hp dv6 bios dump
  • asliyucegsm
    • Jun 2011
    • 351
    • Turkiye
    hp dv6 bios dump
    my friend
    dv6-3320st
    mainboard.DA0LX6MB6H1 REV.H
    Intel Core i5-460M 2.53GHz SLBZW (Socket G1 (rPGA988A))
    Graphics
    AMD Mobility Radeon HD 5650 (216-0772000) 1 GB GDDR3 (8xHynix H5TQ1G63BFR 12C)
    not.not.HP dv6-3320st MB: fan continuous operation DA0LX6MB6H1 rev.h
    the fan is running too fast with other bios
    bios dump 4mb must
    thanks
  • ala_borbe
    aka Donald
    • 1625
    • Malta
    Re: hp dv6 bios dump
    backup old and try this
    Im Back... sort of...
    • muhamad.sh
      • Apr 2017
      • 6
      • turkey
      thank u my dear
      • onur89
        • Jun 2017
        • 1
        • Türkiye
        Thank you my dream
        • nts28
          • Nov 2015
          • 33
          • türkey
          thankyou
          • hardware-tec
            • Aug 2017
            • 4
            • Argentina
            Hola !! El primer archivos es el bios de la main y el segundo de que es??? dice EC
            • djharold
              • Aug 2015
              • 247
              • COLOMBIA
              el primer archivo es el main qu es el que da video, y el segundo es ec, que es donde guarda los seriales del equipo, con el main funciona la mayoria de los casos
              • daniel92
                • Jan 2015
                • 12
                • kenya
                the dump works fine, thanks.
                • SNS infotech
                  • 2
                  • india
                  dv6-2159tx bios needed
                  • Kamar
                    • May 2016
                    • 8
                    • india
                    good
                    • Pascal Komlassan
                      • Jan 2017
                      • 808
                      • TOGO
                      Good luck
                      • rohit_kool111
                        • Feb 2017
                        • 9
                        • nepal
                        hellow friend ....i want DA0ZQMMB6H0 REV:H bios
                          • 22276
                          Start a NEW thread ,you`ll get it .
                          • rohit_kool111
                            • Feb 2017
                            • 9
                            • nepal
                            what? i didn't understand
                              • 22276
                              The title of this thread is "hp dv6 bios dump"
                              You`re asking for a DA0ZQMMB6H0 bios, which is a acer E5-411. Use the search ,you`ll find previous threads with bios dumps.
                              • jou
                                • Nov 2016
                                • 3
                                • españa
                                thanks
                                • mkuzgun
                                  • 9
                                  • turkey
                                  THANKS bro
                                  • Gasasoft
                                    • Jan 2011
                                    • 4
                                    Thank you from me.
                                    Working dump without SN, SKU, etc.
                                    Must enter it manualy.
                                    • masoudpouramin
                                      • Nov 2018
                                      • 1
                                      • iran
                                      thank you ok
                                      • thelibrary
                                        • Jul 2018
                                        • 18
                                        • philippines
                                        tested working !!
                                        • Ahari
                                          by Ahari
                                          I...
                                          08-13-2025, 06:12 AM
                                        • mkdj
                                          ASUS ZenBook UX480F : need help with cleaning the ME region of my BIOS dump
                                          by mkdj
                                          Dear all,
                                          I have a ASUS ZenBook UX480F with the following symptoms:
                                          I suspect it is a BIOS issue. So I decided to try to clean the ME region. I followed the guide on win-raid, and I believe I have done everything correctly. My problem is: when I open the outimage.bin in ME Analyzer, it says that it is Extracted, and not Region, Extracted as it should be. Is it normal, or did I do something not correctly? This is my first experience editing BIOS files.
                                          I would appreciate if someone could take time to explain the issue, so that I can learn. But I would...
                                          10-19-2025, 04:41 AM
                                        • Habble7
                                          I need a BIOS dump for the Samsung S49CG934SU monitor
                                          by Habble7
                                          The Samsung S49CG934SU monitor does not power on - no LED indicator activity and no response to power button. However, when 21V power is connected, it immediately draws 0.8A of current with no display output. The motherboard processor gets warm, and there is continuous reading activity from the W25Q128BV BIOS chip.
                                          Suspected Cause:
                                          I suspect the BIOS may have been corrupted during a power interruption while updating the firmware. The official website provides firmware updates, but they can only be installed via USB flash drive.
                                          Troubleshooting Attempts:
                                          05-22-2025, 07:28 AM
                                        • haitham sharabati
                                          [Request] Clean BIOS dump for HP 15-da2007ne (8XF55EA#ABV) - N4000 - BIOS Lock
                                          by haitham sharabati
                                          Hello engineers 😀,
                                          I’m kindly requesting a clean and unlocked BIOS dump for the following HP laptop, as it’s bricked after flashing SP152727. The system now keeps rebooting, and the original issue was an Administrator / Power-On Password that I can no longer access.😏
                                          🔧 Device Info:
                                          - Model: HP 15-da2007ne
                                          - Product Number: 8XF55EA#ABV
                                          - Serial Number: CND0338P0D
                                          - CPU: Intel Celeron N4000
                                          - EC/BIOS Chip: [Add chip number from the motherboard or BIOS chip]
                                          💀 Problem:😅
                                          - Device shows “Administrator Password”...
                                          08-07-2025, 04:54 AM
                                        • Citymin
                                          NT955XED (Samsung Galaxy Book2 Pro - 15.6) BIOS dump file Request
                                          by Citymin
                                          My Samsung Galaxy Book 2 Pro 15.6-inch laptop has no display and won't boot.
                                          The charging red LED lights up, but the charging screen doesn't show any indication.
                                          When I press the power button, the blue LED cycles on and off three times, then the screen doesn't turn on, and the device won't boot.
                                          (I've tried removing the battery and resetting the device, but the issue persists.)
                                          NoteBook Model name : Samsung NT955XED-KK51G(Galaxy book2 pro, i5-1240p, 15.6inch AMOLED)
                                          PCB model name : Venus2-15-5G(REV1.2), Venus2-15 ADL NPC
                                          S/N : 5RNK9FFT70...
                                          08-05-2025, 05:12 AM
