First circuit design needs to be checked please?
  • EasyGoing1
    Shock Therapist
    • Sep 2016
    • 977
    I am building a hidden compartment for valuables and I decided to use a magnetic reed switch so that I can hide the switch, and I decided to go with a 12 volt solenoid as the locking mechanism.
    When I connected the solenoid to the 12 volt source through the reed switch and then hit it with a magnet, the reed switch immediately became magnetized and will not open up anymore. Fortunately, I have 10 of these things and I figured it was the heavy current traversing the switch that was magnetizing the iron elements inside.
    SO, I decided that I need to switch this solenoid with a low current and what better way to do that then with a power transistor?
    Here is the design I came up with. I simply need someone who knows more than I do (electronics is a hobby for me, not a career) to please look at the design and let me know if I missed anything? I need this thing to last because I'm installing it in an inconspicuous place that will be hard to get to later on should it need to be repaired or whatever.
    I included the datasheets to save you time.
    Thank you,
    Mike
    sigpic
  • Andrew F. Ali
    • Jan 2014
    • 2450
    • Trinidad & Tobago
    Re: First circuit design needs to be checked please?
    From you diagram the diode across the solenoid is wrong. It should be the other way around. Perhaps the magnet you are using is too powerful for the Reed switch.
      • 31199
      not magnetised, you welded the contacts!
      your circuit looks generally o.k. - dont know about those resistor values though.
      HOWEVER - your protection diode is the wrong way around - it will blow or take out your transistor!!
        • 31199
        and use a 1n4007 - you need a high voltage one.
        • EasyGoing1
          Shock Therapist
          • Sep 2016
          • 977
          I probably did weld the contacts...
          The resistors I calculated using a voltage divider calculator ... across R2 I get somewhere around 4.7 Volts.
          I know that when I tested the circuit, when the diode was inserted the wrong way, the solenoid would not energize at all ... I'll make sure that its in the right way when I solder it up.
          If I'm not mistaken, the line on the diode represents the cathode, right? and current flows in the direction of cathode to anode ... right?
          And if thats the case, then wont this configuration prevent current from flowing backwards into the Collector of the transistor, so that any charge in the solenoid will have to dissipate through itself?
          sigpic
          • EasyGoing1
            Shock Therapist
            • Sep 2016
            • 977
            No, I used a magnetized small screwdriver head ... one that barely picks up screws... it was definitely the current flow through the switch. I had an ammeter on it and it reached 1.5 amps ... I dont know what these reed switches are rated at, but they are very delicate looking things encased in glass ... they don't look to me like they could handle 1.5 amps at 12 volts...
            Mike
            sigpic
            • EasyGoing1
              Shock Therapist
              • Sep 2016
              • 977
              I dont think I have any ... and you're right about the diode ... I thought about current flow and as it is in the schematic, it would dissipate back through the Collector...
              sigpic
              • EasyGoing1
                Shock Therapist
                • Sep 2016
                • 977
                I do have a couple of monster diodes that I salvaged from something some time ago ... they are PFR854 and GI826. The 854 is rated a 600 volts in reverse and the other one is 400 volts ... here are the datasheets.
                sigpic
                  "The resistors I calculated using a voltage divider calculator ... across R2 I get somewhere around 4.7 Volts." Vr2 will not be higher than Vbe junction Voltage of the Transistor unless that B-E junction is blown.
                  • EasyGoing1
                    Shock Therapist
                    • Sep 2016
                    • 977
                    Originally posted by budm
                    [B][I]Vr2 will not be higher than Vbe junction Voltage of the Transistor unless that B-E junction is blown.
                    No, what I'm saying is, that the voltage divider formula for R2, which is:
                    VR2 = Vcc * (R2/R1+R2)
                    And in this case, the result is:
                    VR2 = 12*(1.8/(2.6+1.8))
                    VR2 = 4.9V
                    Thats the voltage I'm using to turn the transistor on ... and it seems to work...
                    sigpic
                    • EasyGoing1
                      Shock Therapist
                      • Sep 2016
                      • 977
                      Updated the schematic
                      sigpic
                        That is not how you do it, The R2 = 0.6V because it is connected in parallel with B-E junction of the transistor, so VR1 = 11.64V, and then you can calculate what the Bias current will need tobe for the transistor to be turn on to allow enough current to flow through the relay, in this case you want the transistor to be in saturation condition (fully on).
                        http://www.dummies.com/programming/e...r-as-a-switch/
                        http://www.petervis.com/GCSE_Design_...h_Biasing.html
                        http://www.electronics-tutorials.ws/...or/tran_4.html
                        http://www.rason.org/Projects/transwit/transwit.htm
                          • 31199
                          a fet may be better, as it's only on or off
                          or an scr - if they even make those anymore!
                          • redwire
                            • Dec 2010
                            • 3912
                            It will not work so great, a few suggestions.
                            R2 should be across the E-B junction of the transistor (move it from other side of reed switch). This to ensure R1+R2 don't drain the battery dead (they are always wasting current as drawn), and to ensure the transistor leakage currents keep it off. I would set R2 to 10k-100k ohm, not critical.
                            You are looking at R1+R2 as a voltage divider, dropping 12V down but a transistor is a current-controlled device. Input current (base) controls output (collector) current.
                            This means R1 sets the base-current. 2N6487 is a low gain part, as low as hFE=20. For 1A solenoid, theory says R1 = (Vcc-VBE)/IB or (12V-0.6V)/50mA =228ohms. In practice you'd use a 150-220ohm resistor to give the transistor extra base drive. Since R2 is so much bigger than R1, it is ignored in the calculation for convenience.
                            Make sure you can access this thing if the battery goes dead.
                            • EasyGoing1
                              Shock Therapist
                              • Sep 2016
                              • 977
                              I had thought about 'idle' current draw of the voltage divider, so I put my Fluke in there in current mode and its drawing around 3mA when not in use. Now, a car battery is roughly 75 AH??? I think when I did the math, it would take something like 10 years to drain the battery.
                              I think if I lowered the resistor values to give the transistor more of what it wants, that might increase my idle current draw... but this suggestion of moving the resistor to the other side ... are you saying that R2 should connect from the Emitter to the Collector?
                              sigpic
                              • EasyGoing1
                                Shock Therapist
                                • Sep 2016
                                • 977
                                No I think this is what you're saying? (see attachment)
                                It's bloody brilliant ... I was trying to think of a way to incorporate the switch so that the circuit was not completed at all until the switch was actuated, and this configuration had not even occurred to me, but now that I look at it ... its simple and its perfect.
                                sigpic
                                  Just put the switch on the high side feeding the R1 so when switch is not closed there will be current draw through the bias resistors. R1 needs to be able to give enough bias to put the transistor in saturation mode.
                                  "are you saying that R2 should connect from the Emitter to the Collector?" That will give the path for the current to flow through the solenoid and through the resisto even when the transistor is not on, just follow the current flow and you will see why.
                                  Did you read any of the links I gave?
                                    That is one way of doing it. But R1 has to be able to provide enough bias current to turn the transistor fully on. R2 can be higher value too.
                                    • redwire
                                      • Dec 2010
                                      • 3912
                                      No I think this is what you're saying? (see attachment)...
                                      Yes that looks better. R1 is still 10x too big to saturate the transistor. It works now but the transistor is probably partially "on" losing 1-2V and burn your finger if you keep the solenoid on.
                                      That car battery sitting there doing nothing, self-discharge estimate 3.5%/month or 3.7mA due to impurities in the acid alone.
                                      Please add a fuse close to the car battery for safety. Say 5A.
                                      • EasyGoing1
                                        Shock Therapist
                                        • Sep 2016
                                        • 977
                                        After reading the first two links, I came up with this:
                                        (I edited this because of an error in the math png file)
                                        Last edited by EasyGoing1; 05-16-2017, 09:09 PM. Reason: There was an error in one of the graphics
                                        sigpic
                                        • Powderfanupnorf
                                          Dell AL440LX power on switch circuit help required
                                          by Powderfanupnorf
                                          Hi Everyone. First official post so fingers crossed I conform and also manage to get photos to work.
                                          So I am requesting some help from anyone who happens to have one of these motherboards to hand and perhaps a multimeter.
                                          My board has a single row of header pins for all the front panel stuff (have seen others where they are grouped together differently so thats no help) and the two pins for the power on switch had been previously repaired and I am trying to make a better repair. There looks to be pad and trace damage and im happy to relocate the header pin/pins to...
                                          06-24-2024, 01:24 PM
                                          Acer Switch Switch V 10 SW5-017P Hybrid (2-in-1) V 10 Specification for Upgrade or Repair
                                          This specification for the Acer Switch Switch V 10 SW5-017P Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Switch V 10 SW5-017P boardview and Switch V 10 SW5-017P schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                          09-06-2024, 05:30 AM
                                        • fab13
                                          Nintendo Switch lite charging chip heats up and does not short circuit
                                          by fab13
                                          Hello everyone
                                          Small technical problem on a Nintendo Switch lite
                                          Here's what I noticed: the USB port has been damaged internally, with a short circuit on the power supply line to the small fuse.
                                          After replacing the USB connector, the short circuit went away and I can't see any other short circuit in the whole motherboard.
                                          When I charge the console, it seems to be charging: I get 15 volts and an amperage of 0.450 A.
                                          Then, after a while, the amperage increases to 1.1 A and the BQ24193 charging chip starts to heat up, as evidenced...
                                          09-16-2023, 04:59 AM
                                        • Natob82
                                          Micro Momentary Push Switch?
                                          by Natob82
                                          Great to be here! I'm a newbie here trying to find a "micro", momentary push switch to repair a Sony "clamshell" video walkman. This micro switch has long since discontinued by Sony, however I hope there are third-party switches of the same size and functionality that I might be able to source to play the same role. The purpose of this switch is to tell the video walkman that the user has activated the mechanical tape eject button, turning that physical action into an electronic signal that tells the tape transport mechanism to open so one can load or eject a video tape. I...
                                          12-21-2022, 05:22 AM
                                        • grimacelord
                                          NEC TurboExpress On/Off Power Switch Replacement Help
                                          by grimacelord
                                          I've been working on a NEC TurboExpress and I accidentally got the plastic inside the power ON/OFF switch too hot while doing other repairs and melted it. At first, it would still power on when sliding the switch, but you had to really press inward while sliding to get it to work.
                                          I removed the switch component and tried to gently melt the plastic back so it would work more reliably and all I managed to do was make it worse.
                                          I need to find a replacement On/OFF switch for this, but having some trouble figuring out which kind of switch I need....
                                          11-09-2023, 09:49 AM
