Ue65f9000
    Ue65f9000
    Hello, I wonder if anyone could shed some light in the repair to the mainboard for this tv please, the mainboard is a bn41-01950c and also has a one connect box, after the apps logo is displayed the tv becomes unresponsive and the red led flashes in the bottom right hand corner of the tv, it then starts again and does the same, if it is this board at fault then does anyone know what the fault is with it
    As I can't find a replacement in the uk.
    Thank you.
    Re: Ue65f9000
    Maybe eeprom. You could try spraying freeze spray on it and see if it comes on. Is a one connect box a tuner? If so try disconnecting it and see if it comes on.
      Re: Ue65f9000
      Have you read through Nick's posts on the "One Connect" problem sets
      https://www.badcaps.net/forum/showth...=one%2Aconnect
        Re: Ue65f9000
        Hi thank you, yes I have read it and is a confirmed main board however I can't find a replacement for less than £400, I could probably repair the mainboard if I knew why it was doing it, but haven't' got much on it to be fair.
          Re: Ue65f9000
          It may be more cost effective to keep an eye out for a smashed screen set.
            Re: Ue65f9000
            I had such a problem, rebooting in a circle. the problem was solved by re-rolling nand flash on the programmer. 15 minutes of work.
              Re: Ue65f9000
              What do you mean "re-rolling"? I'm not familiar with this term.
              And which specific eeprom chip are you re-flashing? There are a few eeprom chips I think. Can you list the PCB IC number?
                Re: Ue65f9000
                Unspun did you find a solution for this ?
                  Re: Ue65f9000
                  Hi OCBSlimz:
                  I have a different problem. My TV does not freeze, or lock up, or reboot. The problem with my TV (UN65F9000) is a white screen with yellow/cyan artifacts (with or without the One Connect device attached) and no functionality whatsoever.
                  See the link to the thread below:
                  https://www.badcaps.net/forum/showthread.php?t=63109
                  The solution is Mainboard replacement or repair (specific part number is BN94-06654B. Board markings are BN41-01950C, BN97-07631A. Your numbers may be different).
                  I am still trying to resolve the issue for my problem as of today's date. However, if your TV has a problem with freezing, or lock ups, or reboots, then your solution is also Mainboard replacement or repair, but you may be able to reprogram a new Nand flash or EEPROM chip as indicated by CDRW in his earlier post.
                  CDRW: Can you please let us know which specific IC you replaced or reprogrammed?
                    Re: Ue65f9000
                    Originally posted by Unspun01 View Post
                    Hi OCBSlimz:
                    Hi were u able to repair or had to replace the main board?
                      Re: Ue65f9000
                      I successfully repaired my UN65F9000 TV with working mainboard replacement (TV was stuck on was white screen with cyan/yellow artifacts)
                      I plan to repair the old board when I can. I strongly suspect embedded eMMC memory IC1801 as highlighted in the image I attached below. eMMC = "embedded Multi-Media Controller" with flash memory and a flash memory controller integrated on the same silicon die.
                      IC1801 may be corrupted from a bad update? or like other garbage EEPROM designs, maybe deteriorated internally which is causing the inability to read or write program contents.
                      If I can read the contents of the eMMC chip from my working board, and re-program to a new chip for my faulty board, I think I can repair it... But I have no idea how to read/re-program the IC.
                        Re: Ue65f9000
                        Hello all!
                        I have a ue65f9000 that turns off by itself after a few minutes.
                        I can browse sources, go to the menu, all eco options off, and TV still turns off by itself.
                        It turns on right away if I press the power button.
                        Does this indicates a Mainboard issue?
                        Has anyone faced similar problem?
                        Thanks for any inputs!
