As the title says, I got a "AO" (no, not AOpen
, their units are FSP) PSU that sits doing nothing and I have a complete PCB from a Enermax EG-365P/VE sitting here. It's a "P4 ready" variant according to the old casing. (which I ditched because of way too much rust)
Here are my goals with them:
- remove whatever PCB the Deer has (and probably reuse it when I need a solid 200/250 watt unit for say a Pentium MMX - Pentium 3 range machine)
- remove the auxiliary AT- style plug from the Enermax and the -5v rail as well since they have no use anymore
- rig up an extended 4 pin adapter for the plug using the old plug from the Deer as well as reuse the SATA plugs as well
- recap the Enermax
- replace the fan with either an clean Xinruilian LP/EP or a newer Globe Fan (which ironically is made by Jamicon)
- upgrade the 12v rectifier if necessary
Now several questions:
- When powered up, the Enermax does an insanely high pitched sound that keeps on going higher. What could it be? There's very little glue left on the board.
-Given I do the upgrades, what can I power with it? I could identify the following rectifiers - 2 of them that might be for 3.3 and 5v are S30D40C but the one in the middle which should be for 12v (I guess) is a S40SC4S, which I couldn't find a lot of info about.
- recap the Enermax
