XVT3D554SV - Boot issues
  • DLinkOZ
    • May 2013
    • 238
    I found this TV noted as "won't turn on" and grabbed it as an upgrade for one of my smaller sets. I got it home, plugged it in and it worked perfectly (see first pic). I does take a very long time for the initial standby to kick in (logo flashes 90-something times before going solid amber).
    After about 15 or 20 minutes, I walked back by it and noticed that sound was still on, as was backlight, but the picture was now blank. It would not power off via the remote, so I pulled the power. At this point, I've seen references to this behavior on the internet (and I believe here) related to a t-con issue. I plugged it in, and it hasn't powered on since. At least, not properly. After the painfully-long blinking to a steady amber logo, pressing the power button (side or remote) turns the logo solid white, and 12v goes hot. After two minutes, it shuts down, begins the long sequence of flashes and attempts to power on again. Rinse and repeat with the two minutes of white logo until a reboot.
    The 5.1v is always present, 12v comes on with the white logo. All fuses are good (main board, power supply and t-con). There is a flashing blue LED on the LED driver board, I did not see it when the TV initially worked so I don't know if it was steady at that point. I isolated the t-con, then the LED driver board, with no change in behavior (though I didn't really expect to see any changes).
    Is there a service manual available, and have these sets been seen enough to build a familiarity and "common cause" knowledge? It now acts like a typical Vizio bad eeprom, but what bugs me is that initial time when it did work (before it somewhat froze). Are the eeproms available for these, versus replacing the entire main board (if that's what it turns out to be)?
  • DLinkOZ
    • May 2013
    • 238
    Re: XVT3D554SV - Boot issues
    Also, in the power supply picture the bottom-most (which is actually right-most since the pics showed up here sideways for some reason) transformer gives a pretty good buzz while it's turned on.
    • DLinkOZ
      • May 2013
      • 238
      It's identical to this post:
      https://www.badcaps.net/forum/showthread.php?t=29914
      So unless I can come up with another reason, I'll order a replacement t-con.
      • necatduman
        • Feb 2015
        • 72
        • siirt
        vestel 17pw25-4 power kartı
        subject did not know where to turn in vestel LCD pov card + 5-volt diodes 1 and does not work 2 volts play making TV more employees supply board could not find the defective part in the TV worked I grandparents d809 diode wonder which barges defective
        • Glitcher
          • Mar 2013
          • 673
          • USa
          Does sound like a main board problem if you weren't able to turn it off when it went blank.
          • cliff_hootarski
            • Jul 2006
            • 411
            I agree with Glitcher.
            • nomoresonys
              • 12274
              • U.S.
              looks like the x's are starting to show on a couple of the tcon caps, dont necessarily mean theyr bad, why not? try a tcon, if you get a good one, then if it dont work, you can rule it out, and you have a spare.
              • nomoresonys
                • 12274
                • U.S.
                could very well be a mainboard issue, mainboards usually cost much more than tcons do, thats why I when in doubt I start with it, I dont mind having a spare tcon on hand, just in case.
                • ReeceyBurger123
                  Never Give Up !
                  • May 2014
                  • 7325
                  • Britain
                  The vents on smd caps normally look bloated slightly outwards, they arent bad at all especially of the age of the tv.
                  • nomoresonys
                    • 12274
                    • U.S.
                    Originally posted by ReeceyBurger123
                    The vents on smd caps normally look bloated slightly outwards, they arent bad at all.
                    they very well can be bad, I've had some that were, no doubt about it.
                    • ReeceyBurger123
                      Never Give Up !
                      • May 2014
                      • 7325
                      • Britain
                      Let me rephrase that for you, smd style electolytics the vents normally look pushed outwards even when the caps are good, not sure why maybe due to the angle of light.
                      • DLinkOZ
                        • May 2013
                        • 238
                        Yes, those are a 470uf cap and every single one on every board (t-con, main board, etc) have visibly-creased vents. I can't believe that every single one went bad. And I agree - the t-con is cheap at only 40 bucks, and my symptoms are 100% exactly like that other thread (down to the flashing blue LED). So I'll get one ordered.
                        • nomoresonys
                          • 12274
                          • U.S.
                          you could be on the right track with the eeprom too, hard to tell.
                          • DLinkOZ
                            • May 2013
                            • 238
                            It is, definitely. If I could find just the eeprom alone, I'd snag that. But for the cost of the entire main board, I'll wait to see how the t-con goes
                            • nomoresonys
                              • 12274
                              • U.S.
                              ran across this place, don't know anything about them tho. http://www.rohm.com/web/global/searc...ncEaAhA48P8HAQ
                              • nomoresonys
                                • 12274
                                • U.S.
                                maybe put in the number on your eeprom, might be able to locate one, looks like they run from 10-20 bucks.
                                • DLinkOZ
                                  • May 2013
                                  • 238
                                  I'm not able to positively identify which is the eeprom on this board, I took pictures of all of them for future reference. But no matter, as for now I'm keeping an eye out for a t-con. I just keep going back to the other post with absolutely the same symptoms (even the initial successful power on). Now to find one in stock somewhere for a reasonable price.
                                  • DLinkOZ
                                    • May 2013
                                    • 238
                                    Here's everything I found on the board (front and back). Extra pics, some of them I know aren't the eeprom but decided that if I was taking pictures I might as well capture everything. Did not take pics of the memory from the solder side of the board.
                                    • nomoresonys
                                      • 12274
                                      • U.S.
                                      not sure which one it is ether, but the ones I looked at had four pins on each side.
                                      • DLinkOZ
                                        • May 2013
                                        • 238
                                        My eBay refreshing got the board right after it was posted. Snagged and paid for, we'll see if it resolves things once it arrives.
                                        • Teban1306
                                          [REQUEST] ThinkPad T14 Gen 1 (20S1) - Custom Boot Logo Modification
                                          by Teban1306
                                          Hello everyone!
                                          I hope this is the right section for this request. I'm looking for help to modify the boot logo on my ThinkPad T14 Gen 1.
                                          System Information:
                                          • Model: Lenovo ThinkPad T14 Gen 1
                                          • Machine Type: 20S1S4E600 (Intel i7 variant)
                                          • Current BIOS: N2XET42W (1.33) - Latest version
                                          • BIOS File: n2xuj25w.exe (12.98 MB) - Downloaded from Lenovo support
                                          What I'm trying to achieve:
                                          Replace the default "LENOVO" boot logo with a custom image during POST.
                                          🔧 What I've tried:
                                          09-14-2025, 11:49 AM
                                        • q2v5
                                          Lenovo T480s, what's up with this Bios, modded boot logo, reflashed now bricked
                                          by q2v5
                                          Lenovo T480s
                                          Model 20L8-S3TE00
                                          Board ET481-U10
                                          Chip MX25L12873F
                                          Hi, I have a few of these & they came with a custom bios boot logo, no passwords etc.
                                          2 x were brand new unused but with custom boot logo, 1 I installed Windows/ran updates then it bricked itself. 1 wouldn't get past the custom bios boot logo.
                                          The third I loaded windows, took a backup of the bios chip, then tried to flash several different clean bios's via programmer which all caused it to not boot. I tried to reflash the original bios both using clip & desoldering but...
                                          08-15-2024, 10:40 PM
                                        • kca
                                          by kca
                                          Hello all ~
                                          08-31-2025, 06:38 AM
                                        • taslan
                                          Surface 7 Pro wont boot, shows Logo and immediately turns off
                                          by taslan
                                          as stated in the title, my surface 7 pro wont boot anymore.
                                          When i press the power button it shows the square windows logo for a second and immediately turtns off again.
                                          I dont even have a chance to get into bios or boot from usb.
                                          While trying to find help online it was suggested to look for help/repair here on badcaps and it might be a ME Region corruption in bios.
                                          I dont know what that is exactly, but i never tinkered with the bios or windows in terms of hacking/patching etc.
                                          Bought it directly from microsoft and used it now and then and only...
                                          01-16-2025, 01:25 AM
                                        • cdma-india
                                          Acer Commercial BIOS boot logo tool for TMP214-53
                                          by cdma-india
                                          REQUIRED Acer Commercial BIOS boot logo tool for TMP214-53
                                          I WANT TO CHANGE STARTUP BOOT LOGO ANY ONE HAVE ABOVE TOOL OR ANY EXACT LOCATION WHERE BOOT SPLASH SCREEN LOCATED?
                                          THANKS
                                          02-27-2023, 09:27 AM
