Recapping a DFI nF4 Ultra-D
  • mitchmaster
    • Jan 2016
    • 40
    • Italy
    I have this motherboard that won't post and I have decided to try and fix it. The last time I saw it working must have been Oct/Nov 2014 and when the PC didn't turn on any longer I just blamed it on the PSU because I didn't really care to investigate why it wasn't working.
    Last week I finally did decide to investigate what was wrong and I noticed two bulging caps near an auxiliary power connector, they are KGZ 1500uF 6.3V which I understand are bad. One has the bung popping out also but apparently it didn't leak on the PCB.
    I thought I may as well replace ALL the capacitors while I'm at it in order to avoid future failures but I don't know if it's really necessary so I need a few directions.
    Let's get to it.
    On the board there are 61 electrolytic caps and 8 polymer caps (these are all 560uf 2.5V, brand unknown, A 54J if it rings any bells).
    I'm attaching a few pictures for your viewing pleasure. In one I indicated the values of all the lytics, the original picture (here) is from the Techpowerup review of the board (check it here if you want to see close-up shots of the board) although the PCB revision is different. In the other two pictures you can see the two bad caps.
    The two bad KZG and the other five KZG caps near the ATX connector are going to go, but I would like to know what you guys think of the other caps on the board, if they need replacing or not. I can guess what a certain cap does but I can't really tell where the VRM or other sections begin or end so I need some guidance. And the polymer caps are staying, right?
    If you have any questions or need more info, just ask.
    Thank you
  • Stefan Payne
    • 1267
    Re: Recapping a DFI nF4 Ultra-D
    Replace KZG with polymer caps.
    And the KY can be replaced with 'normal' low ESR caps of equal value...
    Are those Nichicon all HM series?
    HM seems to be equal to NCCs KZG, so it's best to replace them with polys as well.
    Or similar, long life, ultra low ESR caps...
    • ReeceyBurger123
      Never Give Up !
      • May 2014
      • 7325
      • Britain
      Ky should be fine they are UCC's best series IMO but replace all HM & KZG.
      • mitchmaster
        • Jan 2016
        • 40
        • Italy
        Thank you for pointing out that the Nichicon HM are bad, I tought they were good caps
        About replacing them with polys though... I'll look into it but since there are 34 of them that would cost more than the board is worth.
        I know of the half-capacitance rule for replacing lytics with polys when they are in the VRM, but to which capacitors on my board other than the KZG should I apply it? What about that lonely Nichicon 1000/6.3 to the right of the two bust KZG 1500/6.3 in the middle of the board?
        Thank you
        • mariushm
          • May 2011
          • 3799
          HM and HN are good series of capacitors.
          However, there was a small time period around 2002-2004 if I remember correctly when the Nichicon factories used too much electrolytic (or some other substance) inside these series of capacitors which made them failed prematurely.
          Capacitors made after somewhere around April-May 2004 (again, if I remember correctly) from those two series are good.
          If they're failing or failed on motherboard, it's not due to technical faults but due to other reasons (for example whole pc overheating or power supply giving bad quality power to the motherboard.
          There's usually a datecode on the capacitors (4 digits), the first two are the manufacturing week and the other two are the year, that should tell you if you MUST replace the caps, or if you just SHOULD (if you want to replace with polymers)
          Also, HM and HN were discontinued recently by Nichicon but big stores like Digikey should still have some in stock. Nichicon recommends HW series as replacement for the two (and indeed it works well for most cases) but you can use polymers instead if you want.
          KZG series is just bad, it's one of the series that has lowest esr possible, and my guess is the electrolyte inside is of another formula compared to their other series, and this formula wasn't quite stable. They're known to fail even without usage, just by sitting on shelves or in boxes.
          • Stefan Payne
            • 1267
            Still, I'd do every cap I'd come across, just to be safe...
            But the question is what mitchmaster wants to do...
            Does he want to get rid of the 'bad caps' or does he want to do a real capjob??
            • mitchmaster
              • Jan 2016
              • 40
              • Italy
              I'm going to do a real capjob
              I'm planning to replace the KZG caps with polys and all the others with lytics. Going full poly would be too expensive.
              The supplier I chose to buy from (that would be RS) has a lot of stuff but many types of capacitors are sold only in packages of 10 or 25 and up and I don't need that many, so the selection was somewhat reduced. Anyway, these are the caps I have selected for now.
              KZG 1500uF 16V >>> Panasonic OS-CON 1000uF 16V 16SEPF1000M
              KGZ 1500uF 6.3V >>> Nichicon L8 FPCAP 1000uF 6.3V RL80J102MDN1KX
              Nichicon HM 1000uF 6.3V >>> Panasonic FM 1000uF 6.3V EEUFM0J102
              Nichicon HM 470uF 16V >>> NIC Components NSRG 470uF 16V NRSG471M16V10X12.5F
              KY 470uF 6.3V >>> Panasonic FC 470uF 6.3V EEUFC0J471
              KY 1000uF 16V >>> NIC Components NSRG 1000uF 16V NRSG102M16V10X20F
              KY 100uF 25V >>> Rubycon ZLG 100uF 25V 25ZLG100MEFCT16.3X11 (I fear these at 6.3mm diameter are too big, gotta check)
              Are they looking good?
              • mariushm
                • May 2011
                • 3799
                I wouldn't use NIC Components caps. See if you can replace those 470uF 16v with 270-330uF 16v polymers
                You could also do better with the 1000uF 16v selection. You could use 1000uF 16v for the 1000uF 6.3v capacitors as well, if that will allow you to buy a larger pack of same capacitor, just be careful at the distance between leads.
                I don't normally do this because it's a lot of wasting time at the post office but if your problem is the minimum quantity on RS and you have a Paypal account to pay me, I'd be willing to mail you some capacitors from my own personal stock (bought in 2015 from Farnell and Digikey, but i keep them properly stored so no issues).
                I have 100uF 16v Panasonic FR capacitors (5x11mm) or 120uF 50v (8x15mm) to replace your 100uF/25v caps, 470uF/25v Panasonic FM because it's common combination in lcd monitors, but you could use instead of 470/16 as long as they fit (i think 10x12mm , may have some 8x16mm but not sure until i check boxes) and I should have 1000uF 16v Panasonic FM (10x20mm)
                If you're interested let me know, i bought them in large quantity (50-100+) so price would be less than RS, plus maybe about 2$ for postage.
                • mitchmaster
                  • Jan 2016
                  • 40
                  • Italy
                  Thank you for your kind offer but I think I'll just leave the HM and KY caps where they are and replace the KZG.
                  I have found problems with the size of most of the caps I had chosen and buying different types would cost too much. It was already over 30 € with tax and shipping and I don't want to spend even more money on a 10-year old board.
                  I checked the data code on the HM caps and they are all A0520 and A0531, and since I bought this board in November 2005 I assume that 05 is the year and 20 and 31 are the weeks so they should be good.
                  Maybe I'll change them at a later time
                  • ReeceyBurger123
                    Never Give Up !
                    • May 2014
                    • 7325
                    • Britain
                    No REPLACE THE HM ! They are known defective, you will just be fixing it again in a few months times even if they are 2005 +
                    • mitchmaster
                      • Jan 2016
                      • 40
                      • Italy
                      I hear you, I'll look into it and I'll let you know.
                      • mitchmaster
                        • Jan 2016
                        • 40
                        • Italy
                        Okay I'm getting Panasonic FR caps to replace the HM, and I'm keeping the KY caps.
                        • RJARRRPCGP
                          • Jul 2004
                          • 6304
                          The last two being the year is American format, lol. (WW-YY)
                          International format is YY-WW
                          ASRock B550 PG Velocita
                          Ryzen 9 "Vermeer" 5900X
                          Arc A770 16 GB
                          eVGA Supernova G3 750W
                          Alienware AW3423DWF OLED
                          • Stefan Payne
                            • 1267
                            HM seems to be similar to NCC KZG, so you need a similar ultra low ESR series...
                            I think the newer KZE series could be OK, but I'm not sure (and I don't want to take a look at the Datasheets)...
                            You should worry more about ESR than the capacitance of the cap...
                            You probably would be fine with a smaller cap if the ESR is similar...
                              master hoarder
                              • May 2008
                              • 12175
                              • Bulgaria
                              That should work fine.
                              Panasonic FR and FM series are not quite as good as Nichicon HM, but they are reasonably close, especially FM. Not to mention FR and FM have much longer endurance lifetime, so they can take a little more abuse than the HMs. An alternative to FR and FM would be Nichicon HW.
                              However, the closest option (besides getting new Nichicon HM or HN again) would be Rubycon ZLG, or if you don't mind old stock - MBZ. Chemicon has a new series for motherboards too - KZA. But I wouldn't jump on them just yet. They could have the same unstable electrolyte as KZG/KZJ.
                              And yes, leave the Chemicon KY. They are non-aqueous electrolytic caps and extremely stable. Shouldn't need to touch them for another decade or possibly even longer.
                              Chemicon KZE has slightly more inferior specs to both Panasonic FR and FM. It has the same exact specs as Nichicon HD and Rubycon ZL.
                              Disagree here.
                              Nichicon HM caps made after (and including) 2006 are fine. It's the ones between 2001 and 2004 that are *definitely* problematic. With 2005 ones, take out a coin, call heads or tails, and flip it - some have problems and others don't. Same goes for HN and HZ, especially when they sit on a shelf with no voltage applied.
                              • Wester547
                                • Nov 2011
                                • 1268
                                • USA.
                                KZA is described as having the same "super low resistivity" electrolyte as KZG and KZJ and looks to be KZJ's replacement. KZA isn't that new though - went into production around 2008 or 2009.
                                Not really. KY are definitely on the aqueous spectrum, like HE and YXH, they just contain a low amount of H2O (20%-30% probably) in the solution compared to KZE, HD, ZL (40%-50%), and especially compared to MBZ, MCZ, KZG, KZJ, HM, HN, HZ, (70%-75%), etc. H2O yields a much higher conductivity compared to organic liquid electrolyte, although a lower viscosity (and has a much poorer thermal coefficient in terms of capacitance and ESR). I attached a document by Chemi-con that describes the KY series as having "high water contains electrolyte" (or "high aqueous electrolyte") and LXZ as using "conventional electrolyte" (1-2% H2O content, probably using the organic solvent gamma butyrolactone and carboxylic acid as the solution or something similar since they moved away from the notorious quaternary ammonium salt system that caused leaking from the bungs in the 80s and 90s). Furthermore, United Chemi-con describe KY, KZE, KZG, and KZJ in their datasheets as using the same "unique low resistivity" electrolyte which suggests, coupled with the same temperature range (-40C to +105C) that they are all aqueous.
                                Disagree here.
                                I consider any capacitor that regularly bulges in storage without ever having bias applied to the plates or current passed through the solution to be very very bad. That suggests major chemistry issues unless they were overheated or exposed to incompatible cleaning agents. But then again, I don't expect highly aqueous 2,000 hour at 105*C capacitors to last very long under high heat conditions.
                                Those all look like good replacements for those KZGs, and they're all much more reliable than the KZG series.
                                • mitchmaster
                                  • Jan 2016
                                  • 40
                                  • Italy
                                  Thank you for your replies.
                                  I have eventually replaced the caps and now the board is working fine, actually I'm using it right now to type this.
                                  The capjob looks like crap though, my solder sucker is worse than I remembered so I didn't manage to clear many of the holes. In hindsight I should have spent 15€ and get one with a heated tip off Amazon... well maybe I'll fix it someday before retiring the board for good.
                                  Thank you again for your help
                                  • alindumitru46
                                    • Aug 2015
                                    • 255
                                    • Romania
                                    Hi, I read your post with big eyes. I own an Expert version of this motherboard, which now lights up only 3 of 4 LEDs, managing only a few starts.
                                    On the board are three strongly oxidized areas that I tried to clean but not sure if it affects the mobo itself.
                                    I'm thinking of doing a reccaping, but I encountered a strange resistance to latest attempts for desolder some of capacitors, and now I'm afraid to start (too cold pcb, too much Pb in the solder?!).
                                    Effectively the solder is not melted enough to remove so easy the capacitors and release the holes. And I have used a 60W iron and a 150W big iron.
                                    Now I have to think very well if they start such a job because DFI NF4 Ultra-Expert is very sensitive and crowded.
                                    • Dan81
                                      SNES-powered
                                      • Oct 2013
                                      • 1866
                                      • Romania
                                      Try using a gun shaped soldering iron that has a switchable wattage (my dead Kemot 30/130W one did).Those have a better heat transfer.
                                      Oh,and if it helps,use some pliers and your soldering iron in case there's any pin left if a old cap breaks.
                                      Main rig:
                                      Gigabyte B75M-D3H
                                      Core i5-3470 3.60GHz
                                      16GB DDR3-1600
                                      Samsung SH-224AB DVD-RW
                                      Delux MG760 case
                                        master hoarder
                                        • May 2008
                                        • 12175
                                        • Bulgaria
                                        The 60W iron should be more than enough to remove caps from a motherboard.
                                        What you need is flux - either liquid or gel. Standard Rosin or Rosin Mildly Activated (RMA) should both work well. Apply to joints, then hit them with your iron. Make sure your iron's tip has some solder on it as well. A medium-sized blob of solder on the tip will actually help quite a bit.
                                        If unsure what I am talking about, create a new thread in the Equipment sub-forum and post some pictures of the irons you have.
                                          Seasonic B12 BC-550 – barely 2 years old and with BAD CAPS already!
                                          by momaka
                                          I know I've been a little scarce lately (like the last 2-3 years), but I'm still here and still doing my thing with fixing PSUs.
                                          For today's considerations, I have a Seasonic B12 BC-550 [A551bcafh] 550 Watt ATX power supply for you (click on links for full size images).
                                          https://www.badcaps.net/filedata/fetch?id=3591771
                                          https://www.badcaps.net/filedata/fetch?id=3591772
                                          It's a modern ATX unit with fixed (non-modular) cables and an 80-plus bronze certificate. Here's the label:
                                          https://www.badcaps.net/filedata/fetch?id=359177...
                                          03-12-2025, 03:42 PM
                                        • eryjus
                                          Heathkit IO-4205 Power Supply Caps
                                          by eryjus
                                          First, I am a complete noob with high voltage stuff. I'm learning, but I need help by someone looking over my shoulder.
                                          I recently came into posession of a Heathkit IO-4205 5MHz Dual Trace Oscilloscope. The documentation is copyright 1978. I'm told it works.
                                          I opened it up to check the caps before I applied power, and found the following black caps and wanted to know what they were. They are on the power supply board. I was able to read the name and model and came up with, "Nytronics 162J-1, 0.1uF, 20% tolerance, 2000VDC."
                                          05-10-2023, 11:21 AM
                                        • Paxman_Swede
                                          Identifying caps on an old Zoom 9000
                                          by Paxman_Swede
                                          Hello!
                                          I have two projects on my work bench. One is a friends dead JBL Xtreme speaker with a blown voltage regulator and corresponding bulged and shorted cap. That cap has clear markings so I know what replacement I need for it.
                                          The other project however is a whole different deal. It's a Zoom 9000 guitar effect from the 90th that has developed a devil hound howl when there is no input from the guitar. I'm guessing caps problem. So, since I don't really use this effect anymore I thought it would be a perfect project to learn on.
                                          I have studied the board and...
                                          01-14-2025, 09:51 AM
                                        • captain150
                                          Help with switching power supply caps
                                          by captain150
                                          I'm trying to repair two old VCRs, they both have bad caps. One has leaky ones, the other would barely run until I subbed in some caps from another power supply I had laying around (though they are the wrong values). This vcr works for an hour or two, but then the power supply starts whining and the picture gets lines in it. I didn't replace all the secondary caps, so another voltage might still be problematic, or the values I used are too far off.
                                          I've been on mouser and digikey but the options are a bit overwhelming. I just need some new ones that will work. They don't need to be top quality,...
                                          03-16-2025, 07:34 PM
                                        • Foetuss
                                          Gigabyte GA-6OXT :: caps question
                                          by Foetuss
                                          Good evening
                                          I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
                                          Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
                                          But I was also suprised about the bigger boys, which are 330µF 25V.
                                          Could it be they used 25V caps because they were cheaper / available at that time?...
                                          02-11-2025, 12:22 PM
