dell xps 13 L322x (2012/13)
  • g0rak
    • May 2014
    • 10
    • Czech Republic
    I am seeking tips on mobo repair in beautiful dell xps13 L322x (2012/13). Its a bga IvyBridge with qs77/76? chipset.
    Symptomps:
    Black screen, not a flash of light. Keyboard light is on, keyboard does not read keys (like FN + turn off Keyb.Light, or caps lock switching)
    Stays on, until you switch it off with PWBTN, produces quite a heat and I didnt saw fan spinning since then.
    It happened when I was rebooting Ubuntu, and when you expect to see Logo flash there was only black screen. At that momment I had to go away for like 5-10 minutes thinking damm linux, gonna deal with you fucker when I come back. Yea
    Tryed so far:
    Ive stripped it completedly, cleaned it, put away all cards, disks, repro etc... Still same. Batery only, AC only(got 2 AC adapters), pluged another monitor., putting preassure on chipset, cpu. Unpluging bios battery (~3.1 V). Not a clue.
    BIOS code shows: "0." (got that chineese PCI-m code reading card). Pressing FN+PWBTN does not work (i believe it should run dell BEEP diagnostics).
    So It ends to two scenarios in my opinion, power issue or chipset/cpu, right? Its wierd chipset is 3,5W with NO heatsing or anything over it! It was coverd only by black tape (to be fancy). Anyway motherboard doesnt have any brown areas (like overheat dmg, or even melted stuff). If I compare it to my Acer mobo, it actualy looks like new. When I opened it first motherboard was untouched (had no reflow/reball imho).
    Sooo, how is changing 22x22mm chipset with roughly 1k balls?
    Ty for any advices.
    /g0rak
  • g0rak
    • May 2014
    • 10
    • Czech Republic
    Re: dell xps 13 L322x (2012/13)
    reserved .. power issue with adapter
    • Bowline
      by Bowline
      06-11-2025, 10:13 AM
    • Akhlz001
      by Akhlz001
      09-20-2025, 07:15 PM
    • master3112
      by master3112
      07-29-2025, 01:55 PM
      Dell Thunderbolt Firmware
      by SMDFlea
      Dell thunderbolt firmware, extracted from dell firmware update exe. Padded to 1MB.
      Some models have a choice of 2 different firmwares, it depends on the dell SKU.
      The SKU is in brackets (****)
      EDIT: NVM65...
      01-26-2025, 06:22 AM
    • F R 2568
      Dell Latitude 5420 does not start (no post) need help to find the reason why
      by F R 2568
      Hello all,
      this is my first post, so if I make mistakes please do not hesitate to point them out, thank you in advance.
      I got a Dell Latitude 5420 (Service Tag: 7RFM6D3, Motherboard: GDF40 LA-491P Rev.: 2.0 (A01)) which does not start and I want to repair it. These are the symptoms:
      If the laptop is only connected to the AC adapter (battery removed):
      When I press the power button, the keyboard backlight and the display backlight are turning on. Caps key light is lightning, but key does not respond to pressing it.
      The power/battery...
      01-08-2025, 05:45 AM
