Car Ammeter
  • barry wilkins
    • Aug 2009
    • 172
    Car Ammeter
    I did this test on my previous car to check the alternator was charging the battery properly.
    The earth cable from the negative terminal to earthing point on the vehicle has a very small resistance. So I built a simple millivolt meter and connected from the said battery terminal and earth point and measured the voltage drop ,then I connected a DC ammeter in series with the earth cable and measured the actual current drawn.
    Now I had the measurements I calculated a factor ,multiplying the mV by 0.921 which gave me the current .
    Examples
    Side lights - 3.8mV x 0.921 = 3.5A discharge.
    Head lights -12.6mV x 0.921 = 11.6A discharge
    With the engine running after starting gave me +7 to 4.5 mv ,so I could tell the alternator was charging the battery.
    Barry Wilkins
    Re: Car Ammeter
    Useful info. But isn't it enough to see the battery voltage increase? A charging lead acid will show around 14.4V, whereas a battery that has been idle will drop down to around 13.5V reasonably quickly.
      • 31086
      Re: Car Ammeter
      you can get a digital ammeter with a 200a shunt on ebay for under $10
      • redwire
        • Dec 2010
        • 3910
        Re: Car Ammeter
        It's an interesting experiment.
        Copper is not so great for a (shunt) resistor. The tempco of copper is about +2% per 5°C and you have to make a Kelvin connection with your multimeter.
        If your probes are not matched- touching different metals like lead, zinc, or copper then thermocouple effects add mV too.
        You have a 1.09 milliohm resistor, all for free. I looked at #4AWG wire which is about 0.25 milliohms per foot, so your crimp connections are looking dirty....
        • caspian
          Can Ammeter damage Power Supply?
          by caspian
          Dear Members,
          My DC linear Lab Power Supply does not display the current and voltage correctly. Thus, I am going to connect an Ammeter/Voltmeter Module to the DC output of the power supply. Then, a load will be connected the takes about 1-5volts with 0.1-1.5Amps.
          But I heard If I connect an Ammeter to the output of the power supply, then the Ammeter module is not isolated from the power supply so that the Ammeter can damage the power supply.
          Is this true?
          I have attached the photo of a sample Ammeter module that I am going to buy....
          06-05-2022, 01:42 AM
        • redwire
          Making a capacitor discharge tool
          by redwire
          I'm making a new capacitor discharge tool. Asking for suggestions for sizing the discharge resistor.
          Mr. Carlson's Lab High Voltage Capacitor Discharge Tool 1 is using 4 of 1kΩ 50W aluminum (mount to heatsink) resistors in series for 4kΩ 200W, so it's big, which is fine.
          His Patreon but I don't have a paid subscription for the project details but it looks straightforward. The plastic box with aluminum plate can't get rid of any amount of that heat though.
          Wirewound resistors can be overloaded by a factor of 5 for 5sec. and a factor of 10 for brief times. I've never tried say...
          06-18-2023, 07:09 PM
        • shagster
          Capacitor Discharge Rate Testing!
          by shagster
          Hi, I have 2 identical capacitors from an old scope I'm trying to get running.
          Both caps measure ok in ESR and Capacitance values imo.
          Data sheet says tolerance spec is -10 +50%. And these are way under that.
          Both of there original values are marked as (430uf 200vdc).
          After ~40 years, they now measure 485uf and 465uf. Well under the +50% tol.
          Anyway I charged them up to 24 volts dc and discharged them slowly down to 10 volts using a Digital Multi Meter. Funny thing was one of them just took over 4 minutes to discharge down to 10 volts. And the...
          08-24-2023, 02:55 PM
        • Zibbo
          Lenovo T470P NM-B071P not charging, 20 volts on positive +ve battery terminal
          by Zibbo
          Lenovo T470P NM-B071P had no power. PQ2 and PQ11 were shorted, repaced them and laptop turned ON. Connected the battery and the motherboard turned off immediately and it won't charge, checked the voltages and found out that there is 20v on the positive battery terminal.
          Replaced battery charger IC PU101 and the two switching mosfets PQ101 and PQ102 and still same problem. Now I can't figure out how 20v is ending up on the battery terminals.
          12-27-2024, 12:20 AM
        • Hornnumb2
          Relay feed terminal
          by Hornnumb2
          I have this relay on my tv lift and would like to figure out what voltage is needed to activate the relay. Which terminal do I test. Thanks Michael
          11-01-2024, 06:55 PM
