Shuttle ST61G4 No Boot
  • KeriJane
    Mac Enthusiast
    • Sep 2008
    • 681
    Hello.
    I recently obtained a broken Shuttle ST61G4 system complete, ready to run even down to the legit XP Pro COA.
    It's a very pretty little computer with a mirrored front, built-in camera card reader, Firewire, front audio ports and so forth. Cute, even.
    It just didn't boot. Powers on, Lights on, fans on.
    No Video, no disk activity.
    Tried a known good PSU- no luck. The PSU and board are entirely populated with OST in apparent good condition.
    Pulled out the board, checked the caps with an oscilloscope with the power on- 1.4v a little lumpy with ripple at 40mv ( I think)
    I just happened to check the CMOS battery at this point- DEAD.
    Pop in a new 2032 CMOS battery- Surprise! The system works great! It seems that the ATI RS300 chipset requires a live CMOS battery in order to boot! Oh my.... I wonder how many systems have been discarded because of a tiny watch battery gone dead?
    So I went ahead and recapped it anyhow with Rubycon MCZ on the mainboard and UCC KY and KZJ in the PSU. The PSU had non-standard 10mm 2200uf/16v in it which measured at 2000uf. My KZJ replacements were 1800/16 that measured 1900uf.
    After recap, the 1.4v at the caps on the mainboard was flat. No trace of lumpyness. Probably if I change the v/div I could find some.
    It just goes to show....
    Don't assume anything. Even though most computers start OK with a dead CMOS battery, some don't. The previous owner could have saved buying a new system with the purchase of a tiny battery at Walgreens. The system had been disassembled and thoroughly cleaned before I got it, so it's likely that someone had tried to repair it and gave up.
    Due to its dimunative size and total cuteness, I'll probably have to find a place for this thing somewhere. Maybe use it as a dedicated Windows box so I don't have to Boot Camp this Mac Pro when I want Windows.
    Have Fun!
    Keri
    I wish that I had an ESR meter when I had this thing apart. Still, I did save the caps so that I can check them later. Most of the OST caps I pulled were in spec for uF except for the two non-standard ones in the PSU. It'll be interesting to see where the ESR falls.
    The More You Learn The Less You Know!
  • kc8adu
    • Nov 2003
    • 8832
    • U.S.A!
    Re: Shuttle ST61G4 No Boot
    just pulled the boards out of the 2 freebies i got last week.
    these are ss59g v2.0.
    all the ost are nearly open.esr of 8 ohms on all the vcore caps.
    1 would post and then freeze.
    the other boots and restarts.goes in circles.
    i will be using a few 3300 mbz and mostly 820@2.5 solid poly on vcore.
    lots of empty spots on vcore.
    • privato89
      Nintendo Switch Oled HEG-001: Second-Stage Boot Failure
      by privato89
      I'm facing an issue with a HEG-001 motherboard that is unable to complete the Second-Stage Boot. I'd like to start directly with my conclusion, which is the decision to replace the MAX77621AEWI chip, and understand if it could be a correct evaluation.
      Before I dive into the process that led me to this decision, I want to mention that I have a fully equipped lab where I can perform any kind of tests.
      Let's begin:
      Following some guides online, I tried to understand how the Boot phase of the Nintendo Switch works, and what are the...
      03-26-2024, 06:37 AM
    • hinisa
      Xiaomi router freezes at boot after re-capping
      by hinisa
      I'm using Xiaomi Router 4A gigabit edition as wireless repeater. It worked fine for 2 years or so, but last week, wireless started to disappear.
      When I unplug/replug the power, it was working fine for a day/half a day or so until it freezes again.
      After testing with different power supply adapters and concluding it wasn't the issue I finally opened the case and this was the situation:
      Anyway I proceed to clean up the mess and replace all caps but unfortunately it made the situation worse. Now router can't even boot, either it freezes during...
      07-08-2023, 05:58 AM
    • Luke Anders
      Lenovo Legion 5 (15ACH6H/17ACH6H) - Does not boot into any OS
      by Luke Anders
      Hi everyone,
      A few details about the laptop itself:
      Name: Lenovo Legion 5
      Model: 15ACH6H (according to its back cover details) / 17ACH6H (according to the BIOS Menu)
      BIOS Version: GKCN60WW
      EC Version: GKEC65WW
      Serial Number: PF39AQ7Z
      Board Model: NM-D562 Rev 3.0
      RAM: 16GB Installed, DDR4 (brand new)
      NVME: 500GB NVME drive (brand new, installed Windows 10 onto it for testing purposes and tested on another laptop (a dell XPS) works perfectly fine and boots in)
      I bought this laptop recently from eBay as a faulty device....
      10-12-2024, 05:13 AM
    • claws77
      FX553VE-DM318T(FX553v) not POSTING
      by claws77
      Cpu i7-7700hq Ram - 8gb samsung, 32 gb sk hynix
      Gpu - nvidia geforce 1050ti
      Ssd orion o700
      Hdd hgst721010A9e630
      See images
      What's not working right?
      The system does not even POST, display is black,
      LEDs on - power led, aiplane mode, capslock fpr few seconds in the start(when connected to ac power) only.
      When did the problem happen?
      My laptop had dual boot setup, ubuntu and windows 10.
      It already had a moklist error, that would occur when i tried to boot ubuntu.
      05-17-2025, 04:09 PM
    • NolesFan
      Samsung un82ru88000f - Boot loop sort of but can correct with taping of LVDS ribbon
      by NolesFan
      Hello all... TV started boot looping. Opened the back panel and tried to isolate the problem. Just PSB no boot loop. PSB and MB no boot loop. Plug in the LVDS from panel to MB and boot looping starts up. It doesnt matter of order that I plug the LVDS ribbons back in, only 1 and no boot loop but as soon as 2nd one plugs in boot looping. I then noticed a flicker on the screen when I was closing the clip on the harness to the LVDS. Shut the lights off so I can see better, and I noticed as i slowly close it, I will get a picture, but as soon as it clips in, I lose picture and booting happens. So I...
      10-24-2024, 06:36 PM
