ECS H61H2-M2 v2.0 bios
  • nixi22
    • May 2016
    • 44
    • Croatia
    I'm searching for bios dump of this particular MBO
  • IDislikemakingLogins
    • Feb 2017
    • 38
    • moon
    Re: ECS H61H2-M2 v2.0 bios
    Hi, if you have a de-funk dump and lucky enough you can use UEFI tool and use the .cap file from ecs website and attempt to fix a somewhat mangled bios.
    • nixi22
      • May 2016
      • 44
      • Croatia
      I already tried to repair it with content of old dump and new cap file but no luck.
      • ala_borbe
        aka Donald
        • 1625
        • Malta
        post old dump
        Im Back... sort of...
        • nixi22
          • May 2016
          • 44
          • Croatia
          Here is broken dump
          • ala_borbe
            aka Donald
            • 1625
            • Malta
            something is wrong with your dump
            its 14mb????
            i fixed it to 8mb, if its bios problem it should work
            • see1001
              elo
              • Dec 2015
              • 41
              • turkey
              its 14mb????
              do not work.
              casper logo . work
              • bhcomputadores
                • Jun 2017
                • 25
                • Brazil
                Originally posted by see1001
                do not work.
                casper logo . work
                My thanks directly from Brazil. Bios working properly. tested with i5 3470. Bios was uploaded on an OEM motherboard similar to ECS. It was a MWX MW-H61-H2. 100% Running 3-Generation CPU
                • rajeshkumar
                  • Oct 2014
                  • 44
                  • india
                  Thanks working bios
                  • vickey_vip
                    • Mar 2016
                    • 136
                    • India
                    Another Working tested bios here
                    • Ahari
                      by Ahari
                      I...
                      08-13-2025, 06:12 AM
                    • mkdj
                      by mkdj
                      Dear all,
                      10-19-2025, 04:41 AM
                    • Habble7
                      by Habble7
                      Suspected Cause:
                      Troubleshooting Attempts:
                      05-22-2025, 07:28 AM
                    • haitham sharabati
                      by haitham sharabati
                      Hello engineers 😀,
                      🔧 Device Info:
                      - Model: HP 15-da2007ne
                      - Product Number: 8XF55EA#ABV
                      - Serial Number: CND0338P0D
                      - CPU: Intel Celeron N4000
                      💀 Problem:😅
                      08-07-2025, 04:54 AM
                    • Citymin
                      by Citymin
                      S/N : 5RNK9FFT70...
                      08-05-2025, 05:12 AM
