LG 50PJ550 Clicking
  • sordids999
    replied
    Re: LG 50PJ550 Clicking
    ok cleaned like Flocko suggested all working again no white line ill keep monitoring this although the panel has image burn
    thanks
  • sordids999
    replied
    Ah that might explain it flocko I had a few black lines when I Resinstalled buffers but sorted that by finding a few ribbons out of line so fixed this but a few days later the white line appeared I'll look again
  • flocko
    replied
    Hi Lee check Y buffer ribbon that lines up with it and give it a good clean,it could be Y buffer but would normally show as a dark line.but could be on its way out?
  • sordids999
    replied
    The TV is still working fine but started to develop a faint white line going across the screen I know when I fixed it the to had a bit of image burn
    So do you think it's the panel ?
  • ReeceyBurger123
    replied
    Nice one
  • sordids999
    replied
    Originally posted by flocko
    Well done Lee, did you upgrade to the ICE3BR1065JF current mode controller. I fit these now in all my power board repairs, LG and Samsung
    yes mate thanks
  • flocko
    replied
  • sordids999
    replied
    Update:::
    Replaced all parts as described by Flocko and tv up and working now
  • flocko
    replied
    The SMD resistor 680K (4) 620K(1) and 560K(1) IC 701 MC81F4316 and use 3BR1065JF gives it more head room, and is the same as used on Samsung power boards so always at hand
  • sordids999
    replied
    https://KIT363 EAY60968701 EAX613971...on=ViewProductThanks flocko was going to try this kit
  • flocko
    replied
    put in a new 3BR regulator and replace IC 701 also check on the back of the board there is a string of SMD resistor head to tail (in series )just by the IC about 11or 12 of them,I have had problems with these in the past, worth a look Flocko
  • sordids999
    replied
    its strange because 3BR1565JF Regulator is showing as shorted again and the diode as well but i know if i remove the diode out of circuit its fine
  • sordids999
    replied
    Originally posted by Hamie
    ok I've jumped my board on and it's RL-ON to 5v stby.
    all voltages came up.
    jumped RL-ON to 5v no voltages came up just one click
  • Hamie
    replied
  • sordids999
    replied
    Sorry Hamie your right i was measuring the legend wrong with main board unplugged RL-ON is reading 0 volts but with main board plugged in then the tv clicks RL-ON is reading 3.9 volts then drops to 0 Volts
  • Hamie
    replied
    You sure you've measured your voltages right?
    I have a working board for this model, if the mainboard is unplugged RL-ON is 0v
    Ac-detect, the pin opposite it, is close to the voltage you have stated you have RL-ON.
  • sordids999
    replied
    RL-ON to ground.
    Vs ON to 5v stby.
    Give that a try.
    hi hamie do you mean jumping
    RL-ON to ground and M-ON to 5v stby ?
  • Hamie
    replied
    RL-ON to ground.
    Vs ON to 5v stby.
    Give that a try.
  • sordids999
    replied
    4.14 Volts
  • Hamie
    replied
    What voltage do you get on RL-ON?
  • Astonished
    Fixing the Charge Circuit of the Batteries of the DC Motor
    by Astonished
    Hi friends of electronics
    What you see in the video and pictures attached is the circuit for charging the batteries of a DC motor.
    The problem is that this circuit cannot charge the batteries (3 1800mAH NiMH batteries) any more. When the circuit was OK, its green LEDs lit up one at a time to show that the batteries have charged more. But now that the circuit is flawed, LEDs light up as you see in the video and at the same time successive beeps are heard.
    Please help me fix this circuit.
    (the datasheet of the IC: https://pdf.datasheet.live/28...
    01-28-2025, 06:24 AM
  • Tarot Superstars
    Short Circuit tester
    by Tarot Superstars
    Hello.
    I have seen a short circuit tester made with 3 * 9V batteries, a voltage limiter component and a resistor connected to the probes of a multimeter.
    The theory is that the meter becomes sensitive enough to read very low resistances and the lowest resistance to ground on a circuit is likely to be a short circuit in that area.
    Link
    The Amazing $1 Short Finder Upgraded! Convert ... - YouTube
    https://www.youtube.com/watch?v=0eixDdCpiO4
    My multimeter isn't normally sensitive to very small resistance, but when I put a 1 mega ohm resistor...
    09-25-2023, 09:11 AM
  • Alimash
    op amp circuit function?
    by Alimash
    I am repairing a ups which doesn't turn on ,it has the following ICs:
    SG3525 used to drive inverter mosfets.
    couple of uc3483, one for the power supply and another to drive a big mosfet at the output stage(i think the technique is called boost)
    A LM358 and TL074 for control mechanism and of course the uController.
    The SG3525 is shutting down every time the ups is turned on.
    I want your help to know the function of LM358 and TL074 in the system.
    I reverse engineered the LM358 circuit and i think that one of the block(A) is used for battery level...
    07-31-2025, 07:45 AM
  • M1NEBLANK SHOW
    MSI B250 Gaming M3 Short circuit in CPU power supply circuit
    by M1NEBLANK SHOW
    Hello. MSI B250 Gaming M3 board, short-circuit on the power supply. Found a problematic mosfet VQ1
    (N-PK616BA_PDFN8-HF) soldered it out - short circuit is gone. I replaced VQ1 + VQ5 (N-PK632BA_PDFN8-HF). VQ1 was replaced with PK618. After starting attempt VQ1 is lit again. What can be the problem? In the driver?
    Schematic and Boardview here
    04-04-2025, 03:57 PM
  • прямо
    Viper22A 5VSB circuit
    by прямо
    So I have a cheap non working ATX PSU that I was learning to repair a decade ago. At the time, it blew the main fuse, bridger rectifier, NTC, and primary 9A 900V MOSFET. Replaced all except the MOSFET. 5VSB came back online. Then I poked around in it so much, measuring components one by one to a point I accidentally made the 5VSB circuit primary side went bang. Blown the AP8022 (Viper22A) PWM chip, along with a low resistance resistor and the PC817 opto isolator. I replaced them all.
    In the process of poking around, I also lost a zener diode that stabilize the voltage coming from...
    01-13-2024, 07:05 PM
