LG 50LA6230 backlight repairs
  • chrismurphy
    • May 2014
    • 251
    • australia
    For everyone
    repaired this TV with faulty LED back-lights
    Removed the panel and diffuser and found one burnt LED
    removed the faulty LED and replaced with 5 diodes (5x .7 drop=3.5)
    tested each string ...all ok
    replaced diffuser and panel . TV now works and the missing LED had no effect on the picture .posted FYI
  • RobbieC
    • Sep 2013
    • 26
    Re: LG 50LA6230 backlight repairs
    I did the same thing but just shorted the LED. There is enough tolerance in the supply to allow for missing individual units (mine also had 8 failed led's too but had failed shorted so didn't take down the string).
    Ideally, long term fix is find suitable drop in repalcements (for one or all led's)
    • chrismurphy
      • May 2014
      • 251
      • australia
      cant short the LED on this one as they are all in series
      • RobbieC
        • Sep 2013
        • 26
        ? afaik all of the strings using in tv's are in series which is why the whole string dies if one goes open circuit. Would be some serious current if in parallel too!
        Shorting only works IF in series
        • chrismurphy
          • May 2014
          • 251
          • australia
          yes my mistake ,replied to quick ,your right
          The only reason i put the diodes in place of the LED is in this set there are two strings of LEDS and i wanted to keep the brightness of the strings as close as i could
          • pni
            Backlight panel diffuser melt by backlight leds broken
            by pni
            Hi guys, I changed my backlight to a 5g in Samsung but the broken leds burned the thick plastic panel . I give the photo. Do you think if I try to rotate the panel, with the botton on the top I have a good image? Becacause now how u can see, on the light color I sse the leds because of the burned on the plastic diffuser....
            10-12-2025, 12:08 AM
          • triplefour
            by triplefour
            09-13-2023, 10:43 PM
          • DanPoka
            Guide me through repairing a Dell p2210f LCD ccfl backlight monitor
            by DanPoka
            I bought this p2210f dell monitor to fix. Schematic is the same as p2210.
            Behaviour is that monitors comes on but then backlight switches off almost instantly. If I look with flashlight I can still find the "No signal message". So definitely a backlight issue. Trying to advance the issue I proved that the protection circuit is switching off the backlight by shorting out C3 and resistor to disable the INL chip then re enable by removing the short.
            This is where it gets interesting. When I disassembled the monitor to solder leads on c3 capacitor I noticed the backlight flickered...
            02-15-2025, 05:05 AM
          • Comp_Pro
            No Backlight Macbook A1990 820-01041
            by Comp_Pro
            Hello all,
            Am trying to figure out this backlight issue with this A1990 Macbook Pro.
            Tests performed:
            There is no backlight even with a good screen.
            Backlight IC is receiving the correct support voltages.
            Fuse F8400 ok
            Current sense resistor R8400 ok
            Backlight IC is receiving 3.3V on enable pin.
            Backlight IC receiving voltage from PPBUS_G3H, aprox 12.5V.
            Backlight IC receiving 5V from PP5V_G3S
            Backlight IC BKLT_SCL and BKLT_SDA both measure 0.545V diode mode to ground
            I2C_BKLT_SCL and I2C_BKLT_SDA both measure...
            05-06-2024, 10:23 PM
          • cheebster
            iPad Pro 12.9 5th Gen Backlight Issue
            by cheebster
            Hello, got an iPad Pro A2378 12.9 5th gen with no backlight. Got another test unit without screen, tested the screen, still no backlight with the test unit.
            Figured out the backlight on the screen was bad, ordred a new backlight from mobilesentrix, *carefully replaced it* without damaging the lcd, oh well.
            Final result, issue is still there, the screen has no back lights. So i'm back to square one, with 3 hours less and 100$ out, issue still on the screen.
            The panel is still ok, i can see the apple in the middle of the screen when it kicks in, just no backlight.
            Anyone...
            05-20-2025, 09:17 AM
