I was looking at all these small approx 4x6 open frame PSUs that typically are around 40W. Then I came across this "monster" 110W (130W max) unit! It was rated 15A at 5V, 5A at 12V, and a half amp on the -12V rail. Looking at its specs it should be 80% efficient unlike the other 4x6 where average in the 70% range.
However, it failed. Not surprisingly I suppose, though, it's too dense. Anyway it won't start properly. It comes up for a fraction of a second but goes dead to 0. It tries starting again two seconds later, and goes out. So, it's the dreaded blip blip blip type failure.
It has pretty much all Chemicon LXP capacitors on it except the bulk supply capacitor, which is a Chemicon KMG capacitor. What's surprising is that it's a 420V 47uF capacitor...
47uF?!?!?
Seems a bit low, as most of the other smaller openframe caps I've seen 100uF or more, and compared to the switched range PSUs that have two caps, it's 1/((1/470)+(1/470)) = around 235uF for a 200W PSU...
It uses a dreaded 8-pin SK-8120 PWM controller which I can't find much info about unlike the ubiquitous UC3842-series.
Anyone worked on these before?
47uF?!?!?
