Hi guys
I've been looking at this Samsung LE32S73BD. Basically the Standby LED is flashing and the TV will not power up.
On the PSU all the voltage rails are coming on for a few seconds, but they read much lower than they should. For example 24V rail is going to just over 5V. Then the voltages all decay and power back up again.... ad nausium
I don't have my Isolation Transformer here yet, it is still in the UK with my variac.
Putting my scope on 10mV scale and holding the probe near to the SMPS transformer primary it is clear that the PSU is powering up for a few seconds, then stops oscillating for a second and powers back up again.
Found one bad bulging cap on the low voltage side 1000uF 10V and changed that. All the rest look OK visually. It didn't make any difference anyway.
No short circuits on any voltage rails and anyway every rail gets some voltage (lower than it should be) so there couldn't be any shorts.
I found a repair kit for this fault on ebay so it seems fairly common? The kit is one IC and one capacitor. It's obvious which IC it is, not sure which cap.
Anyone seen this fault and could suggest anyway to prove the cause of the fault before buying the repair kit (or just the IC and Cap if I know which it is)
This is definitely for my model of power supply board BN96-03775A
http://www.ebay.co.uk/itm/F9222-REPA...MAAOSwPhdU1LTi
Cheers
Rich
Cheers
Rich
