Corsair CX400W 5vsb goes into safety loop
  • Per Hansson
    • Jul 2005
    • 5895
    • Sweden
    Hi, I have a Corsair CX400W that has been in use for a few years.
    Recently I had to replace it because the owner complained that his PC would shut off for no apparent reason (It has a UPS too...)
    To make a long story short the PSU is finally here at me now and disassembled.
    There seems to be no problem to rectify the AC, I have a constant 330VDC on the main filter capacitor.
    The 5vsb is generated by a Fairchild FSQ0165 which has just Q0165R printed on top of it.
    If I plug it in I get a nice and stable 5v output, but after a couple of minutes with a small load it goes into a safety loop: shutting down the output and then trying to restart it.
    It does this if I plug in a PC too, it runs for a minute or two and then shuts down, at which stage 5vsb pulses all lights on the mainboard as it tries to restart...
    I replaced all electrolytic capacitors in the 5vsb section but it made no difference.
    I also replaced diode D101 for a UF1007 even though it measured good, with no difference, I replaced it because the soldering on the back looked bad.
    All the other diodes and zener diodes in the area measure good in circuit.
    Between VCC and GND sits a 100uF 50v Suncon WX cap now, it was a 100uF 25v OST RLS before.
    The voltage on this cap starts off at 16v but rises slowly to 18v at which stage the IC goes into it's safety loop.
    The optocoupler has around 2 > 3v on the primary side depending on load.
    On the secondary side was a 3300uF 10v OST RLX that I replaced with a 6.3v Rubycon MBZ
    And finally a 16v 220uF OST RLS right on the 5vsb output cable that got replaced with a Rubycon ZLH 220uF 16v.
    Once the chip is in the safety loop it's enough to remove the load for it to be able to stabilize the 5vsb again, but if I don't it seems to be stuck there forever.
    I also noticed that if I'm probing the feedback signal on the optocpupler it seems to not enter the safety loop as quickly.
    But if it "should have" then it's enough that I remove my probes from the feedback pins and it will enter the safety loop instantly.
    It's worth noting that with no load I see around 720vdc between drain and ground, but with a load this goes down to a more sensible 600vdc.
    Is not this too high, the datasheet says max 650v for the drain?
    Any ideas what more I can check?
    • 31020
    Re: Corsair CX400W 5vsb goes into safety loop
    is the output rectifier D121?
    and what's that stain on the ceramic disc behind the chip?
    • Per Hansson
      • Jul 2005
      • 5895
      • Sweden
      Yes, D121 is a Fairchild SB540 Schottky Rectifier.
      It takes the "AC" from the transformer and turns it into 5vdc
      My meter manages to read ca 0.5Mhz switching frequency and 3.3vac on the transformer, no idea if it's a true reading or it's just getting fooled.
      It goes bananas if I don't have a load, probably frequency out of range
      As for the ceramic capacitor I think it's just some strange artifact in the photo, I can't see it myself if I look at it with a magnifying glass...
      • ReeceyBurger123
        Never Give Up !
        • May 2014
        • 7325
        • Britain
        Think this is what Stj meant Per ???
        • Per Hansson
          • Jul 2005
          • 5895
          • Sweden
          Yes and what I replied was that I think it's just some strange artifact in the photo.
          I took a new picture of it, and also the optocoupler which had a small mark.
          But that on the other hand looks to be just a "QC" mark done with a marker pencil...
            • 31020
            the reason i mentioned d121 is maybe it's breaking down under load - i'v had that on a psu once.
            had to find it with freezer spray!
            • Per Hansson
              • Jul 2005
              • 5895
              • Sweden
              Thanks for the idea stj, I replaced the 5AH Schottky with a 3AH stolen from this PSU but unfortunately it made no difference.
              That is 5vsb worked fine for a few minutes and then went into safe mode again.
              It's a little annoying how they have grouped the safety conditions into the same trip point.
              It's not exactly easy to figure out what is causing it to trip that way
                • 31020
                maybe swap the opto-isolator next.
                • Per Hansson
                  • Jul 2005
                  • 5895
                  • Sweden
                  Just did, found an exact match in this disaster of a PSU.
                  No go though, 5vsb worked fine for a few minutes and then went into safe mode again just like before.
                  I'm stuck on still thinking this is wrong, could it be that Zener diode ZD102 is not doing it's job?
                  From what I can see it seems to have E150A written on it, so 150v Zener?
                  Don't think I have anything to replace it with though.
                  • Per Hansson
                    • Jul 2005
                    • 5895
                    • Sweden
                    I replaced the Fairchild FSQ0165 5vsb chip and the PSU is now able to handle a load a little longer than before, but it's not close to fixed.
                    Probably the new FSQ0165 just has a bit different tolerances for when it goes into it's safe mode...
                    So I would like to continue my original plan, I took out ZD102 which I suspected in my previous posts, it's marked: P6KE150A so it's actually a TVS diode...
                    But on the backside are more Zener diodes which I have no idea what their ratings are: ZD103 & ZD101
                    And while I'm at it it might also be a good idea to check D102 & D103
                    So does anyone have a schematic for the 5vsb in this PSU?
                    It's a Seasonic S12-II platform...
                    • Behemot
                      • 4845
                      • CZ
                      Corsair CX Seasonic? No way, that's CWT. It's a long shot, but I can only think about asking Jon, maybe he'll get at least the information about what parts those are from some enginner. Don't think they'd send you full schematic…
                      • Per Hansson
                        • Jul 2005
                        • 5895
                        • Sweden
                        CWT? No way, this looks very much like a Seasonic to me.
                        I'll give Jon a ping and see if he is able to help, thanks for the idea.
                        http://www.hardwaresecrets.com/corsa...supply-review/
                        "Like most power supplies from Corsair, CX400W is manufactured by Seasonic"
                        http://www.bit-tech.net/hardware/psu...w-psu-review/4
                        "Underneath the soldering quality is also excellent - it's very neat with no large blobs (just as we'd expect from Seasonic)."
                        http://www.anandtech.com/show/2697/8
                        "The inside reveals a typical Seasonic design"
                        http://www.x86-secret.com/dossier-36...400_Watts.html
                        La majorité des alimentations Corsair sont conçues autour d'une base Seasonic. La première chose à faire était donc de vérifier de quelle plateforme est issue la CX400. Un simple coup d'œil à l'architecture interne ne laisse planer aucun doute: Cette alimentation repose donc elle-aussi sur la même base que les autres modèles haut de gamme de Corsair, c'est-à-dire la Seasonic S12-II.
                        • Behemot
                          • 4845
                          • CZ
                          Oh yeah, it's the 400W version, the only one made by Seasonic…I can see that now.
                          Than it's classic OEM version of S12II…those are quite common but I don't know if anybody made or got any drawing of that…
                          • fzabkar
                            • Mar 2009
                            • 772
                            Is the 5VSB output stable and ripple free all the time? If so, then ISTM that the IC, optocoupler, TL431, etc are all doing their job. However, the fact that the auxiliary supply is slowly climbing from 16V to 18V suggests that the IC is gradually driving harder and harder to compensate for an overload on the transformer windings.
                            Is there an 18V zener on the VCC pin? Is the IC shutting down because its OVP sync pin is being triggered?
                            To me the problem looks like a leaky rectifier or filter capacitor on the 5VSB output, but both components have been replaced. ??? Ideally the 5VSB and VCC outputs should track each other according to the turns ratio. Perhaps it would be an idea to interpose an 0.1 ohm sense resistor in the output and monitor the current.
                            • Per Hansson
                              • Jul 2005
                              • 5895
                              • Sweden
                              Thanks for your post fzabkar, yes this PSU has turned out difficult to troubleshoot.
                              Unfortunately I don't have a scope, but according to my multimeter the 5vsb is stable as a rock.
                              The testing equipment I run from it before it goes into the safety reboot loop also has no problems, so it would imply that it infact is stable.
                              Yea I think that Zener diode ZD103 is a 18v Zener, it sits between VCC & GND and would be a sensible rating since the FSQ0165 is rated for max 20v on the VCC pin.
                              It's also sensible from the perspective that this is the voltage I read before the thing goes into the safety loop...
                              Actually with the new FSQ0165 VCC can go up to 18.2v now before the unit shuts down.
                              There is also a 100ohm resistor here so the voltage on the FSQ0165 is slightly lower at 16.9v, the Zener diode sits on this side of the resistor too so that's what it sees as well.
                              The other SMD Zener diode ZD101 I'm not sure about, but it sits on the feedback signal which is rated for up to 9v so I guess it's sensible that's what it's rated for.
                              As for the TVS diode marked ZD102 on the topside I left that out now for a test, since a big leakage here would case problems since it sits between drain and B+ from the main bulk capacitor, but it made no difference at all.
                              (The unit also did not blow up and continued working as before so the problem was not here )
                              I have not connected a sense resistor but I do have a quite accurate power meter to measure the load of the whole PSU.
                              With nothing connected it shows 0.0w draw.
                              With a small ~0.4w lightbulb for load it shows 0.4w.
                              With the lightbulb and a small fiberswitch it shows 3.0w draw.
                              All of this is sensible because the devices by themselves do draw that amount of power if measured using a DMM in series...
                              The 5vsb is rated for up to 2.5Ah or 12.5W according to the power rating plate provided on the PSU by Corsair so we are not even close to actually overloading anything...
                                • 31020
                                so the power for the chip passes through a resistor, then has a zener across it to ground?
                                that sounds like a shit attempt at a voltage regulator to me!
                                • CapLeaker
                                  Leaking Member
                                  • Dec 2014
                                  • 8158
                                  Had a PSU a while back that would work for a while, then shut down. One of the voltage rails was jumping up and down after running a while, then shut off. Traced it to a couple of inductors that I had to desolder, take out, clean the through hole and resolder it. Works fine as kinds now. I finally found the problem by watching the voltage rails and using my hot air soldering station, heating up the inductors.
                                  • Per Hansson
                                    • Jul 2005
                                    • 5895
                                    • Sweden
                                    stj: no the zener is a protection device.
                                    The Zener will only conduct if the voltage crosses the breakdown voltage, which most likely is around 18v.
                                    Thus protecting the FSQ0165 from too high a voltage (it's rated for max 20v on the VCC pin)
                                    I have attached an annoted version of my picture above, it's the closest thing to a schematic so far
                                    The two diodes in the top: D102 & D103 are marked "A1 W73" on their casings.
                                      • 31020
                                      if there is a resistor between the source and zener it wont protect the chip.
                                      the zener will conduct, but because of the resistor it wont produce enough of a load to shut the source down.
                                      so it will just keep conducting till it burns out.
                                      if it was a safety device it would drive the base of an scr to short the supply - a crowbar circuit.
                                      when you find one after a resistor it's often intended as a dirt cheap voltage regulation circuit.
                                      so what is the source of the original supply voltage?
                                      • Per Hansson
                                        • Jul 2005
                                        • 5895
                                        • Sweden
                                        Ok, it serves another purpose too, during startup the FSQ0165 has an internal switch that takes power from the bulk capacitor and charges the VCC voltage up to 12v.
                                        If this where to fail internally I guess we would be conducting 325VDC here so then it works as a safety device for that as well, though there is a resistor on this side too.
                                        In any case when that is done the switch closes and the device is powered from the transformer.
                                        But seeing as this is high frequency pulsed DC I can't tell you what the voltage is on the other side of the diode (D103) because my meters can't get a reliable reading at this frequency.
                                        But obviously since we have a stable supply after the diode it's somewhere in the range of 20V
                                        My UNI-T meter says it's around 0.2 > 0.5Mhz and the voltage varies depending on load, but as I said it's not a reliable reading.
                                        E.g it can sometimes show 5.7v which is completely impossible since we have a stable ~17VDC output after the diode depending on load.
                                        And my Fluke meter is not able to show anything on either AC or DC so it's similar to my experience in this thread with these meters.
                                        • hobostove
                                          Corsair RM1000e - Help identify 5VSB Zener diode
                                          by hobostove
                                          Hey there guys. I've got a Corsair power supply that's come across my bench dead. I usually don't mess with power supplies, but it's a slow week so I'm giving it a whirl.
                                          Taking it apart I heard a screw rattling around inside, and when I got it apart I found a couple blown components near what I think is the 5VSB area.
                                          There's a 22ohm resistor that's melted and open, but it still has the bands.
                                          The other part is a zener diode and it's top went to jesus, so I can't read the marking.
                                          It looks like the diode connects the source and drain of a TNY284...
                                          03-27-2025, 02:25 PM
                                        • Takeatry
                                          Yet another Samsung QLED Boot Loop
                                          by Takeatry
                                          Samsung QLED QN50Q — purchased 2022 started experiencing a delay in the picture coming on in the morning less than 2 years later. Did not know the term boot loop at that time. As the loop delay ran into a few minutes did all the recommended troubleshooting, soft and hard reset, changing cables and outlet locations, no help. As the delay increased contacted Samsung tech group and allow them remote access the tv. Tech was moving too fast to see exactly what he was doing but this ultimately it was also no help. Lived with the delay until it stretched out over 6 hours. Pulled of off the back cover...
                                          10-04-2024, 02:57 PM
                                        • blaster_
                                          Samsung UE49MU6105K - boot loop, horizontal lines
                                          by blaster_
                                          Less than a year out of warranty, samsung UE49MU6105K craps out, they've got this designed obsolescence down to an exact science of self destruct when out of warranty...
                                          Screen started to show horizontal lines and ghosted image at the bottom, then turned off by itself. Did software update, to no avail of the line problem, and got a boot loop after some minutes of watching TV. This boot loop will turn on the backlights for some seconds the sound comes on, the image will turn dark very fast and then it reboots again. Pressing power button will not put it on standby. Disconnecting...
                                          06-22-2022, 05:19 PM
                                        • прямо
                                          Viper22A 5VSB circuit
                                          by прямо
                                          So I have a cheap non working ATX PSU that I was learning to repair a decade ago. At the time, it blew the main fuse, bridger rectifier, NTC, and primary 9A 900V MOSFET. Replaced all except the MOSFET. 5VSB came back online. Then I poked around in it so much, measuring components one by one to a point I accidentally made the 5VSB circuit primary side went bang. Blown the AP8022 (Viper22A) PWM chip, along with a low resistance resistor and the PC817 opto isolator. I replaced them all.
                                          In the process of poking around, I also lost a zener diode that stabilize the voltage coming from...
                                          01-13-2024, 07:05 PM
                                        • kotel studios
                                          FSP300-60GTF - no 5VSB, PS_ON; 5VSB carnage
                                          by kotel studios
                                          Finally replaced all of the shorted 4148's and resistors and an blown tl431 on my FSP300-60GTF after 5VSB going crazy and destroying it self. Those components also made the secondary transistors appear shorted (while in reality they weren't).
                                          Powered it on through my dim bulb tester and they (bulbs) only flash once meaning primary caps are getting charged, but that's it. No 5VSB, PS_ON voltages.
                                          I am sure I have replaced the components correctly and that there weren't any shorted/blown traces left.
                                          Any ideas where to go next?
                                          02-23-2025, 11:47 AM
