dell xps 13 L322x (2012/13)
  • g0rak
    • May 2014
    • 10
    • Czech Republic
    I am seeking tips on mobo repair in beautiful dell xps13 L322x (2012/13). Its a bga IvyBridge with qs77/76? chipset.
    Symptomps:
    Black screen, not a flash of light. Keyboard light is on, keyboard does not read keys (like FN + turn off Keyb.Light, or caps lock switching)
    Stays on, until you switch it off with PWBTN, produces quite a heat and I didnt saw fan spinning since then.
    It happened when I was rebooting Ubuntu, and when you expect to see Logo flash there was only black screen. At that momment I had to go away for like 5-10 minutes thinking damm linux, gonna deal with you fucker when I come back. Yea
    Tryed so far:
    Ive stripped it completedly, cleaned it, put away all cards, disks, repro etc... Still same. Batery only, AC only(got 2 AC adapters), pluged another monitor., putting preassure on chipset, cpu. Unpluging bios battery (~3.1 V). Not a clue.
    BIOS code shows: "0." (got that chineese PCI-m code reading card). Pressing FN+PWBTN does not work (i believe it should run dell BEEP diagnostics).
    So It ends to two scenarios in my opinion, power issue or chipset/cpu, right? Its wierd chipset is 3,5W with NO heatsing or anything over it! It was coverd only by black tape (to be fancy). Anyway motherboard doesnt have any brown areas (like overheat dmg, or even melted stuff). If I compare it to my Acer mobo, it actualy looks like new. When I opened it first motherboard was untouched (had no reflow/reball imho).
    Sooo, how is changing 22x22mm chipset with roughly 1k balls?
    Ty for any advices.
    /g0rak
  • g0rak
    • May 2014
    • 10
    • Czech Republic
    Re: dell xps 13 L322x (2012/13)
    reserved .. power issue with adapter
    • Bowline
      by Bowline
      06-11-2025, 10:13 AM
    • Akhlz001
      Dell Pro 13 Plus PB13250 Bios Unlock
      by Akhlz001
      Could someone help trying to unlock this BIOS, seems that Dell have changed the layout of new Dell Pro 8FC8 bioses from checking HXD - 4000 bits do not need changing, only 2000. However after FF the section starting from '01000' upto 2000 bits and then soldering the chip back it seems that the microchip on the motherboard is recovering the bios back to original settings after first boot. Has anyone found a way to crack this extra layer of security Dell have implemented? Seems both HP and Dell have upped bios security to match Lenovo by implementing extra measures on a separate...
      09-20-2025, 07:15 PM
    • master3112
      Dell Inspiron 5590 Board 18778-1 no charging, charging not possible
      by master3112
      I would like to share my experience about charging issues with Dell power supplies with the tech community. I am working on a Dell Inspiron 5590, Mainboard 18778-1 with charging problems. The device can be switched on and works so far, only the message appears at startup:
      Alert! The AC power adapter wattage and Type cannot be determined. The battery may not change. The System will adjust the performace to match the power available.
      The power supply unit is not recognized in the Bios and the charging process is set to "idle". I use original Dell battery, type...
      07-29-2025, 01:55 PM
    • F R 2568
      Dell Latitude 5420 does not start (no post) need help to find the reason why
      by F R 2568
      Hello all,
      this is my first post, so if I make mistakes please do not hesitate to point them out, thank you in advance.
      I got a Dell Latitude 5420 (Service Tag: 7RFM6D3, Motherboard: GDF40 LA-491P Rev.: 2.0 (A01)) which does not start and I want to repair it. These are the symptoms:
      If the laptop is only connected to the AC adapter (battery removed):
      When I press the power button, the keyboard backlight and the display backlight are turning on. Caps key light is lightning, but key does not respond to pressing it.
      The power/battery...
      01-08-2025, 05:45 AM
    • diamon
      Looking for Dell Latitude 5520 / 5530 / 5540 RJ45 network connector replacement
      by diamon
      I have a Dell Latitude 5530 with a damaged RJ45 network connector. See the attached pictures.
      Have already searched on Farnell / Aliexpress / Ebay and had contact with several suppliers on Aliexpress and Ebay, but they cannot deliver this connector.
      Is there someone inside the EU, who has these connector(s) or perhaps defective motherboard(s) for these laptop models I have mentioned in the topic title.
      Pictures of these boards:
      Dell Latitude 5520 https://www.ebay.com/itm/256052956663
      Dell Latitude 5530 https://www.ebay.com/itm/125844181534
      Dell...
      02-28-2024, 12:51 PM
