Xbox 1.6 Power Supply Problem
  • Gorrillasnot
    • Dec 2013
    • 316
    I have a original Xbox 1.6 that I am tinkering with.
    Originally it had 5 bad 3300uF 6.3v caps near the power connector on the motherboard. I replaced those with some low ESR replacements and the Xbox worked good for a couple months. Then the other day I pressed the power button and got nothing.
    I swapped in a good PSU from another 1.6 Xbox and it fired right up.
    On the bad PSU I don't see any obvious signs of damage and the fuse tested good with my DMM.
    I'm not getting any voltage readings at the power connector that plugs into the motherboard.
    I'm somewhat of a newb but where would be a good place to start? what part is likely bad?
    The PSU is labeled Tuscany.
    thanks
    Re: Xbox 1.6 Power Supply Problem
    So are you getting any DCV between the two legs of each one of the two main filter caps in the primary side?
    • Gorrillasnot
      • Dec 2013
      • 316
      Hi budm.
      Yep I am getting 171v on each of the filter caps.
      • Drack
        Yup it's me
        • Nov 2016
        • 297
        • Venezuela
        That's a perfect voltage, have you checked the primary transistors or the rectifier on the secondary for shorts?
        • Gorrillasnot
          • Dec 2013
          • 316
          I am a newb so I am not sure what the rectifier is, but I have checked all the transistors and all give a reading except Q6 (circled in pic next to big cap)
          thanks
          • Drack
            Yup it's me
            • Nov 2016
            • 297
            • Venezuela
            Tell us what is written on the pieces mounted on the heatsink and we will tell you what they are and how to test them
            • Gorrillasnot
              • Dec 2013
              • 316
              I cant make out whats written on most of them because of the other components that are in the way. One of the items on the backside of the big heatsink says SF1004G.
              The board looks a little discolored in the area of resistor R10.
              I googled "xbox power supply r10" and it appears another person with version 1.0 of this PSU had an issue with this resistor. http://www.xbmc4xbox.org.uk/forum/vi...t=4946&p=33993
              How can I tell if mine is bad and what would be a good replacement?
              Could I harvest 1 off of a old PC motherboard? (I have a few of those laying around)
              thanks
              EDIT: Nevermind on the resistor. It measures 68.3 so I think it is good.
                Can we see good clear straight shot pictures of the bottom side of the board?
                  https://www.badcaps.net/forum/attach...8&d=1486841140
                  See those two small lytics cap right next to the power resistor? They are probably startup/running caps, try heating them with hair dryer for 2~3 minutes and then apply the power to the board to see if you will get any dcv output on the cold side.
                  • Gorrillasnot
                    • Dec 2013
                    • 316
                    tried heating the caps with my heat gun, but still didn't get any output.
                    • Drack
                      Yup it's me
                      • Nov 2016
                      • 297
                      • Venezuela
                      Is it me or is that a burnt mark on the middle of the PCB?
                      • Gorrillasnot
                        • Dec 2013
                        • 316
                        I think its a shadow in the picture..I cant see any burn marks on the bottom of the board.
                        I do see some discoloration on the top side of the board though near the R10 resistor and the thing with a yellow top in front of the big heatsink (transformer?). The board looks darker in this area
                        • Drack
                          Yup it's me
                          • Nov 2016
                          • 297
                          • Venezuela
                          Well is a resistor, they get hot because of the inefficient way the work, the big yellow thing is indeed the transformer and it looks like the discoloration on its side of the PCB is due to the same resistor.
                          • Gorrillasnot
                            • Dec 2013
                            • 316
                            I found a used psu on ebay for $12. I think that will be the quickest and easiest way to get the ole xbox back up and running.
                            Thank u both for all your help
                              That resistor looks to be part RC Snubber network.
                              • CapLeaker
                                Leaking Member
                                • Dec 2014
                                • 8153
                                Now you can compare the working PSU against the non working one. I would check the gate drive components, what ever switches the FET on the primary on the old PSU.
                                • Drack
                                  Yup it's me
                                  • Nov 2016
                                  • 297
                                  • Venezuela
                                  Well that's an option, not the one I like, but is one nonetheless
                                    by sam_sam_sam
                                    03-31-2024, 02:12 PM
                                    by sam_sam_sam
                                    07-01-2024, 06:34 AM
                                  • Tynan Dill
                                    by Tynan Dill
                                    Assuming...
                                    11-22-2024, 01:46 PM
                                  • JimBanville
                                    Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
                                    by JimBanville
                                    The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
                                    Opened it up and discovered the power supply is making a faint clicking or ticking sound.
                                    I measured the amp's output to the woofer and it pulses up to 50mv DC to be driver. The pulses coincide with the power supply ticking/clicking.
                                    I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
                                    09-13-2023, 07:21 AM
                                  • shamsudeen
                                    Hi, Can we use SMPS Bench Power Supply for Laptop troubleshooting?
                                    by shamsudeen
                                    Hi all, I just need to know that, can i use SMPS type power supply to test and short circuit detection on a laptop motherboard?
                                    I saw 95% of repair guys are using only Linear bench power supply. linear bench power supply is pricy, thats why i planned to get one SMPS supply.
                                    i know that in linear power supply the noise will be very low comparing to SMPS supply....
                                    07-19-2025, 07:14 AM
