Hoping someone who recapped these already can give some data on this.
Got a Friend's Enermax Liberty 400 Watt ELT400AWT which has two blown capacitors and is full of CTC & CEC.
Blown capacitors are:
C17 - 2200uF 16v on 12v Rail
C14 - 1000uF 10v on 5vSB.
The rest test OK but the 3300uF parts aren't as close to their rated value than the other ones are... Anyway, I decided to replace the lot, since they're a bit lame and I already pulled them all for testing anyway, and the PSU is some several years old.
I found that I should be able to cram 12.5mm diameter parts in for C18 and C19 (a little up off the board), as long as I drop C21 down to 6.3v to get a 10mm diameter, then I don't need to try to find any 3300uF in 10mm diameter.
My current selection is thus:
These should all be suitable, right? I picked whichever had the highest RCR (overkill?) and ESR that was as close as possible to what I measured on the old ones.
Unless anyone has used these already and knows otherwise, I'll get them.
Can't compare anything with CEC\CTC datasheets as they don't seem to exist. Nobody seems to have heard of LFFM or LFKM. There was some reference to KM series that seemed to come from Rifeking (Who seemed to be associated with CTC) but those are GP and have low RCR which doesn't make sense.
Only some CEC PCE-TUx datasheets exist which don't help since they are just the small (<22uF) GP capacitors that I'll be replacing with FC or PW.
Code:
Ref Value Voltage Size Brand Series Code ESR Capacity Rail Manf. Code ESR RCR C13 1500uF 10v 10x25mm CTC LFFM 6046 0.02 Ohm 1420uF 5vSB EEUFM1A152L 0.018 Ohm 2470mA C14 1000uF 10v 8x19mm CTC LFKM 6046 7.4 Ohm 50uF 5vSB EEUFM1A102L 0.03 Ohm 1560mA C16 470uF 25v 8x19mm CEC PCE-TUR 06-02 0.03 Ohm 405uF -12v EEUFM1E471L 0.03 Ohm 1560mA C17 2200uF 16v 10x25mm CTC LFKM 6046 2.2 Ohm 206uF +12v EEUFK1C222L 0.025 Ohm 2140mA C18 3300uF 16v 10x34mm CTC LFFM 6046 0.01 Ohm 2687uF +12v EEUFR1C332L 0.013 Ohm 3630mA C19 3300uF 10v 10x34mm CTC LFFM 6046 0.01 Ohm 2821uF +5v EEUFM1A332 0.015 Ohm 3190mA C20 2200uF 10v 10x25mm CTC LFKM 6046 0.02 Ohm 2210uF +5v EEUFR1A222L 0.018 Ohm 2470mA C21 3300uF 10v 10x34mm CTC LFFM 6046 0.01 Ohm 2838uF 3.3v EEUFR0J332L 0.018 Ohm 2470mA C22 2200uF 10v 10x25mm CTC LFKM 6046 0.01 Ohm 2199uF 3.3v EEUFR1A222L 0.018 Ohm 2470mA
Half of the computer problems is caused by bad contacts
And don't you recap PSUs all the time sou it would only make sense to buy some on stock?
(and yes, I waited for them to cool down after desoldering).
Thus, I knew I'd eventually go around to repairing it. One year later and we're here.
