hp 15 bios da0u93mb6d2
  • bluestone
    • Jun 2011
    • 343
    • Ghana
    I need this dump urgently pls help da0u93mb6d2
  • imranromi
    • Jan 2015
    • 1290
    • Pakistan
    Re: hp 15 bios
    Try this and reply.
    • bluestone
      • Jun 2011
      • 343
      • Ghana
      Re: hp 15 bios
      Originally posted by imranromi
      Try this and reply.
      already tried this one it didn't work. this is for da0u93mb6d0
      • mehmood muhaish
        • Sep 2013
        • 37
        • pakistan
        Re: hp 15 bios
        need bios DA0U93MB6D2 REV
        • ADAN
          • Apr 2017
          • 3
          • TUNISIA
          Re:HP 15 BIOS
          • fyaagoub
            • Dec 2016
            • 269
            • maroc
            Re: hp 15 bios
            Thank you very much
            • Watz
              • Sep 2014
              • 21
              • Kenya
              Re: hp 15 bios
              Thank you, worked like a charm on a DA0U93MB6D2 board
              • premnam@gmail.com
                • Apr 2015
                • 2
                • india
                not working ..i tried this
                • samoosa
                  • Jan 2015
                  • 3
                  • South Africa
                  Re: hp 15 bios
                  How do I read/write ec chip?
                  • hussaka
                    • Jan 2015
                    • 154
                    • italy
                    Re: hp 15 bios
                    thank you so much
                    • eljiranih
                      • May 2020
                      • 1
                      • maroc
                      Re: hp 15-ay011tx bios
                      thank you so much
                      • Ahari
                        by Ahari
                        I...
                        08-13-2025, 06:12 AM
                      • mkdj
                        ASUS ZenBook UX480F : need help with cleaning the ME region of my BIOS dump
                        by mkdj
                        Dear all,
                        I have a ASUS ZenBook UX480F with the following symptoms:
                        I suspect it is a BIOS issue. So I decided to try to clean the ME region. I followed the guide on win-raid, and I believe I have done everything correctly. My problem is: when I open the outimage.bin in ME Analyzer, it says that it is Extracted, and not Region, Extracted as it should be. Is it normal, or did I do something not correctly? This is my first experience editing BIOS files.
                        I would appreciate if someone could take time to explain the issue, so that I can learn. But I would...
                        10-19-2025, 04:41 AM
                      • Habble7
                        I need a BIOS dump for the Samsung S49CG934SU monitor
                        by Habble7
                        The Samsung S49CG934SU monitor does not power on - no LED indicator activity and no response to power button. However, when 21V power is connected, it immediately draws 0.8A of current with no display output. The motherboard processor gets warm, and there is continuous reading activity from the W25Q128BV BIOS chip.
                        Suspected Cause:
                        I suspect the BIOS may have been corrupted during a power interruption while updating the firmware. The official website provides firmware updates, but they can only be installed via USB flash drive.
                        Troubleshooting Attempts:
                        05-22-2025, 07:28 AM
                      • haitham sharabati
                        [Request] Clean BIOS dump for HP 15-da2007ne (8XF55EA#ABV) - N4000 - BIOS Lock
                        by haitham sharabati
                        Hello engineers 😀,
                        I’m kindly requesting a clean and unlocked BIOS dump for the following HP laptop, as it’s bricked after flashing SP152727. The system now keeps rebooting, and the original issue was an Administrator / Power-On Password that I can no longer access.😏
                        🔧 Device Info:
                        - Model: HP 15-da2007ne
                        - Product Number: 8XF55EA#ABV
                        - Serial Number: CND0338P0D
                        - CPU: Intel Celeron N4000
                        - EC/BIOS Chip: [Add chip number from the motherboard or BIOS chip]
                        💀 Problem:😅
                        - Device shows “Administrator Password”...
                        08-07-2025, 04:54 AM
                      • Citymin
                        NT955XED (Samsung Galaxy Book2 Pro - 15.6) BIOS dump file Request
                        by Citymin
                        My Samsung Galaxy Book 2 Pro 15.6-inch laptop has no display and won't boot.
                        The charging red LED lights up, but the charging screen doesn't show any indication.
                        When I press the power button, the blue LED cycles on and off three times, then the screen doesn't turn on, and the device won't boot.
                        (I've tried removing the battery and resetting the device, but the issue persists.)
                        NoteBook Model name : Samsung NT955XED-KK51G(Galaxy book2 pro, i5-1240p, 15.6inch AMOLED)
                        PCB model name : Venus2-15-5G(REV1.2), Venus2-15 ADL NPC
                        S/N : 5RNK9FFT70...
                        08-05-2025, 05:12 AM
