Samsung UN46EH6000 LED ERROR Codes
  • Michale32086
    • Nov 2011
    • 1453
    I have a nice UN46EH6000 that I have tried 3 different power boards on. All three produce the same response.
    When plugged in, I hear the SAMSUNG tones, but absolutely no light on the screen at all..
    On the power button (a PS3 style thumb button) a red LED blinks 6 times..
    I was going to tear down the unit to the bare bulbs and see if the problem lies there but before I do, I wanted to see if those Error Code Blinks mean anything else.. GOOGLE was no help..
    Also, on the cable between the power board and the video board, there is a trace that had been factory cut...
    Any hints would be appreciated...
    Re: Samsung UN46EH6000 LED ERROR Codes
    They mean nothing. It is not an error code.
    Most likely open circuit LED strip, or short circuit LED to chassis.
    That will cause a Samsung to cycle the power or fail to boot.
    I don't think that's a factory cut.......
    • Michale32086
      • Nov 2011
      • 1453
      Yea, that turned out to be the problem with a previously mentioned Westinghouse I worked on..
      OK, disassembly it is...
      Well, it WAS until I spliced it to see if that was my problem..
      Yea, probably not the smartest move, I realize...
      Thanx for the response...
      • Michale32086
        • Nov 2011
        • 1453
        OK, got the unit disassembled down to the bare LEDs
        Interesting arrangement.. Looks like a padded room I have been in once or twice.
        I re-seated the connector to the LEDs and want to hook up the power board to see if I get light..
        Is it wise to hook up just the power board without the video or TCON boards??
          Yes, you can power up the TV without the T-CON and the LCD panel attached.
          • Michale32086
            • Nov 2011
            • 1453
            Thanx, budm...
            Yea, I had to hook up the video board anyways to have the ON/OFF switch in play, so I went ahead..
            Found something interesting. Hopefully the smoking gun...
            Using a voltmeter I determined that there were no direct shorts and the connections were laid out as indicated in the attached Pic..
            "Now, I don't know what all that means, but it sounds pretty bad."
            -Tom Cruise, A FEW GOOD MEN
            • Michale32086
              • Nov 2011
              • 1453
              Attached is the other side of the connector shown in the post above...
              • Michale32086
                • Nov 2011
                • 1453
                As the saying goes, "Curiouser and Curiouser..."
                I took out all of the light strips shown in post #4... Powered up and still got the same result. 6 blinks on the power LED...
                So, I tried something I probably should have done BEFORE I disassembled this unit down to bare tacks...
                I pulled the connector (Post #7) that goes from the power board to the LED strips shown in post #6...
                Plugged in and still the same 6 LED blinks..
                Which leads me to believe that the short is NOT in the LED strips....
                The only other possible culprit is the video board...
                But that doesn't make much sense...
                Does it??
                  What DC Voltages do you get on the connector CNM803 pins when TV is OFF and when power switch is activated? There are label for each pin.
                  http://assets.shopjimmy.com/media/ca...498a-top_1.jpg
                  Also if you disconnect the CNM803 and then plug the TV into the outlet, do you get backlights?
                    6 blinks means nothing.
                    It is the normal Samsung power up routine. Every Samsung TV does the same. Anywhere from 4 to 10 blinks seems normal.
                    • Michale32086
                      • Nov 2011
                      • 1453
                      1- 12.8v
                      2- 3.1v
                      3- 12.8v
                      4- 12.8v
                      5- 12.8v
                      6- 2.9v
                      7- 12.8v
                      8- 0
                      9- 0
                      10- 0
                      11- 5.3v
                      12- 5.2v
                      13- 5.3v
                      14- 3.2v
                      Plugged in, power switch activated makes no difference... From the tones I am assuming that the TV is activated once it's plugged in..
                      Nope... Dead as a doornail...
                      • Michale32086
                        • Nov 2011
                        • 1453
                        Ahhhhh Hokay, I get it now..
                        Blinks can be ignored...
                          Originally posted by Michale32086
                          1- 12.8v
                          2- 3.1v
                          3- 12.8v
                          4- 12.8v
                          5- 12.8v
                          6- 2.9v
                          7- 12.8v
                          8- 0
                          9- 0
                          10- 0
                          11- 5.3v
                          12- 5.2v
                          13- 5.3v
                          14- 3.2v
                          Can you please put the pin labels next to the readings?
                            OK, I look at the picture myself:
                            Pin 6 = BL ON/OFF = 2.9V = OK, it should be <1V when TV is turned OFF.
                            Pin 14 = PWR ON/OFF = 3.2V = OK, it should be <1V when TV is turned OFF.
                            So the main board is sending out correct signal to turn on the power supply and the backlights circuits.
                            The problem is on the power supply board some where, the backlights should at least flash on for a second for the error detection circuit to detect any fault before going into shutdown.
                            What DC Voltage do you get at THE TWO LEGS of the main filter cap (82uf 450Vdc) when power switch is activated?
                            Pictures are provided by SHOPJIMMY.
                            • Michale32086
                              • Nov 2011
                              • 1453
                              My Bust....
                              1 B13v 12.8v
                              2 PWM_DIM 3.1v
                              3 B13V 12.8v
                              4 B13V 12.8v
                              5 Vamp 12.8v
                              6 BLU On/Off 2.9v
                              7 Vamp 12.8v
                              8 GND 0
                              9 GND 0
                              10 GND 0
                              11 B5V 5.3v
                              12 A5V 5.2v
                              13 B5V 5.3v
                              14 Pwr On/Off 3.2v
                              • Michale32086
                                • Nov 2011
                                • 1453
                                I am not sure but it might be indicative of the problem.
                                I can't seem to turn the set off...
                                When I plug it in, I hear the Samsung Tones that indicates power up..
                                Looking at the INPUTS area, the red light is on in the OPTICAL AUDIO connector which I have always associated with the TV being ON...
                                Pushing the power button does nothing to change anything..
                                Totally disconnecting the Video Board (and, hence, the power button) produces the voltages I outlined above...
                                • Michale32086
                                  • Nov 2011
                                  • 1453
                                  Also, this is the 3rd Power Board I have put in the unit...
                                  The one that was initially in there..
                                  One I had flying around my shop of unknown operability..
                                  And the third one that's in there now that I had purchased from Shop Jimmy...
                                  All gave me the same results...
                                    Because it is most likely an open circuit LED in the panel. This is by far the most common fault with LED TVs and is making many of them really difficult to fix.
                                    I don't really know how you'd go about fixing an O/C LED in something like an 70" panel... 46" sounds bad enough.
                                    • Michale32086
                                      • Nov 2011
                                      • 1453
                                      I thought about that.. That maybe one of the strips was bad.. So I took one out and tested..
                                      No luck..
                                      Took another out and tested again..
                                      No luck...
                                      And so on and so on until there was only one left...
                                      I then put them back in, in reverse order and tested again after each install..
                                      No go..
                                      What about the idea of buying a new strip that's (assumed) good?? And use it to test each strip connection??
                                      • Michale32086
                                        • Nov 2011
                                        • 1453
                                        Does the voltages in post #6 provide any clue??
                                        EDIT: Actually, #6 just provides a continuity diagram..
                                        Would checking voltages help???
                                        • peterwang
                                          Samsung NP750QGK-KG3US BIOS program error seeking help
                                          by peterwang
                                          PCB:BA41-03025A BA92-25486B
                                          I opened the Modular Flash Image Tool-v16.50.00.1120 software and encountered the following error message. I am seeking help.
                                          08-14-2025, 08:15 PM
                                        • AK_777
                                          Sony KD-65A1 Repair – 4 Red Blinks Error
                                          by AK_777
                                          Hi everyone!
                                          I have a Sony KD-65A1 TV with a fault – 4 red LED blinks. After disassembly and visual inspection, I found that the G76 power board and DKA board had been replaced. It is also possible that TCON was replaced, but I am not sure – there are a few marker marks that could be factory-made.
                                          Based on assumptions, the previous service attempted to solve the issue by replacing potentially faulty components. I decided to investigate further, found a service manual, and figured out a way to power up the power supply unit autonomously and put the OLED panel and...
                                          02-20-2025, 04:15 PM
                                        • Sus256
                                          HISENSE 65E7KQ PRO - no boot
                                          by Sus256
                                          Hi all!
                                          HISENSE 65E7KQ PRO
                                          RSAG7.820.13512 - chassis
                                          MT9618BAATAB - cpu
                                          RSAG7.820.12059 - power
                                          HD650Y3U77 - panel
                                          KLM8G1GETF - emmc
                                          The TV does not turn on, the standby indicator is on. All voltages are present.
                                          Emms is dead. Not readable, not detected.
                                          Replaced emmc.
                                          But with another dump there is no launch
                                          Terminal log
                                          UART
                                          AC_ON
                                          RPMB key is not yet programmed
                                          HASH1_VERSION=0x00000000 64bit
                                          E-B
                                          FDE enabled
                                          layout pattern onebin by SAR7,0...
                                          06-01-2025, 02:11 AM
                                        • brithepi2k
                                          Samsung UE75TU7020k No picture, Standby blinks 2 times
                                          by brithepi2k
                                          My Samsung UE75TU7020k lights up fine when one of the ribbon cables are disconnected from the main board, lights stay on but not getting half a picture, I do the same with the other ribbon and put the other one in and lights stay on but not getting half a picture. The standby light flashes 2 times then reboots then it then tries to come back on again and just keeps looping until I take either one of the ribbon tables out (doesn’t matter which one I take out it stays lit when either one is out). I’ve tested the backlights but all working with none shorting out, I’ve replaced the main board...
                                          04-23-2025, 10:05 AM
                                        • Caimano
                                          hp Pavilion 14 CE-1XXX 5 fast 3 slow blinks or cmos checksum error if restarted immediately after shutdown or suspend
                                          by Caimano
                                          MB G7AD-2G DAG7ADMB8D0 REV D
                                          Processor i5 8265U
                                          AFAIK schematics or boardview are not available for this MB, but I used a similar board as a reference (G7AL-2G)
                                          Laptop came in not booting with caps lock blinking 3 fast- 2 slow indicating RAM error. Charging works fine. Found bad soldering on the only ram socket present (2 outer left pins and 2 outer right pins).
                                          Once soldered the laptop started fine and I was able to install Windows 11, upgrade BIOS to version F30 from Windows without a problem, BUT I found a strange and annoying...
                                          02-06-2024, 10:14 AM
