LG 50PJ550 Clicking
  • sordids999
    • May 2013
    • 2152
    • uk
    LG 50PJ550 Clicking
    hello
    got another tv im trying to fix with just a clicking fault i will upload more pictures soon
    i have so far tested the follwoing
    1. two 5W22 ohms resistors but they are good
    2. D304 is showing as shorted in circuit but ok when out of circuit
    3. No Vs or Va from the power supply even with the Ysus and Zsus disconnected
    any ideas how to test this part which is a common failure on these power supplys 3BR1565JF Regulator
    thanks
  • Hamie
    • Apr 2014
    • 1383
    Re: LG 50PJ550 Clicking
    Pin 5 is ground, so put black probe on pin 5 and touch the other pins with red probe.
    If any are shorted to ground then it's certainly bad.
    • sordids999
      • May 2013
      • 2152
      • uk
      Thankyou ill check now
      • ReeceyBurger123
        Never Give Up !
        • May 2014
        • 7325
        • Britain
        Link to repair kit:
        http://www.ebay.co.uk/itm/LG-Power-R...-/131027150307
        I had one and that Ic was failed however it never blew the fuse. Also the control circuit for that Ic is also prone to failure on these, will find the kit for that.
        • sordids999
          • May 2013
          • 2152
          • uk
          Thanks Hamie its shorted
          i have ordered 3BR1565JF Regulator and a replacement diode ill change that and see how i get on
          @reecey yes i have seen in further posts that IC701 can be faulty as well but ill try this first then move on if not
          thanks guys
          • ReeceyBurger123
            Never Give Up !
            • May 2014
            • 7325
            • Britain
            No worries let us know how its goes
            • retiredcaps
              • Apr 2010
              • 9271
              The mark up on these kits are high. Kit for the same auction above is $25 CDN (with current exchange rates).
              Aliexpress sells the IC for as low as $1.22 USD + free s/h ($1.64 CDN).
              http://www.aliexpress.com/item/Origi...488431640.html
              or 5 (Five) for $2.91 USD + free ship.
              For those doing a lot of repairs, you might as well order 5 them well in advance so you don't have to wait 30 days for shipping from China.
              10 x 22 ohm 5W resistors also sell for $2.29 USD + free ship.
              So, through aliexpress, I can get probably 10x of everything for less than the price of one kit on ebay.
              --- begin sig file ---
              --- end sig file ---
              • sordids999
                • May 2013
                • 2152
                • uk
                changed 3BR1565JF Regulator and a replacement diode but still the same as before clicking so maybe IC701 is faulty
                • ReeceyBurger123
                  Never Give Up !
                  • May 2014
                  • 7325
                  • Britain
                  Possibly does seem common on these,
                  • sordids999
                    • May 2013
                    • 2152
                    • uk
                    can anyone point me into the right direction to test patterns or maybe jump the main board
                    Legend pins on Psu are as follows
                    17V 17V
                    GND GND
                    5.1V 5.1V
                    ERR_DET 5.1V
                    GND GND
                    GND GND
                    STBY STBY
                    AC_DET RL_ON
                    AUTO_GND M_ON
                    • Hamie
                      • Apr 2014
                      • 1383
                      What voltage do you get on RL-ON?
                      • sordids999
                        • May 2013
                        • 2152
                        • uk
                        4.14 Volts
                        • Hamie
                          • Apr 2014
                          • 1383
                          RL-ON to ground.
                          Vs ON to 5v stby.
                          Give that a try.
                          • sordids999
                            • May 2013
                            • 2152
                            • uk
                            Originally posted by Hamie
                            RL-ON to ground.
                            Vs ON to 5v stby.
                            Give that a try.
                            hi hamie do you mean jumping
                            RL-ON to ground and M-ON to 5v stby ?
                            • Hamie
                              • Apr 2014
                              • 1383
                              You sure you've measured your voltages right?
                              I have a working board for this model, if the mainboard is unplugged RL-ON is 0v
                              Ac-detect, the pin opposite it, is close to the voltage you have stated you have RL-ON.
                              • sordids999
                                • May 2013
                                • 2152
                                • uk
                                Sorry Hamie your right i was measuring the legend wrong with main board unplugged RL-ON is reading 0 volts but with main board plugged in then the tv clicks RL-ON is reading 3.9 volts then drops to 0 Volts
                                • Hamie
                                  • Apr 2014
                                  • 1383
                                  ok I've jumped my board on and it's RL-ON to 5v stby.
                                  all voltages came up.
                                  • sordids999
                                    • May 2013
                                    • 2152
                                    • uk
                                    jumped RL-ON to 5v no voltages came up just one click
                                    • sordids999
                                      • May 2013
                                      • 2152
                                      • uk
                                      its strange because 3BR1565JF Regulator is showing as shorted again and the diode as well but i know if i remove the diode out of circuit its fine
                                      • flocko
                                        • Nov 2012
                                        • 1121
                                        • uk
                                        put in a new 3BR regulator and replace IC 701 also check on the back of the board there is a string of SMD resistor head to tail (in series )just by the IC about 11or 12 of them,I have had problems with these in the past, worth a look Flocko
                                        • Alimash
                                          op amp circuit function?
                                          by Alimash
                                          I am repairing a ups which doesn't turn on ,it has the following ICs:
                                          SG3525 used to drive inverter mosfets.
                                          couple of uc3483, one for the power supply and another to drive a big mosfet at the output stage(i think the technique is called boost)
                                          A LM358 and TL074 for control mechanism and of course the uController.
                                          The SG3525 is shutting down every time the ups is turned on.
                                          I want your help to know the function of LM358 and TL074 in the system.
                                          I reverse engineered the LM358 circuit and i think that one of the block(A) is used for battery level...
                                          07-31-2025, 07:45 AM
                                        • Astonished
                                          Fixing the Charge Circuit of the Batteries of the DC Motor
                                          by Astonished
                                          Hi friends of electronics
                                          What you see in the video and pictures attached is the circuit for charging the batteries of a DC motor.
                                          The problem is that this circuit cannot charge the batteries (3 1800mAH NiMH batteries) any more. When the circuit was OK, its green LEDs lit up one at a time to show that the batteries have charged more. But now that the circuit is flawed, LEDs light up as you see in the video and at the same time successive beeps are heard.
                                          Please help me fix this circuit.
                                          (the datasheet of the IC: https://pdf.datasheet.live/28...
                                          01-28-2025, 06:24 AM
                                        • rddube
                                          Lenovo L490 Ram voltage circuit malfunction
                                          by rddube
                                          Hello friends,
                                          Looking for some guidance here. The RAM voltage circuit on this motherboard keeps burning out PU301 which is a RT8231AGQW. Copy of the board with the burnt chip attached with some voltage measurements and copy of the schematics also included.
                                          I think I've checked almost every component in the circuit, but when I change the RT8231, the laptop starts I have 1.2V on the inductor for about 10 seconds and then the RT8231 goes south and no more voltage on the inductor. All other voltages on the laptop are good, this is the only one conking out for a reason I...
                                          07-15-2025, 04:41 PM
                                        • Tarot Superstars
                                          Short Circuit tester
                                          by Tarot Superstars
                                          Hello.
                                          I have seen a short circuit tester made with 3 * 9V batteries, a voltage limiter component and a resistor connected to the probes of a multimeter.
                                          The theory is that the meter becomes sensitive enough to read very low resistances and the lowest resistance to ground on a circuit is likely to be a short circuit in that area.
                                          Link
                                          The Amazing $1 Short Finder Upgraded! Convert ... - YouTube
                                          https://www.youtube.com/watch?v=0eixDdCpiO4
                                          My multimeter isn't normally sensitive to very small resistance, but when I put a 1 mega ohm resistor...
                                          09-25-2023, 09:11 AM
                                        • M1NEBLANK SHOW
                                          MSI B250 Gaming M3 Short circuit in CPU power supply circuit
                                          by M1NEBLANK SHOW
                                          Hello. MSI B250 Gaming M3 board, short-circuit on the power supply. Found a problematic mosfet VQ1
                                          (N-PK616BA_PDFN8-HF) soldered it out - short circuit is gone. I replaced VQ1 + VQ5 (N-PK632BA_PDFN8-HF). VQ1 was replaced with PK618. After starting attempt VQ1 is lit again. What can be the problem? In the driver?
                                          Schematic and Boardview here
                                          04-04-2025, 03:57 PM
