Led Backlight Stacking Repair Video
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Here is the Led Stacking aka Flocko-Budm repair for Led backlights. Hope this helps as its easier for people who dont have a hot air station.
    Link to video:
    https://m.youtube.com/watch?v=RxwdC7V5Ue0
    Also before anyone moans, yes the solder I was using had some very nasty flux in it but this was cleaned off properly and even if it wasn't the Tv simply wont last that long for it even to start corroding anything as its a total POS.
  • Malachi
    • Dec 2015
    • 1077
    • Usa
    Re: Led Backlight Stacking Repair Video
    Another good video. My led set for the 50" insignia should arrive Wednesday. I might do this instead of replacing all of them or a whole strip.
    Is the silicone thermal plaster a British thing? I've never heard of it. I wonder if it's what we simply call silicone caulking?
      I use KAPTON tape on top of the old pads just to be sure the new board will not short out the old pads.
      • flocko
        • Nov 2012
        • 1121
        • uk
        Good video, I just remove the old LED with pliers twist off and clean up with a craft knife and use twin-stick tape. What I must point out is always try to use the same style LED and lens that is already fitted to your strip, or you will not get the best result and an even light output. as the LEDs are not all the same some of the big LG Innotek LED/lens run at 6v
        • ReeceyBurger123
          Never Give Up !
          • May 2014
          • 7325
          • Britain
          Cheers think its almost the same, I use it to secure the Led and it can also help transfer heat to the original strip.
          • ReeceyBurger123
            Never Give Up !
            • May 2014
            • 7325
            • Britain
            I seen, lol I ran out of that and sort of find it better to use silicon plaster
            • ReeceyBurger123
              Never Give Up !
              • May 2014
              • 7325
              • Britain
              Cheers Flocko, yeah I know what you mean the Leds you talk of have big lenses but these are the same and the image was fine has been for the others which I have used what ever I had in stock
              • ReeceyBurger123
                Never Give Up !
                • May 2014
                • 7325
                • Britain
                Got a 40" Toshiba Led Tv same fault to do later on or tomorrow, unsure if I will do this method as the Leds in the panel (Ves400) are very close together. Might do a video.
                • Diah
                  • Feb 2013
                  • 6563
                  as its 45 minute i would say its nice movie, not as video.. appreciated it , but this repair method not allowed in EU, you will be charge of fined if owner had issue with it. LED are life circular hours life, and as its original, mean the rest will be blow up soon or later. to me just replace the defect on with new one, and if any other failed later or will be not my response
                  look i had 3 from new strip i used for 3 sets.
                  • ReeceyBurger123
                    Never Give Up !
                    • May 2014
                    • 7325
                    • Britain
                    Cheers Also dont think there are any regs over this type of repair. I have some if them Leds on order from China.
                    • vinceroger69
                      • Mar 2012
                      • 6714
                      • uk
                      Be nice to see if the china leds work, i have saw them advertised but some people say they shine slightly yellow in colour/diffrent brightness i guess its trial and error untill you find the correct ones.
                      • Diah
                        • Feb 2013
                        • 6563
                        TOSHIBA 40 or Philips and most 40 used strip of 4 groups leds in one, led type 7030 6 volts but its easy to replace whole of the strip in one hours with new one by using hand soldering head 0.5mm hear are my replace set
                        • Diah
                          • Feb 2013
                          • 6563
                          so fuuny to read people warning on china made and the TV UNDER THEIR HANDS MADE IN CHINA 90% either mobile lol, PSU 100% all in china
                          • ReeceyBurger123
                            Never Give Up !
                            • May 2014
                            • 7325
                            • Britain
                            Yeah some of them if you dont check carefully (current and reverse voltage wise) the colour rendition is different to the originals and might be slightly noticeable.
                            • ReeceyBurger123
                              Never Give Up !
                              • May 2014
                              • 7325
                              • Britain
                              Its a Vestel with the same Leds as in the video and they are the same voltage etc.
                              • Diah
                                • Feb 2013
                                • 6563
                                but 40th will be not row at back the screen. they are always on left or rightside
                                • ReeceyBurger123
                                  Never Give Up !
                                  • May 2014
                                  • 7325
                                  • Britain
                                  No its not a slimline its a full array type loaded all together.
                                  • Alastair E
                                    Chief Womble
                                    • Mar 2013
                                    • 1963
                                    • U.K.
                                    I tried some of those LEDs....
                                    They made bright Yellow Splodges on the screen--Even though supposed to be 8000k LED's
                                    Completely useless! Got 200 of em--Anyone want 'em!
                                    Gone back to cutting up old strips and sticking in place of originals--'legal' or not!!
                                    --You'll be saying you cant use leaded solder next!....
                                    TELEFIX
                                      I wonder if they are rejected and being sold as good devices.
                                      • ReeceyBurger123
                                        Never Give Up !
                                        • May 2014
                                        • 7325
                                        • Britain
                                        Boost to keep thread up on the lists
                                        • Max514
                                          Samsung UN55H8000 sound but no backlight no video
                                          by Max514
                                          Ok so I have this beautiful un55h8000 samsung tv with sound but no video nor backlight. When turning the set on the red light blinks 5 times.
                                          The screen shows no damage and backlight turns on when I disconnect the power supply from the main board. The tcon board only has 2 out of 3 leds on.
                                          I came across this page and followed the different steps: https://techhometravel.com/samsung-u...ight-no-video/
                                          • Unplugging the main board cable at the power supply >>> backlights came on.
                                          • BLU_ON signal from the
                                          04-14-2022, 10:34 AM
                                        • JaquesPratt
                                          Vizio D32f-E1 Powers on, has backlight, won't boot/no logo, no menu or video
                                          by JaquesPratt
                                          I have a Vizio D32f-E1 LCD TV that does NOT have a TCON board.
                                          This TV recently went through some 'death throes' and now won't boot. The first problem that began to manifest was while watching tv, the screen would 'freeze', and the image would dim over a few seconds until it was very dark. HOWEVER, the audio of the show would continue as normal. I could power off the TV for 5-20 seconds, power back on, and the video would be normal. This would occur 1-3 times when the TV was first started, and would not happen again after the TV was 'warmed up'. Not ideal, but this glitch was manageable....
                                          07-16-2024, 01:04 AM
                                          HP EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera EliteDesk 800 i7-7700 Specification for Upgrade or Repair
                                          This specification for the HP EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera boardview and EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our...
                                          09-12-2024, 02:00 PM
                                        • triplefour
                                          by triplefour
                                          09-13-2023, 10:43 PM
                                        • edugimeno
                                          LG 43UK6300PLB has backlight but no video
                                          by edugimeno
                                          Hi! This TV was ready for the trash so I picked it up before it was thrown away
                                          It's pretty new, so I thought I should give it a try. I plugged it in at home and I was expecting blown backlight as most of the TV's that get to me, but in this case it showed backlight with no video at all (no logo no menu no nothing).
                                          TV seems internally responsive, drives stdby led red when OFF, responds to remote to turn on and off, but gets no image at all
                                          Anything common on these sets to start with?
                                          Thanks!...
                                          03-26-2024, 03:29 AM
