Hp dv4 wsnu main board
  • dycc
    Vision
    • Nov 2011
    • 625
    • Côte d'Ivoire
    I am looking for high resolution picture of hp dv4 wsnu main board rev 2.1
    some components are missing on that board . If someone can help with pictures (dual side) , will really appreciate
  • chad720
    • Jan 2011
    • 16
    Re: Hp dv4 wsnu main board
    Hi, could you post the full model of that laptop? dv4-1225dx for example. And also, it would be usefull to have the model of that board you´r refering to.
    Thanks and good luck
    • Dani_2024
      by Dani_2024
      10-28-2024, 05:06 PM
    • ygorsan
      LG 55NANO77SRA TV – Menu scrolling by itself even after removing button board (Main Board EBU66792103)
      by ygorsan
      Hi everyone,
      I’m looking for help with a persistent issue on an LG TV model 55NANO77SRA, which uses the main board EBU66792103 (also used in LG UQ80 and NANO75/NANO80 series).
      🧩 Problem Summary:
      • The TV keeps scrolling through the menu or selecting items by itself.
      • I removed the physical button board (the entire panel with power and volume buttons) and also disconnected the flat cable (CN202) from the main board.
      • The remote control is not in use (batteries removed), and the TV still shows the same behavior.
      • I
      07-28-2025, 08:34 AM
    • JDC
      (SOLVED) - ONN 100012588 No Power, Then Rebooting After Main Board Change
      by JDC
      ONN 100012588
      Issue: No Power, Then Rebooting After Main Board Change
      Short answer: replace main board and power board
      Technical answer: replace main board and Q306 & Q307 on power board.
      Long answer:
      TV wouldn't turn on. Power switch was fine which means the main board isn't processing the power on signal. Replaced main board. TV turns on now but randomly reboots. Bad main board? EEPROM? Tried to pull main board and got a shock touching the corner of the board. That's weird. C334 (450V 10uf) capacitor is still holding a high charge....
      07-15-2022, 07:39 AM
    • m1ch43lzm
      by m1ch43lzm
      05-12-2025, 08:37 PM
    • cheeky2
      by cheeky2
      05-25-2024, 03:27 AM
