Onkyo tx-nr509 receiver no power
  • Wiil
    • Jul 2017
    • 4
    • Usa
    Hello, I recently started troubleshooting my onkyo tx-nr509 receiver that refuses to turn on.
    I suspect the issue is the power supply, but all of the capacitors appear to be fine. The output I measured does not match the specifications on the board, however. The +12VD_ST and +10VS pins on the output both measure around +15v referenced to the GNDDG pin. Fuse is fine, primary side of transformer is receiving 115v ac, output of secondary is about 12.3v ac.
    The output voltage has no ripple, but drops significantly when i add a resistor across the output to about 5v with a 1k resistor. The output of the secondary also drops significantly.
    Since the capacitors look fine, I suspect the issue lies in the transformer or rectification diodes. Any ideas on what my issue could be? Am I on the right track? What would be my options for a replacement transformer?
    Thanks!
  • dobrykamil
    • Jun 2013
    • 63
    Re: Onkyo tx-nr509 receiver no power
    Thanks!
    Hi.
    Please check the main relay (common issue) I believe, the relay's impedance should be around 300-330 Ohm.If it's more than this, replace it.
    • Wiil
      • Jul 2017
      • 4
      • Usa
      Originally posted by dobrykamil
      Hi.
      The relay appears to be bad, Thanks!
      • Wiil
        • Jul 2017
        • 4
        • Usa
        Hi.
        Hey, I replaced the main relay and now the unit clicks a few times when I plug it in, but there is no response to the power button and no display.
        Any ideas what my issue is?
        • mmartell
          • Oct 2013
          • 3189
          Check the transformer primary winding for open condition. There may be a small fuse in the winding that went open.
          • tibimakai
            • Jan 2012
            • 3680
            I had similar issues with other Onkyo receivers, where the ribbon cable(that comes from the front board) wasn't inserted all the way, into the HDMI board, or it was cut to thin(width is less) and it was inserted offset, into the connector. Pins in the connector were not aligned, with the ribbon pins.
            • marqo
              • Feb 2019
              • 1
              • Poland
              Hello Wiil, have you solved your issue? I have similar with my HT-R990 where relay is clicking continuously and display is switching on and off repeatably.
              • madan1
                • Nov 2016
                • 712
                • Bulgaria
                Some of those onkyos behave like that when the back plate is removed. It is used to distribute ground through the boards and without it they just do not want to start.
                • FrancescoV
                  Onkyo HT-R390 no sound output, video output ok
                  by FrancescoV
                  Good morning everyone,
                  I'm trying to repair an onkyo ht-r390 that has no sound output, despite the volume being at maximum, the rest seems to work; the video output signal (coming from an hdmi input) is present, but the audio is absent. Similar situation if I send an audio signal from any input I have no output.
                  The firmware reported is the following:
                  M:1.00/11107BLP
                  D:?.??/????????
                  O:1.00/11107AL
                  The DSP firmware given the question marks seems corrupt.
                  On the BCHDM-0678 - 25140678 - QPWBCHDM0678A0 board the chip that usually seems...
                  05-11-2025, 02:59 AM
                • CDNBrewer
                  Running out of Ideas, hoping someone smart can provide some for my ONKYO TX-SR353 Receiver
                  by CDNBrewer
                  Hello Everyone,
                  I have an Onkyo TX-SR353 Audio/Video Receiver (5.1 ch with HDMI) that I am having a really hard time diagnosing and I'm about to throw this in the junk and go buy a new unit that is on sale until the 7th.
                  Symptoms:
                  • Intermittent (part of the reason why i'm having a hard time isolating problem), sometimes will work for 10+h at a time without issue
                  • Original symptom was wife reported loud banging noise (like someone was banging on the wall with their fists) from the LEFT SURROUND speaker and then the unit shut off.
                  • I swapped the Left and Right surround
                  08-05-2025, 09:29 PM
                • bauto601
                  KDM 480W PSU upgrade succes! (opinions?)
                  by bauto601
                  Back in 2020 i bought a (2nd hand) compact ATX psu to replace my current one. My PC case only fits very short ATX power supplies so i didn't really have the choice of buying a decent 80Plus unit. The current unit is a modded YoungYear unit that i made a thread about a while ago:
                  A "nice" YoungYear unit? - Badcaps
                  The "new" unit is a KDM-M6480 480W psu, the 480W number is a typical KDM bullshit claim of course, but the 24A rating on the 12V rail seemed reasonable and the "Active PFC" claim gave me a bit of hope that this was going to be decent-ish....
                  12-26-2023, 03:05 PM
                  NTE Electronics “NTE5251K” Zener Diode 9.1V @ 50W Do-5.5% Want to build a 9.1 output from a 9.6 lipo4 battery pack
                  by sam_sam_sam
                  I have bought this Zener Diode for this project what size and wattage resistor value do I need to use to get near 50 watt output
                  I bought this from an eBay seller but unfortunately they only had one
                  I bought three from Vetco Electronics these are Sylvania ECG5185A 9.1@10w A to Stud what size and watt resistor do I need to use to get near 10 watt output
                  I bought three of from them to also make battery packs with this output power limit in mind
                  I want to use this battery pack and turn it into a 9.1 output battery pack output to eliminate using 9 volt battery...
                  04-23-2025, 05:50 AM
                • amelbye
                  is it ok to replace a dual output transformer with two single output transformers?
                  by amelbye
                  Hi, some prestory: I was repairing an amplifier - a "Phil Jones Bass". It had some bad capacitors an a faulty power switch. Easy job. However upon putting it back together I screwed up. The connector from the 15V-0V-15V from the transformer is identical to the audio ouput from the preamp board to the poweramp board. I ended up putting +-15VAC into the preamp outputs frying some traces on the circuit board along with the power transformer The transformer is shorted. It blows the fuse immediately even with no load on the secondary.
                  Now that's a challenge - luckily...
                  08-21-2020, 08:51 AM
