need bios dump for IBM 0302-44u
  • naeemshahzad
    • Jan 2015
    • 129
    • uae
    Hi i need bios for IBM Lenovo motherboard is DAGC6CMB8D0 REv: D
    i already try ibm E50 bios display is OK but message in first booting screen battery low and turn off
  • naeemshahzad
    • Jan 2015
    • 129
    • uae
    Re: need bios dump for IBM 0302-44u
    waiting
    • Touqeersiddiqui
      • Dec 2016
      • 19
      • Pakistan
      check it c6c
      • AHmad_Salal
        Need BIOS Dump/ROM for Lenovo Thinkstation p500
        by AHmad_Salal
        Hello all,
        I have a Lenovo Thinkstation P500 that is stuck at post with no display, it happened after I changed the memory timings in bios. I can not clear CMOS using the jumper on the motherboard, also tried re-flashing bios suing a USB stick but it also doesn't work. The only solution that I can think of right now is re-flashing the bios chip using an external programmer but the problem is that I don't have the bios dump of p500 for flashing externally and I don't know the location of bios chip. If someone can provide the bios dump and bios chip location it would be really helpful....
        11-28-2023, 05:28 AM
      • Ahari
        by Ahari
        I...
        08-13-2025, 06:12 AM
      • hyperwood
        [REQUEST] 2MB BIOS Dump for Lenovo NM-E471 Rev 2.0 (Winbond 25Q16JWSIQ Chip)
        by hyperwood
        Hi everyone,
        I’m looking for a 2 MB BIOS dump for a Lenovo IdeaPad 5 16ARH7H / Legion 5 with mainboard NM-E471 Rev. 2.0.
        The BIOS chip is a Winbond W25Q16FW (1.8V, 2MB) and it's completely unresponsive / bricked. I tried recovery via USB but no success. Now I want to reflash it externally using a CH341A programmer.
        I already found 32MB dumps (e.g. from Vinafix and Badcaps), but they are too large for the chip – and the last 2MB in those files are just FF FF FF....
        āœ… What I need:
        • A working 2MB BIOS dump
        • Matching NM-E471 Rev. 2.0, e.g. JY575
        06-25-2025, 02:28 PM
      • Habble7
        I need a BIOS dump for the Samsung S49CG934SU monitor
        by Habble7
        The Samsung S49CG934SU monitor does not power on - no LED indicator activity and no response to power button. However, when 21V power is connected, it immediately draws 0.8A of current with no display output. The motherboard processor gets warm, and there is continuous reading activity from the W25Q128BV BIOS chip.
        Suspected Cause:
        I suspect the BIOS may have been corrupted during a power interruption while updating the firmware. The official website provides firmware updates, but they can only be installed via USB flash drive.
        Troubleshooting Attempts:
        05-22-2025, 07:28 AM
      • Joluvillas
        Lenovo ThinkPad L15 Gen 1 i7 (20U4) Bios and EC dump needed
        by Joluvillas
        Hi all! I was reading on tutorials how to flash a bios to remove password from a bios, and I ended up reading the EC chip instead of the main bios chip, it only gave me a .bin file of 1,024kb, I learned later that that is the EC chip not the main bios chip (I should have read the tutorials here instead before attempting anything, my bad), I went to flash the original backup, the 1,024kb size file into the same chip and laptop is not powering up anymore. I may have screwed the chip or even the motherboard (Hopefully not), I am trying to see if there is a fix before I discard it. I had a couple...
        06-18-2024, 10:35 PM
