Debugging Vertical Lines/Freezing on Samsung LN-S3241DX
  • hotsho111
    • Jan 2021
    • 7
    Hey! I have an LN-S3241DX that I think has a bad t-con board but I wanted to check here to see if anyone had any ideas on anything else I could do to conrifm the issue
    Occasionally, colored vertical lines would appear across the screen and the screen would freeze while slowly turning black. Usually, if I just power cycled the TV this would go away.
    Slowly it's started happening more and more and starting a few days ago it would happen shortly after turning the set on. Power cycling would still work, but it would only last a short amount of time (less than 1 minute). Sometimes the screen would exhibit the symptoms and would pop back to normal before doing it again after a little while.
    I took apart the panel to see if I see anything obvious and at first, flexing the tcon board and reseating the ribbon cables seemed to help but that might have just been a coincidence. From there the symptoms got a bit worse and now it just powers on with no picture (the backlight does come on). I did run it for a bit with the panel off the main board so I could check values and that had a heatsink touching the video processing (STP03) chip which did get a bit hot to the touch.
    Here is an example of a picture I managed to get 1 time it happened (this was September of last year so it's been mostly fine for the last 4 months)
    The output voltages of the power board match the values written on the board so I don't think it's that (although there are a few caps that look a little suspect)
    Checking the connector off of the main board to the t-con the powered pins are reading 5.4v or 1.2v, The tv turns on via the remote and panel buttons and functions work (changing input, volume, setting the sleep timer - you can't see them, but I've had it long enough I can set this without needing to see the screen)
    Power levels on the t-con board seems suspiciously low. The test points near the main board connector (RX1. RX2. RX3) read 1.2v, the voltage regulator (U14) reads 2.5mV, the fuse (F1) reads between 20 and 100mv, and the value for all of the GAMMA test points fluctuate pretty wildly.
    Does that seem like a t-con issue or something else? Anything else to check?
    Thanks!
  • zen
    • 511
    Re: Debugging Vertical Lines/Freezing on Samsung LN-S3241DX
    Hi
    With this sort of symptom , i would be looking at either T-CON , or display itself .
    Very unlikely to be caused by main board .
    Regards Zen
    • nomoresonys
      • 12305
      • U.S.
      I'd throw a replacement tcon at it, see what happens, they should be pretty reasonable for a 32 inch tv.
      • hotsho111
        • Jan 2021
        • 7
        Cool! I thought that might be the case so I'll try that and let you know how it goes. Thanks!
        • hotsho111
          • Jan 2021
          • 7
          Quick update, I purchased a t-con board but the order got cancelled because it was out of stock.
          I'd disconnected the tcon board before and noticed the LVDS cable wasn't fully seated. I reconnected that and now I'm back to having a picture that occasionally glitches out.
          I did take readings of a whole bunch of components on the tcon board when the picture looked normal and they all read what more like I'd expect. The picture did get distorted a couple times while I was measuring values and when that happened they would wildly change (I didn't notice if the levels went up or down but I think they went down)
          Would that still indicate tcon board issues or possibly a power board issue?
          • hotsho111
            • Jan 2021
            • 7
            Quick follow up question. It seems like the issue is related to one of the voltage regulators (MMC6100B) so I'm going to replace that, but they are all reading slightly off so I was thinking of picking up two others.
            The others are labeled L1117DG and L1117LG-33. Does anyone know suitable replacements for these (the latter has been a little easier to search for)? L1117DG is reading 3.5V on the output so I'm not sure if that should be a 3.3V or 5V one
            • dick_barton
              • Aug 2015
              • 6643
              • Wales
              The L1117LG-33 is a 3.3V fixed regulator.
              L1117DG is an adjustable regulator
              https://www.datasheetq.com/datasheet...ko-Sem/L1117DG
              Page 5 shows the arrangement for the adjustable regulator chosing R1 and R2
              • hotsho111
                • Jan 2021
                • 7
                Thanks Dick, I ended up just ordering the 1 voltage regulator and a bunch of caps for the power supply which should be in this weekend.
                • hotsho111
                  • Jan 2021
                  • 7
                  Hey, just following up, swapped out U14 LD1117S25TR‎ and the tv is working now.
                  I'm still gonna swap out the caps but just wanted to follow up on the fix.
                  Thanks everyone!
                  • Stanley1843
                    Screen Display Vertical Multicolor Lines
                    by Stanley1843
                    Hello, I have a screen in where sometimes when I open it pop-up vertical multicolor lines (I would say the most of them are green). If I tun off and turn on the screen the lines dissapear or if I leave open the screen after approximately five minutes the lines gone. I measured the below voltages on the main PCB and on the T-CON board and the voltages are the same when it doesn’t display the vertical lines and when it displays the vertical lines. Also, I cleaned all the connectors very good with IPA. I moved back and forth the connectors and the COF tabs but the vertical lines didn't displayed...
                    06-29-2024, 11:54 AM
                  • Falki
                    Colorful LCD Vertical Lines on Samsung ue55es8090
                    by Falki
                    Hello there, ive recently found an older 55inch Samsung SmartTV.
                    Sadly it has vertical lines at the left and one line in the middle-right.
                    I have already tested out the connections and have looked at the soldered ribbons of the LCD panel to see if some contacts got loose by pushing them a bit but with no success.
                    I have factory resetted the TV as well but also with no luck.
                    I am afraid that it is indeed a LCD Panel issue but there are NO scratches or any impact-marks..
                    A similar issue has been posted as well but also with no actual response ...
                    08-12-2025, 04:19 AM
                  • visionbluedemon
                    Help. Sony kd-65x85dj vertical lines
                    by visionbluedemon
                    First. it has no picture at all. i solved it by covering the ckv lines using tape to to block the connections
                    Second. now has picture but with vertical lines that follow the image. tcon board ic overheating
                    tried blocking LC lines too, but same results
                    is it lcd panel issue or tcon board issue?...
                    07-25-2025, 04:56 AM
                  • gpo23
                    Sony KDL-40V3000 - Vertical lines
                    by gpo23
                    i order a t-con because i had bad colors on my SONY KDL-40V3000 :
                    With the new t-con the color are good but there are vertical lines on all the screen :
                    I've tried the old t-con and it returned to the initial issue (bad colors but no vertical lines)
                    Is there a way to fix the vertical lines on the new t-con ?
                    Thank you for your help
                    gpo23...
                    10-04-2023, 09:11 AM
                  • Firentiosi
                    1/3rd of screen black with occasional vertical lines - repair attempt for learning! - Kogan KALED58RT9220SVA
                    by Firentiosi
                    Thanks for offering your assistance with this. I'm an electronics enthusiast with moderate level of competence (have a decent lab with two power supplies, microscope, DSO, hot air, good iron, can competently work at a component level on SMDs, design and solder own PCBs etc). I really enjoying fixing things and learning new stuff so took up a free 58" LED TV and have been googling and watching Youtube videos to see if I can fix this! I am happy to go down to individual component replacement/strip replacement etc - it's all in the name of learning.
                    The issues are as follows: the...
                    11-27-2024, 12:33 AM
