Relay feed terminal
  • Hornnumb2
    • Feb 2011
    • 218
    Relay feed terminal
    I have this relay on my tv lift and would like to figure out what voltage is needed to activate the relay. Which terminal do I test. Thanks Michael
  • R_J
    • Jun 2012
    • 9588
    The coil voltage will be marked on the relay, The coil is marked by the square simble across the two pins
    • Hornnumb2
      • Feb 2011
      • 218
      I am trying to figure out what pin gets the signal to lower or raise the tv lift. I want to use something that when tv is turned on it lowers and raises when turn off. So a separate remote is not needed. The relay states it’s rated for 24vdc but I don’t think it’s running on that.
      • truclacicr
        • Apr 2019
        • 343
        • australia
        https://www.generationrobots.com/media/JQC-3FF-v1.pdf
        The coil voltage is 24VDC. The contacts are SPDT.
        • Hornnumb2
          • Feb 2011
          • 218
          Still looking for answer to the question, which terminal would I send 24vdc to to click relay on? Thanks
          • truclacicr
            • Apr 2019
            • 343
            • australia
            The relay's datasheet shows you the pinout. One end of the coil would be wired to +24VDC, the other would be connected to a switching transistor or IC. We can't tell much from your limited photo. Basically, you need to trace the circuit to understand what is going on.
            • R_J
              • Jun 2012
              • 9588
              It is likely that one side of the relay coil is connected to the +24v supply and the other end of the coil is connected to a transistors collector,and the transistors emitter connects to ground (negative of the 24v supply) The base of the transistor could be controlled by a low voltage ie:3~5volts from what ever controls this board. If this is the case there will likely be a diode across each relay coil as well. A picture of the back of the board will help as well as knowing what those plugs connect to.
              • CoinCoin88
                Garage door RX unit (Cardin S38C) does not short relay to send opening signal
                by CoinCoin88
                I'm turning to the Badcaps community to help me troubleshoot the radio Rx card from my (old) garage door opener. While I could just ditch that card and replace the whole system, I first would like to understand "why" it suddenly stopped working, because that's just how I am wired...!
                Some basics: the receiver works on a 30.875 Mhz frequency. Yes, I'm aware this is not in use anymore in a looot of places. It does not use any rolling code, it's just a regular dip-switch code that you have to set up on both the receiver and transmitter. The receiver...
                09-15-2025, 03:36 AM
              • jm1234
                9V relay temperature 40C
                by jm1234
                Hi, I'm seeing one 9V relay having temperature 40C on its 9V (primary) side. Does that seem right? I switched 2 relays on that board and the temperature was the same (on the same position), so I'm sure it's not a faulty relay. I measured voltage on that relay and it was 9.5V DC, so that looks good. I don't see any other relay on that board having that kind of temperature and they have 9V on them too.
                I thought maybe the transistor that is switching this relay keeps switching on/off, so I also checked for AC and there was almost none: 0.3V using mV range. No steady frequency was shown, but...
                05-09-2024, 03:03 AM
              • edugimeno
                Biomass Boiler not driving cleaner motor relay. ENERTRES BIOMASA BI-650
                by edugimeno
                Hi everyone!
                I have this board that suddenly stopped supplying power to an output that drives an interchanger cleaner motor.
                I checked while the board was in place with all wires attached and there's no AC voltage on the corresponding plug X5
                This X5 is driven by fuse F8 (tested OK) which comes from the second orange relay
                To make sure there are no charcoaled contacts inside the relay, I got a 24VDC power supply and got it ready to manually power up the coil side of these relays.
                I respected the polarity, positive to cathode of protecting diode
                So provided all...
                04-18-2024, 01:15 PM
                TOP201YAI 3-Terminal TO-220 PWM switch Figure #7 in date sheet
                I would like to know what the specifications for the transformer in this data sheet is I would like to build one
                Also for figure number 8 as well
                Also for figure number 9 as well
                Here is the data sheet I know that this item has been disconnected but I can buy them surplus
                https://cdn.badcaps-static.com/pdfs/...da43fe7f6c.pdf
                I have a mad scientist streak in me lately and want to be a little adventurous
                The reason is I have some ATX switching power supply that I have as spare parts from and wondering if I could use one...
                10-09-2021, 06:21 AM
              • edugimeno
                Repairing a ENERTRES Biomass BI-650 heater
                by edugimeno
                Hi all!
                A friend asked me to repair his biomass (pellet) heater. This heater has a pellet feeder powered by a relay that's not switching anymore
                I measured the voltage at the relay coil socket while entering the individual tests procedures and it has 6-7v while the relay is NOT on the socket, and drops to 0v when the relay is plugged in the socket, like the source is providing nearly 0 mA. I measured the relay coil and it is correct and not shorted so the issue is in the board, fed no amps to this output
                I checked the board at home and this output is driven by an...
                07-28-2025, 04:32 AM
