Fixing magic sparkles on a Philips 50pf9830a plasma
  • Spork Schivago
    • Mar 2012
    • 4734
    • United States of America
    Hi.
    Anyone familiar with this TV? The Philips 50pf9830a plasma? A customer brought it to me a while back and we replaced the Y-Main, X-Main, the buffer boards, and the logic board, which fixed the original problem (bad Y and buffers, bad tuner). There were magic sparkles though on the left side (if you were looking at the TV). I want to say just the upper part of the screen, but it could have been the upper and middle part.
    Would those side buffer boards be bad? This had side ones and then ones on the top. I don't have the TV right now, but he's decided he now wants the magic sparkles fixed. He said they had been there a long time.
    I know a leaking PDP can cause it, but how do I test? I know I ran across a thread that discussed the magic sparkles a while back and it said some of them were fixable, depending on what the cause was....plasma's are definitely not my thing!
    The voltages are all in the correct ranges / tolerances. Originally, he said he didn't care about them because they had always been there, but now he says he wants it like new. Not sure it's even possible. Any suggestions on what to do when / if I get the TV?
    Thanks!
  • chrismurphy
    • May 2014
    • 251
    • australia
    Re: Fixing magic sparkles on a Philips 50pf9830a plasma
    pictures would help
    are you talking red green speckles on the screen ?
    if its just one side check for bad solder joints on zsus
    • Spork Schivago
      • Mar 2012
      • 4734
      Thank you. When he brings me the TV, I will post pictures. For this board, I think the X-Main is considered the zsus board, which has been replaced and didn't fix the problem.
      I believe they were red and green. There might have been some white ones, like snow. I'm afraid that PDP (I think that's what it's called) might be slowly leaking.
      • tvtimmy
        • Mar 2015
        • 1160
        • usa
        I thought turning up the VS voltage a little corrected this.
        Maybe someone much more suited to this problem will chime in.
        • chrismurphy
          • May 2014
          • 251
          • australia
          Yes that's the only way to fix this issue , screen on the way out
          VS voltage +10volts no more ,have found on some makes lower works as well ,try both ,if you go too high the protection may kick in
          The problem is its normally short term fix as it will eventually come back slowly
          • Spork Schivago
            • Mar 2012
            • 4734
            Yeah, if it's a leaking panel, I know it'd be a short term fix, and this is what I'm afraid of, that it's a leaking panel. Is there any other known causes that you can guys can think of? I'm sure when I get the actual TV, pictures will help more. Then you can see what I'm talking about.
            • R_J
              • Jun 2012
              • 9624
              Looks like Samsung made the panel? If it was LG there may have been a firmware update for the control board to help this problem, If the ysus board has set_up and set_dn adjustments they can also help to minimize the sparkle. Mark there original positions before adjusting.
              • Lintesir
                Panasonic P42S30 Plasma - Pink sparkles
                by Lintesir
                My parents' Panasonic P42S30 died recently, and they asked me to have a look at it. I was able to identify the SN-board as the culprit, as it was shorted. After removing Q401, Q402, Q421 and Q422 the short was gone, so I replaced these components and that got the TV working again. However, when testing the tv a bit, I noticed quite bad pinkish sparkles on some colors. For instance the greyish bar on this forum seems to trigger it quite badly. I made a fullscreen test picture with only that color, with the below result.
                There is about a 5cm high region at the top without any sparkles,...
                07-26-2024, 03:16 AM
              • celiabrown
                Issue with Plasma Philips 37inch chassis FTL2.1
                by celiabrown
                Hello guys,
                My Plasma Philips 37inch chassis FTL2.1 does no picture ,and goes into protection mode after 30 seconds (red led blinks at 3Hz).
                Can someone has any symptom like this ?
                Thanks​
                05-09-2024, 10:56 PM
              • alro7779
                Philips 32PFL4901/F8 BA4GF0F0102 2 Not getting standby led
                by alro7779
                Hello, guys!
                The same 32" Philips TV I was having video issues, but now I don't have standby led at all. Someone here shared with me the schematic of the power supply, and checking the voltages, I see right after the resistor R604 I'm getting 1.6 v which is too low for enabling the Gate of the Q601 mosfet (the diagram says 4.2). On the R614 resistor I'm getting 181 V in and 117 V out, then through R603 I'm getting the same 117 V in and 59.9 V out, finally getting the latter voltage in the R604 BUT getting just 1.6 V out, which is the voltage that goes on to the Gate of the Q601...
                09-14-2025, 12:25 AM
              • G33RT
                Philips 8200 series 65PUS8204/12 stuck at Philips Logo
                by G33RT
                Philips 8200 series 65PUS8204/12 stuck at Philips Logo, it does not reboot it just stays on the logo.
                It does power up when pressing the power button.
                I already try the power button while plugin the plug with no result.
                Also put the latest firmware autorun-TPM191E_R.001.004.100.000.upg on a MBR/FAT32 USB stick at USB port2 with no result either.
                Could this be an PSU or eMMC issue ?
                07-19-2025, 03:43 AM
              • Nirrain
                Panasonic TX-P42S20E Plasma tv. First purple sparkles, now completely black
                by Nirrain
                I have a Panasonic TX-P42S20E plasma TV that lately has been showing flashing pink pixels when the picture is bright (similar to picture 5 in this post), primarily on the top half but to a lesser degree in the buttom half.
                I've tried to change VSUS to high but it made the issue even worse so changed it back.
                However, this is all a backstory as yesterday after being on for about 5 minutes the screen turned black. I've tried to hard reset (hold power on tv for 30 sec).
                When turned on the green LED flashes 6 times and then stays on continously....
                07-09-2021, 02:38 AM
