vizio vp322 powers on but weird pixelation
  • jose6326
    • May 2013
    • 707
    I picked up this tv for free
    The lady was going to throw it in the trash
    I read previous posts on this model tv but nothing comes close to what im experiencing unless I misread something
    Anyways when I press the power button(no remote control) it powers up, psu clicks, tcon lights up and ysus turns on with a noticable buzzing noize.
    No logo shows up on the screen then this weird blue pixelation is going on.
    I hope the panel isnt defective
    I checked the fuses on the psu and they are good
    No visible faulty caps
    The y-sus board fuse is good
    Here are the voltage readings
    Connector on psu going to ysus board
    Va 59.6v
    Vs 190.4
    5.05v
    Connector on psu to main board
    5.08v
    12.11v
    16.41v
    After the tv has been on for a few minutes some of the blue pixels have disappeared. Not sure if this is good or bad
    The 7th and 10th picture are blue pixels just like the 6th picture. The lighting in my room caused a different color but its blue
    So what else should I test?
  • Shinju
    • Mar 2014
    • 1239
    Re: vizio vp322 powers on but weird pixelation
    You need to find the voltage test points on the Ysus and xmain and see what they are. There is a sticker on the panel telling you all these voltages can you post a photo of that?
    • jose6326
      • May 2013
      • 707
      I did its pic number 11
      And I tested the voltages at the connector
      • Shinju
        • Mar 2014
        • 1239
        You are missing VZB, the test point is on the Ysus the arrow points to the leg of a resistor. VSC is also on the Ysus he test point is below a large red capacitor.
        • jose6326
          • May 2013
          • 707
          i dont know why my camera flipped some of the pictures but i can retake pictures if needed
          • Shinju
            • Mar 2014
            • 1239
            I believe the way this plasma is designed is the x and y are on the same board, smallest plasma made in the states as far as I know.
            I have only got to play with one, never had the chance to own one to tinker with.
            • jose6326
              • May 2013
              • 707
              Vzb is 79.4v
              Vsc is -103.2v
              • Shinju
                • Mar 2014
                • 1239
                Yeah, VSC should be -185 and VZB 140 as per sticker spec. You got a bad y/x board. Lucky for you these are cheap.
                Match your Ysus part number here and your are set.
                http://www.shopjimmy.com/vizio/vp322...o+VP322HDTV10A
                • Shinju
                  • Mar 2014
                  • 1239
                  Just to be 100% sure let's try the test patterns, ok on your controller board you will see 3 copper ring holes near the bottom right of the board.
                  With the TV off and the LVDS unplugged from the controller board jump R241 and R211 with a jumper wire and plug in the TV and tell us what you see on the screen.
                  • jose6326
                    • May 2013
                    • 707
                    i ordered the board
                    thanks for the help
                    what causes this problem on the ysus?
                    • Shinju
                      • Mar 2014
                      • 1239
                      LVDS cable connects the mainboard to the controller board.
                      • jose6326
                        • May 2013
                        • 707
                        The red circle or purple circle is the lvds cable?
                        • Shinju
                          • Mar 2014
                          • 1239
                          Purple.
                          • jose6326
                            • May 2013
                            • 707
                            Ok I jumpered the board like you said
                            I got several patterns with different colors but the patterns are distorted like the pictures I posted before of the blue pixelation
                            The paterns would go vertical and horizontal
                            • Shinju
                              • Mar 2014
                              • 1239
                              Question, the longer you keep this unit on does the dark splotches start to go away?
                              • jose6326
                                • May 2013
                                • 707
                                if you look at my first post pictures number 6 and 7 are when i frist powered the tv
                                picture number 10 is after the tv has been on for more then 10minutes
                                so yes the blue pixels spots go away but not all
                                i hope i am making sense
                                • Shinju
                                  • Mar 2014
                                  • 1239
                                  Also while you have your TV apart I would replace the 2 3300uf Caps on the power supply and the 470v as the caps for spots C205 C241 and C236 (cannot remember their values) these are located near the plug going to the mainboard.
                                  The will fail they are the other cause of these little plasma panels failures on the power supply.
                                  • jose6326
                                    • May 2013
                                    • 707
                                    So I should replace all the caps in the red circle right?
                                    And I should also order the ysus board right?
                                    • Shinju
                                      • Mar 2014
                                      • 1239
                                      Sure, those are them. This looks like a sustain failure if it was mine I would take a chance for 20.00 +ship, these are cool little 720p tvs.
                                      • jose6326
                                        • May 2013
                                        • 707
                                        I will order every thing tomorrow morning
                                        Thanks for all your help
                                        • csmith
                                          Vizio D50u-D1 Powers up no picture
                                          by csmith
                                          I replaced the backlights all good. Two months later set was dead, had a shorted D9100, replaced all good again.
                                          Now months later set powers up,backlights light ok,no picture. 12volts missing from fuse on tcon. 12VA on power
                                          supply is 19 volts. Changed D9100 again, same, 12 volts measures 19. Am I looking at a power supply or mainboard
                                          issue. Set will power up with remote but not power off....
                                          07-11-2025, 11:52 AM
                                        • Tynan Dill
                                          by Tynan Dill
                                          Assuming...
                                          11-22-2024, 01:46 PM
                                        • JaquesPratt
                                          Vizio D32f-E1 Powers on, has backlight, won't boot/no logo, no menu or video
                                          by JaquesPratt
                                          I have a Vizio D32f-E1 LCD TV that does NOT have a TCON board.
                                          This TV recently went through some 'death throes' and now won't boot. The first problem that began to manifest was while watching tv, the screen would 'freeze', and the image would dim over a few seconds until it was very dark. HOWEVER, the audio of the show would continue as normal. I could power off the TV for 5-20 seconds, power back on, and the video would be normal. This would occur 1-3 times when the TV was first started, and would not happen again after the TV was 'warmed up'. Not ideal, but this glitch was manageable....
                                          07-16-2024, 01:04 AM
                                        • npolite
                                          Vizio E320-A1 Powers on But No Display
                                          by npolite
                                          Hi All,
                                          I have a Vizio E320-A1 which lost sound and picture. The power LED comes on and stays on but nothing else works. I am not able to power it off unless I unplug it.
                                          Here are the voltages when the power is on
                                          1 - 5.25
                                          2 - 5.25
                                          3 - 0
                                          4 - 4.8
                                          5 - 25
                                          6 - 25
                                          7 - 0
                                          8 - 0
                                          9 - 0
                                          10 - 12
                                          11 - 12
                                          12 - .9
                                          13 - .5
                                          Can someone let me know if the issue is with the mainboard?
                                          Thanks...
                                          04-19-2024, 11:33 AM
                                        • ossroy
                                          Vizio M60-C3 powers on, perfect logo, turns off
                                          by ossroy
                                          Vizio M60-C3 powers on, perfect logo, turns off. If you don't touch anything it will repeat this process by itself until it is unplugged. Not the "button board" since I disconnected the cables to the main board and the problem persisted. So I'm fairly positive something is going on with the main board, but want to know if there is a fix for this other than replacing the expensive mainboard, which may eventually have the same problem. Also, heat sink was hot as hell when this all started. Unplugged for a few days and same thing happens.
                                          My kids are getting antsy waiting...
                                          08-03-2022, 08:11 PM
