Hi. I'm new to this forum (posting, I've been reading it for like two months so far, until I feel comfortable with a little knowledge and a soldering iron).
I have a Samsung 173s that turns on, lights the screen, and then displays the "No signal cable" roaming message on screen. It can stay that way for hours. As soon as I connect a VGA cable to the D-sub input, the screen goes black, and the power led starts blinking. If I remove the VGA cable, it again displays the message of no signal. I opened it and removed the two lamps (2 tubes each one, used them on a ToteVision 18" that had a bad inverter, which was replaced with one from a VE500), so right now it has no lamps installed. The monitor is in good condition, and being 17", I don't want to use it for parts if it can be fixed. I don't have a camera right now, but I will in a couple of days. The boards seem good on visual inspection, but I don't know much about electronics, so I don't know where to start looking. Any advice would be really appreciated.
Thanks in advance.
Thanks in advance.
