ASRock 775i65G R3.0 - mod and recap?
  • trodas
    • Jan 2006
    • 770
    • Czech republic
    I wanted board that support AGP and the Core 2 Duo CPU's, especially the Core 2 Extreme X6800 for AGP benching. Dunno if that was a good choice, but the first board I get for this purpose is ASRock 775i65G R3.0. It does not look like much:
    http://postimg.org/image/i2e14qssf/
    http://www.asrock.com/mb/Intel/775i65G%20R3.0/
    ...but it promise support for the FSB 1066 on the fast CPUs. I ordered a Core 2 Extreme X6800 ( http://www.ebay.com/itm/Intel-Core-2...item2c93a7bad7 ), some fast rams should be moving towards me too ( http://forum.hwbot.org/showthread.php?t=95400&page=2 ), so what remain is a good cooler, PSU and let's the journey begin
    At first I tried a lazy old Celeron 336 (2.8GHz) and some crapy rams (2x 512MB Mushkin enhanced 2.5-4-4-9 tested at 200MHz):
    The board is completely stock, except that I get rid of the stickers and the "bouble gum" for the chipset cooler, replaced with AS2.
    There did not seems to be a way to increase Vcore in bios and using a stock Intel cooler I hit wall at 154MHz FSB (x21) pretty soon:
    http://valid.canardpc.com/lregg7
    Now we can all quess, what that caused. Not enought Vcore? Celeron having a problem going over 3.2GHz? Poor cooling? Poor old FSP300-60NP PSU? Rams? (they should not be the case, as I tested them with the timings (except TRAS 9, this board did not let me set over 8) at 200MHz)
    Never the less, I started measuring on the mobo what caps I can replace with quality ones. There is the table of caps and voltages on ASRock 775i65G R3.0:
    Including original .ai file (Illustrator 7), if anyone want to use/print it for own moding.
    Surprisingly, the board have zero caps from the bottom. And since it have only 5Vcore output caps, then I have to come up with some mod that add caps to the Vcore output, as this is IMHO not enought caps for only 3 phase Vcore regulation.
    Still, people managed max FSB 352MHz: http://ww.w.hwbot.org/submission/243...65g_352.44_mhz
    ...max memory clock 250MHz: http://ww.w.hwbot.org/submission/232..._sdram_249_mhz
    ...and max CPU clock od 4.2GHz: http://ww.w.hwbot.org/submission/233...641_4220.4_mhz
    ...so I have something to look forward to
    "It is dangerous to be right in matters on which the established authorities are wrong." - Voltaire
    "I believe that all the people who stand to profit by a war and who help provoke it should be shot on the first day it starts..." - Hemingway my config - my caps
  • c_hegge
    • Sep 2009
    • 5219
    Re: ASRock 775i65G R3.0 - mod and recap?
    Those pictures don't work (they can only be viewed as thumbnails). Do NOT use postimg, imageshack or any other 3rd party image hosting here. Please upload all of your attachments locally.
    • trodas
      • Jan 2006
      • 770
      • Czech republic
      So, when my Celeron 336 does not like to go higher that FSB 154, then what about my Pentium 4 650? Can it get higher? We see.
      First at all, puting a P4 in the mainboard "unlocked" the DDR400 settings (previously only 133 and 166MHz ram settings are available, now 200MHz is possible too, hoooray!).
      And another thing is, that the Intel cooler is not cooling the CPU well, when come past 3.5GHz, as there are serious thermal slow-downs... :o
      Also the Mushkin enhanced rams cannot make it stable past 200MHz (maybe not even on 200MHz, as they need the TRAS 9, while maximum setting is 8 on this board), so I replaced them with 2x1G sticks OCZP4001G that I have tested they run well at 2.5-3-3-7 1T to 232MHz with mere 2.64V
      Sadly it turns out, that any overclocking with this "cooler" is just a wishfull thinking, so solution is simple - get better cooling, mod the mainboard caps for quality ones, add caps, use good PSU - and possibly also use less TDP demanding CPU (P4 650 have 84W TDP, Core 2 Extreme X6800 have 75W TDP).
      Also I realized, that the nVidia FX 5600XT card, witch I like and moded pretty much well ( http://s18.postimg.org/g28j6c70p/Ge_...ono_Plus_5.jpg ) cannot give over 60Hz output in 1280x1024 using DVI. Crappy lame HW limits. I learn that nVidia used crappy TMDS encoders in the whole FX 5xxx line, so basically it cannot send quality digital signal of need clocks for 75Hz... damn!
      (hence crappy R9100 can do 75Hz over DVI, but FX 5900 Ultra cannot)
      Solution - get Radeon 9600XT and recap it, mod it :o
      I have to report a little progress:
      - get serious PSU - done. eVGA Supernova G2 850W might be a "bit" overkill, but it does the job done:
      - get serious cooling - done. Noctua NH-C12P SE14 will get the job done and keep even highly TDP demanding CPU's in reasonable temps:
      Also I have progress on the bios thing - using AMIBCP v3.51 ( http://forums.mydigitallife.info/thr...-0-bios-unlock ) I opened the bios and - sadly - there is no hidden options:
      Damn.
      Nevermind - how far it will overclock now, witch good cooler? Even 218x17 (3703MHz: http://valid.canardpc.com/hrmiv0 ) does not seems to be a slightest problem.
      Surprisingly (there are plenty of much faster CPUs, so WTF?) I even set a SuperPi 32M record for the mobo:
      http://hwbot.org/hardware/motherboard/775i65g/
      ( http://hwbot.org/submission/2858182_...in_52sec_609ms )
      ...witch is hardly any record, but currently it is
      So till the rams and X6800 Extreme CPU come, I could play a bit to see, how far the poor P4 650 can be pushed w/o increasing the voltage.
      • trodas
        • Jan 2006
        • 770
        • Czech republic
        A serious setback happend - rams aren't performing how they should
        Since the target CPU is Core 2 Extreme X6800, I need fast DDR1 rams. For P4 a 200MHz is fine (800/4 = 200), but for 1066MHz CPU is need 266MHz rams to have FSB:rams into 1:1 for the maximum speed. Therefore I started searching for rams, that can do 266MHz. A user from germany showed that his Qimonda rams, using CE-5 chips can run at 265MHz getting 2.7V (Abit IC7-Max3 with intel 875 chipset):
        So he sold me these and when i used the very same ram sticks (see S/N) in ASRock 775i65G with intel 865G chipset at 2.75V, I get them fail at mere 216MHz, using the very same settings:
        Sure anyone can claim, that it was because my CPU cannot handle that overclock, right? Well... wrong. Even there is no Vcore increase, my CPU can handle 228MHz FSB ( http://valid.canardpc.com/hl1nhr ) somewhat stable for CPU-Z and benchable it can handle 220MHz:
        So to put it short, Qimonda rams fail at 216MHz, OCZ rams working at 220MHz. Hardly this could be because of the CPU ... or can it? Who can explain me, what just happend? Same mobo, same CPU, same settings... yet so dramatically different results?!
        What can be wrong? Could the ASRock somewhat address the rams SO bad, that they now fail at 216MHz, when they worked on Abit at 265MHz?!
        ...and no... I cannot use these OCZ rams for 266MHz, as they have top frequency about 231/232MHz with reasonable timings
          no-name Radeon 9600 XT recap and cooler
          by momaka
          I've been seeing a lot of cheap-looking (but not always so cheap) no-name AGP video cards on eBay for a while. They started popping up quite a bit when the market for AGP cards became more alive all of a sudden due to interest in “retro” PCs. One thing that struck me about these cheapo cards is that they almost always seem to come with garbage caps - including the abominable Sacon FZ. That aside, though, I've been wondering about the rest of the quality (or lack of?) on these cards. So I decided to satisfy my curiosity yet again.
          This one was actually suggested to me by ChaosLegionnaire....
          11-06-2020, 07:54 PM
          BFG Tech. GeForce FX5200 [ASLM52256] – full recap info and cooler mod
          by momaka
          The more time passes, the more nostalgic I get with old hardware. Video cards and motherboards tend to be my weak spot. As such, I often scavenge eBay for old PC hardware, especially anything with bad caps or in need of similar minor repair.
          For today's consideration, I have a popular low-end card from back in the early 2000's: an nVidia GeForce FX5200. This one is the BFG Tech. Asylum take on the card, with 256 MB of DDR RAM running at 400 MHz and 128-bit bus (vs. 64-128 MB and 64-bit bus on many of the cheaper versions.)
          I think it's easy...
          08-11-2019, 10:20 AM
        • gabrieljma1
          Request: Full BIOS dump for ASRock Z790-CX (DDR5)
          by gabrieljma1
          I’m looking for a full raw 16 MB BIOS dump for an ASRock Z790-CX (DDR5) motherboard.
          The board powers on (fans spin, RGB lights on, RAM LEDs active), but there is no display output and the VGA and BOOT LEDs stay lit.
          I’m using an Intel i9-14900KF CPU (14th gen), and it seems the BIOS version on my board doesn’t support it yet. I tried to flash the official ASRock BIOS file (renamed .ROM → .BIN) directly using my RT809H programmer, but it didn’t work — monitor stays on but with black screen, so I believe the ASRock update file is not a complete...
          10-08-2025, 03:32 PM
        • Exim
          ASRock N100M, no picture no boot, but semi-alive
          by Exim
          Hi guys,
          I managed to semi-kill an ASRock N100M board after updating Bios from 1.10 to 2.01. It's a zombie now, dead, but not dead.
          ASRock N100M special features:
          - CPU soldered to board, small Intel 12th gen
          - iGPU
          - four POST LEDs
          Problem after updating Bios to 2.01 using the in-Bios update tool: no picture, no boot.
          I am not sure anymore if it booted at least once successfully after updating the bios to 2.01, maybe not, I can't remember. I think it did not.
          Symptoms:
          - no picture/signal on any of the display connectors,...
          04-01-2025, 02:36 PM
        • MasterCap
          What IC does AsRock usually use to make the PWM signals for GPU fans ?
          by MasterCap
          I have an AsRock Taichi 7900xtx, and the minimum fan speed is way too high at 1000rpm, and thats with it's Quiet BIOS switch on, and me setting the fan profile as low as it goes, while on.
          Now 1 thing I could do is just make some circuit to put in between the fan the the GPU, and leave the fan on all the time, but anytime the GPU is sending the PWM for min speed, I'll just send something lower and quieter.
          But does anyone know what how AsRock usually sends the PWM to the fans on GPUs and mobo's? Is it from the MCU that's often near the 12V inputs and fan jack ? Or is...
          12-28-2024, 08:42 AM
