Recommend a PSU for Benchtesting Motherboards
  • runner3735
    • Aug 2008
    • 3
    Hi, first post here.
    I know there are plenty of great sites testing PSU's, but they naturally have in mind using the PSU for what it was intended, namely being part of a fully functioning PC.
    I've been testing a bunch of motherboards lately, and would like to know of some recommended PSU's for the task.
    1) Of course, I need one that doesn't have a minimum load....sometimes for diagnostic purposes, I need to try to power on the motherboard without even RAM and CPU! I need to know that the symptoms I see are fully a problem with the motherboard and not with with the PSU.
    2) It doesn't need to be very powerful, I would think. After all, this testing is generally done with no hard drives, and a simple video card, and for short durations. The CPU is rarely under load...basically whatever it uses for poking around the BIOS or flashing the BIOS from a floppy or USB drive.
    3) It needs to be resilient. It may be hooked up to a bad motherboard every once in a while. I have no idea what the ramifications of that may be, but from reading here it seems that a high quality PSU will not be damaged, whatever nasty MB's might be attached to it.
    4) it needs to be compatible with lots of motherboards. It needs the 8-pin CPU connector, for instance, and shouldn't have odd incompatibility bugs like certain Antec PSU's had with certain Asus MB's.
    5) It doesn't need to be quiet. It's for short duration sessions. Quiet is nice, but not important.
    All that being said, I'm looking at jumping on a Corsair VX450W. If it's not good for benchtesting, then I have other uses for it, but if someone wants to comment specifically on the VX450W for this purpose, then I'd happily welcome the info.
  • acstech
    GrumpyModerator
    • Jul 2007
    • 1432
    Re: Recommend a PSU for Benchtesting Motherboards
    I use these, both for testing and in computer builds:
    http://www.hypermicro.com/itemdesc.asp?ic=PSAB001
    They come from a Sun Microsystems workstation (probably surplus), and have all your protections built in AFAIK. They're built like a brick ****house. Voltage on the rails is very well regulated too. Double layer PCB's, copper heat distribution plates, etc. It does use some OST caps, but I doubt those will cause a problem in this particular unit. And you can't beat the price.
    On some motherboards you do need to modify the P4 power connector. It somes with the 8 pin EPS connector. A bandsaw with a thin blade will cut that apart nicely if you're careful, then you can use them with any computer. Also be aware it does not have a PCI-E connector, so don't plan on using it with a high performance video card. I have soldered in a PCI-E connector though, and there are empty spots on the PCB.
    But if you don't want the extra work to make one of those work, I'm sure the VX450 would be fine. Although I'd buy a Seasonic.
    A man convinced against his will is of the same opinion still.
    • gdement
      • Jan 2007
      • 690
      I'm not sure what to make of those Acbels. I bought a couple and the one I tried lost the 3.3v rail in about a week. The other unit makes the same scratching noises the first one did, but I haven't left it running long enough to watch it die yet. They give an impression of being well built but mine didn't last. I assume they're good for boards that rely heavily on the 12V lines, but as far as I can tell they can't handle boards that use other rails. It's probably a good PSU but definitely not universal.
      For older boards, I've had good luck with ebay lots of used PSUs. My last purchase was 4x 300W Fortron power supplies which work great, and I only paid about $30-$35 for all 4 of them. I think most buyers on ebay don't recognize the value of certain brands, and they tend to ignore stuff with lower wattage ratings. So if you find the right lot you can expect to buy it pretty cheap.
      There was an inexpensive HiPro 300W at newegg that I also found was pretty good, but last I checked I think they had raised the price on them. It was funny reading all the reviews from people who bought it as a temp while they sent their Antecs in for repair. They seemed to be caught off guard that it works as well as it does, and were unwilling to give it too much praise just because it was cheap.
      Regardless of PSU, get an extension adapter (20+4 preferably). Cut the locking clip off the extension so it's easier to unplug from the board. Using an extension protects the original connector from too much repeated abuse. If you need to adapt an 8-pin EPS to 4-pin, just get (or make) a 4-pin extension and plug the 8pin into that. Even if the PSU already has a 4-pin, an extension is still a good idea.
      • yanz
        • Nov 2004
        • 910
        I think that corsair will be fine. For benchtesting, i use silverstone psus (strider). They are cheap and relatively good quality. To eliminate the minimum load problem, i always use dummy load such this:
        so the minimum load wouldn't be a problem and i can use any decent psus (silverstone, fsp, etc) for benchtesting..
        • acstech
          GrumpyModerator
          • Jul 2007
          • 1432
          Really! I've used at least 8 of them in various builds and as replacements, without a single issue. I'll keep an eye on them though.
          • runner3735
            • Aug 2008
            • 3
            Well, I grabbed an AcBel 530W 80Plus Certified Power Supply, Model FS7013. It was meant for a Sun Ultra 24 Workstation. I really couldn't find much info on it at all, but I got it for a really great price. Google search only brings up 9 hits! Best one is:
            http://www.memoryxsun.com/3002132.html
            Anyway, it looks like it has all kinds of funny connectors on it, but maybe that will be okay. As soon as I receive it, I'm going to crack it open and see what caps it uses
            I sure wish someone would comment on the minimum load requirement. I don't know that I would recognize a minimum load problem if I experienced one. And do too-low loads put undue stress on the PSU or MB?
            • kc8adu
              • Nov 2003
              • 8832
              • U.S.A!
              $498.98?
              is it solid gold??????????????
              • runner3735
                • Aug 2008
                • 3
                My god, yanz, what is that? Thanks for the pics...looks like you can hook it up and load your 12v and 5v...but what about 3.3v?
                @kc8adu...don't worry, I paid less than $30 for mine, and it's supposedly in new condition!
                • yanz
                  • Nov 2004
                  • 910
                  yea they are each for 12v and 5v load, bout 15-20W each (~30W total, iirc...)
                  i never found problems with too low load on 3.3v, im not sure why.. with too low load on 12v and 5v there could be anomaly in voltage rail output, but with 3.3v, never...
                  • gdement
                    • Jan 2007
                    • 690
                    It's possible I just had a lemon, but the fact that the 2nd one makes the same strange noise when I plug it in makes me afraid to use it. FWIW the board that the first one died on was an ABit AN7 (late nForce2). I replaced it with a 300W and it's been running fine for > 6 months, so I'm pretty sure the board isn't abusive.
                    If yours have been running for a long time then they're probably fine. Mine died pretty quickly.
                    • acstech
                      GrumpyModerator
                      • Jul 2007
                      • 1432
                      Well let me see here:
                      A few are used in systems with Biostar Tforce 7025 boards and dual core processors, some having been operated for at least 6 months.
                      One is in a system with a Biostar TP35D2-A7 with a very overclocked E2180 and a 9600GT. Working fine after about 3 to 4 months.
                      One is in a system with an Abit NF7-M. That one's A-OK after a few months.
                      Then there are several that I can't seem to remember now.
                      So it's not like I don't have time on them. I don't know what the problem was with yours, but the ones I use work great. Are you getting them through Hypermicro?
                      • gdement
                        • Jan 2007
                        • 690
                        I'd probably try one again for newer boards like the above. They presumably are heavy on 12v, which is what the AcBels seem ideal for.
                        After the failure, I noticed the 3.3v amperage rating is pretty low, but still it shouldn't have died like it did. The PSU that replaced it is only rated slightly higher on 3.3v, and it was a pretty basic set of components. I can't believe I was pushing it.
                        That board is probably not much different from the AN7. So it's encouraging to know it's working for you on that board. Mine gradually dropped voltage on 3.3v until it started to spontaneously reset about a week later. It was the only board that PSU ever saw.
                        Yes, I got mine from hypermicro. The bad one is still good outside of 3.3v, so I could still use it on a board that doesn't have any connection on the 3.3v rail (I've encountered some boards like that). The 2nd one is still basically unused, because I don't have any boards that I expect a different result from and I'm hesitant to risk ruining it.
                        Have you noticed, when you plug in one of your PSUs but don't have much (or any) load on it yet, does it make a periodic buzzing noise? Both of mine do that. The frequency is about 2 buzzes/sec when plugged into the wall by itself, and gets faster when connected to a motherboard in standby. Just curious if that's normal.
                        I should try to record a .WAV of it sometime, but I'm not sure if the mic will pick it up.
                        • acstech
                          GrumpyModerator
                          • Jul 2007
                          • 1432
                          Nope, mine are totally silent.
                          I can't believe these are bad units. Sun Microsystems used them in their Java Workstation W1100z, and W2100z. http://www.sun.com/desktop/workstation/w2100z/index.jsp
                          Then again, maybe those systems didn't use 3.3v?
                          • gdement
                            • Jan 2007
                            • 690
                            I'm putting together a machine for my niece, and ran into something that might explain my problem with those AcBels. I noticed that when I swap my ti4200 video card into her machine, the 3.3V rail dropped to 3.15v. With an old PCI card installed, it's 3.31v. That was on a different PSU (not AcBel), but it demonstrates the point.
                            Seems maybe my ti4200 card guzzles the 3.3v rail. Or maybe they're all like that.
                            I don't yet have any other compatible AGP cards to test, so I don't know if that card is abnormal.
                            • Krankshaft
                              • Jan 2007
                              • 2328
                              Maybe the AC Bels don't have Over Current Protection?
                              If you draw more current than the supply can handle for an extended period it's not if it's when it will fail.
                              Or it could just be a fluke I don't know.
                              • Wizard
                                • Mar 2008
                                • 2296
                                Even a good generic SMPS have a current sensing circuit to trip on overcurrent but steady 60-80% load of rated watt should not have blow out a PSU if done right.
                                Either this current sense circuit is left out or poorly designed.
                                Cheers, Wizard
                                • KenOlson
                                  • Jun 2011
                                  • 81
                                  Hi All,
                                  Am just starting out testing Motherboards so have been searching the forum to find what PSU and other hardware is recommended. Came across this thread.
                                  Question: Would be interested to find out what acstech recommended in post "I use these, both for testing and in computer builds:".the old link http://www.hypermicro.com/index.aspx did not work.
                                  Am also wondering if any new recommendations since original post in 2008?
                                  Ken
                                  • Uranium-235
                                    Comrade Glimmer
                                    • Aug 2007
                                    • 5042
                                    • US
                                    I use a thermaltake tr2 430. it works, never had one die on me in the 5 computers i've used it on, anywhere from a a64 3400+ 939 5 years ago, to a c2d 8500 /w a gtx 260 2 years ago
                                    • PCBONEZ
                                      Grumpy Old Fart
                                      • Aug 2005
                                      • 10661
                                      Originally posted by KenOlson
                                      Hi All,
                                      Ken
                                      For testing I prefer a server based PSU.
                                      They are more robust and you are less likely to smoke it connecting to an AFU mobo.
                                      Also tend to have really long wires.
                                      Mann-Made Global Warming.
                                      - Dr Seuss
                                      • KenOlson
                                        • Jun 2011
                                        • 81
                                        Hi PCBONEZ,
                                        Thanks for the server PSU tip.
                                        Have an old Gateway 2000 NS-7000 Server that the PSU works but have never checked Mfr & Model.
                                        Did search but did not find any info about PSU. Will have to take apart.
                                        Ken
                                          Lenovo ThinkPad T490s + Ethernet Extension Adapter Gen 2 Notebook T Specification for Upgrade or Repair
                                          This specification for the Lenovo ThinkPad T490s + Ethernet Extension Adapter Gen 2 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the T490s + Ethernet Extension Adapter Gen 2 boardview and T490s + Ethernet Extension Adapter Gen 2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum....
                                          09-06-2024, 08:58 AM
                                        • madscientist750
                                          Replacing electrolytic caps by solid caps on old motherboards
                                          by madscientist750
                                          I do have several old pc motherboards which i recapped 10 year ago and some of those caps are bulged now.
                                          I would like to upgrade them using solid capacitors. I do use them for testing and helping some alternative operating systems.
                                          I would like to ask if such an upgrade can be done, what should i have in mind when replacing electrolytic by solid caps and if such thing exist, if there are caps list for old motherboards. I would have to figure out what caps needs each motherboard and then prepare a list to try to ask for them on some electronics stores.
                                          10-19-2025, 06:10 AM
                                        • AJ847.63e
                                          Testing ATX PSUs under load - Does loading the ATX 24 pin also load EPS & PCIE?
                                          by AJ847.63e
                                          Hi Folks,
                                          Just wanted to clear up a misunderstanding of mine (or what I expect is one). Isn't the 12V rail from the 24 pin, EPS and PCIE separated? IE if I put a power resistor on the ATX 12V pin that is not going to load, thus tell me if the EPS or PCIE rails are fine?
                                          I was recently watching ArIs from Hardware Busters video on how to properly test ATX PSUs without using 5 figure Croma substations.
                                          The PCB adapter he used breaks out the 12, 5 and 3.3V pins from the 24 pin and gives you banana plugs to connect to. That is a bit useless is it not? Aren't...
                                          05-06-2025, 10:37 PM
                                        • qwerty99
                                          Xbox 1.6 Motherboards and Polymer Capacitors
                                          by qwerty99
                                          Hello!
                                          I need to change the capacitors on my three original Xboxes.
                                          Two of them are 1.6B revisions and have Hynix RAM, and the other one is a 1.6 with Samsung RAM.
                                          The 1.6 has the infamous Nichicon HM capacitors around the CPU, which have all bulged and started to leak. This Xbox no longer powers on.
                                          The 1.6B revisions have Rubycon MBZ capacitors that all look fine, but I’ll change them in due course. Both of these work fine.
                                          I’ve seen some excellent threads on the forum about replacing/upgrading capacitors, but I can’t...
                                          06-26-2022, 12:53 AM
