitty
                    • Nov 2017
                    • 299
                    so are these any good?
                    https://www.ebay.com/itm/122612092649
                    i saw a bunch that look like this some testing parts, looks like you just slap a part in there and press a button and the part is magically detected and you get a schematic and specs on it
                    • Per Hansson
                      • Jul 2005
                      • 5895
                      • Sweden
                      Any of the ESR meters in my quote here is good, the one you linked is very old and not really recommended...
                      Yes of course, it was just to show the lowest price possible.
                      If you are really interested in an ESR meter here are a couple nice ones:
                      https://www.ebay.com/itm/GM328-Trans...Y/152443029396
                      https://www.ebay.com/itm/2016-EZM328...a/182344211065
                      https://www.ebay.com/itm/BSIDE-ESR02...r/162714576281
                      I have the same switch, first had to change the startup cap:
                      https://www.badcaps.net/forum/showpo...&postcount=232
                      Then a few years later I had to change them all, so if you need cap details they should be all there
                      https://www.badcaps.net/forum/showthread.php?t=53745
                      • evilkitty
                        • Nov 2017
                        • 299
                        thanks, found a GM328 from a us seller for less
                        https://www.ebay.com/itm/132268934443
                        • evilkitty
                          • Nov 2017
                          • 299
                          Tester just arrived
                          This is the not working start up cap
                          35.85uf
                          vLoss 17%
                          ESR 40 Ohm
                          i take it that is pretty bad given a new Nichicon 10uf cap is 10.75uf; 0.8% vloss;1.4Ohm ESR
                          PN: UKL1H100KDDANATD
                            • Jul 2011
                            • 6070
                            Tester just arrived
                            35.85uf
                            vLoss 17%
                            ESR 40 Ohm
                            That ESR reading means that it has gone high which means that it is ( bad )
                            A new one would read about .350 to about 1.something
                              Tester just arrived
                              35.85uf
                              vLoss 17%
                              ESR 40 Ohm
                              As expected.
                              BTW always fully discharge the cap before making the measurement or you will blow up your new meter.
                              • evilkitty
                                • Nov 2017
                                • 299
                                As expected.
                                Will a cap passively discharge over time and if so how fast (eg sitting in a cardboard box)?
                                I have a shot 470uf cap from here
                                My multimeter shows this cap as 0.11 nf
                                But this new meter shows me this
                                Capacitance: 194.3uf
                                vloss: 12%
                                ESR: 8.1 Ohm
                                on the other my multimeter shows this cap as 0.1 nf
                                Capacitance: 437.9uf
                                vloss: 2.5%
                                ESR: 0.34 Ohm
                                this cap appears to be in better in much shape than the other, but my multimeter does not see the difference in the Capacitance
                                why is this?
                                  vloss: 12%
                                  ESR: 8.1 Ohm
                                  vloss: 2.5%
                                  ESR: 0.34 Ohm
                                  why is this?
                                  Did you remove the cap and test it OFF the board?
                                  And do you have any new 470uF (or any other values) around to test?
                                  It will self discharge due to leakage resistance (very high resistance but it may hold the charge a long time, best to use appropriate Value and Wattage resistor to discharge the cap and then test it with Volt meter.
                                  This is one of many good website for learning:
                                  http://www.electronicdesign.com/anal...e-stuff-anyhow
                                  • evilkitty
                                    • Nov 2017
                                    • 299
                                    all test were done out of board, board is waiting on good caps to be ordered
                                    the bad 47 uf caps acts as you would expect and so does my 10uf cap
                                    • Tynan Dill
                                      by Tynan Dill
                                      Assuming...
                                      11-22-2024, 01:46 PM
                                    • Powderfanupnorf
                                      Dell AL440LX power on switch circuit help required
                                      by Powderfanupnorf
                                      Hi Everyone. First official post so fingers crossed I conform and also manage to get photos to work.
                                      So I am requesting some help from anyone who happens to have one of these motherboards to hand and perhaps a multimeter.
                                      My board has a single row of header pins for all the front panel stuff (have seen others where they are grouped together differently so thats no help) and the two pins for the power on switch had been previously repaired and I am trying to make a better repair. There looks to be pad and trace damage and im happy to relocate the header pin/pins to...
                                      06-24-2024, 01:24 PM
                                    • Info13
                                      Dell H235P-00 Power Supply Failure
                                      by Info13
                                      A H235P-00 power supply unit from a Dell Optiplex 760 PC is faulty.
                                      After removing it from the computer, I placed a paper clip between the green and black wires, then connected it unloaded to the mains through a series lamp.
                                      ➡️ First test:
                                      The PSU partially works: the green indicator LED lights up, and the fan starts for one second, then stops.
                                      A click can be heard at the moment it stops. The series lamp lights up when the power supply starts, then turns off when it shuts down.
                                      I then followed the advice from the forum and replaced...
                                      10-22-2025, 01:52 PM
                                    • shovenose
                                      Ubiquiti Unifi PoE Switch US-8-150W Power Supply Failure
                                      by shovenose
                                      Got this one for free because, well, it no worky.
                                      A little research and there are tons of complaints all over forums/the internet about premature failure of these switches. The observation everyone makes about these is "they run hot" and failure occurring as soon as 13 months, right out of warranty, of course.
                                      Upon removal of the cover I found a G0398-15011480A power supply that, when plugged in, was making a constant ticking noise. Multimeter confirmed the PSU was the issue. Output was cycling between 0 and about 20V. With output disconnected it sat around...
                                      08-11-2021, 01:26 PM
                                      Acer Switch Switch V 10 SW5-017P Hybrid (2-in-1) V 10 Specification for Upgrade or Repair
                                      This specification for the Acer Switch Switch V 10 SW5-017P Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Switch V 10 SW5-017P boardview and Switch V 10 SW5-017P schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                      09-06-2024, 05:30 AM
