Yamaha DRX-730 won't start
  • frankie31
    • Dec 2013
    • 27
    • FRANCE
    Hello everybody,
    I'm back with a new problem... on my audio-video system Yamaha DRX-730 that doesn't want to power on.
    http://elektrotanya.com/yamaha_drx-7.../download.html
    As I push the power button, the main relay that cliks (sticks) and 2 seconds later unsticks...
    The relay is powered independently of the main system by a little transformer (T502) and its voltages are ok so I don't think there is a problem here with the relay command stage.
    On the other side, the Q501 (main mosfet that powers the main transformer T501 that powers the system) doesn't chop the voltage (but the 350V on its drain is ok).
    I suspect the mosfet driver (IC502, L6566BTR). But even its Vcc voltage isn't good (very fluctuant from 9V to 12V measured with my DC voltmeter).
    About it : I don't understand on the schematic how it is powered ? It is at the secondary from T501 but if Q501 doesn't work... no secondary voltages isn't it ?
    So... now I'm stuck... any idea ?
    Thank you very much, regards, François.
    Re: Yamaha DRX-730 won't start
    https://cdn.badcaps-static.com/pdfs/...613cc2ca91.pdf
    "But even its Vcc voltage isn't good (very fluctuant from 9V to 12V measured with my DC voltmeter)."
    Vcc turn on threshold is 14V, right now it stuck in the loop, it can be bad startup cap on the VCC pin or the load is too much so it goes into start-up-shut down loop.
    Read the spec sheet and learn how the IC function.
    • frankie31
      • Dec 2013
      • 27
      • FRANCE
      Thank you budm for helping me
      I think you are right I need to go further in the understanding of this IC.
      So let's measure the voltages on the L6566 chip :
      Pin 1 : The voltage for HVS (the pin whose aim is to charge an external cap to create VCC) is about 350V : it's ok.
      Pin 5 : Vcc changes between 5V and 12V as previously said ; the electrolytic cap C512 is ok (tested with my ESR-meter)
      Pin 4 : At the gate driver output (GD) which pilots the main power transistor Q501 (probe plugged on D502 cathode) I see nothing with my scope when I push the power button (flat curve the same as unplugged probe)
      All the other pins : the voltages = 0V !
      My IC has got no Vref.
      Could it be the IC ? Or do you think the problem is elsewhere ?
      Thank you very much, François.
      • frankie31
        • Dec 2013
        • 27
        • FRANCE
        I would like to add more informations : the measurements are made with only the 4 pin connector (W503) connected between the main board and the sub board (the power supply board) just so I can push on the power button to make the relay stick.
        Additional measures : on this 4 pin connector W503
        No power/Push on :
        CGND (ground) : 0V/0V
        PWR_RY (relay control) : 0V/4.8V
        +5SUB : 13.55V/11.46V
        +12_RES : 15.10V/12.67V
        Thank you
          What do you use for ground ref point for the meter?
            Lets take the resistance reading of L6566 IC between pin 3 (Ground) against all other pins.
            There may be problem with the internal current source that charges the cap on the VCC pin.
              BTW, I look at the diagram and see that there is Zener diode D504 connected to the VCC pin, if there is leakage on the that Zener diode or the Cap has leakage resistance on that VCC pin, then the voltage on the VCC may not be able to get to 14V for the IC to start up.
              You also need to verify the voltage readings on the IC pins again using the ground pin as the ref gnd. I expect the AC OK pin 16 will have 3V per diagram and 1V on Vref unless those two 470K resistors are bad.
              • frankie31
                • Dec 2013
                • 27
                • FRANCE
                For the ground ref point I use an alligator clip put on Q501 heatsink
                • frankie31
                  • Dec 2013
                  • 27
                  • FRANCE
                  I confirm the voltage readings for all my pins.
                  I add some measurements : for AC_OK I agree something is going wrong -> I have my voltage after R558 (320V) but nothing after R559... hum hum...
                  So the resistance for R558 is ok (469K) but... not for R559 : it seems to be bad !
                  Nothing is parallel-connected so this resistor is dead...
                  I have to find another one to test.
                  Do you recommand me to change for a bigger one (higher wattage) ?
                  Thank you, again, François.
                    It has less than 0.1W dissipation on those two 470K, 1/4W will be than enough. They had to use two resistors due to each resistor has breakdown voltage of 250V, for it to handle 400V they put two in series.
                    Worst case at 400V/(470K * 2) = 0.42mA of current flowing through those two resistors if pin 16 shorted out.
                    • frankie31
                      • Dec 2013
                      • 27
                      • FRANCE
                      Yes !
                      It works !
                      It was definitely the 470K resistor
                      One thing that I don't understand :
                      The voltage divider made of R556,557,558,559 gives me for the pin 16 :
                      V_pin_16=V_capacitor*(R556+R557)/[(R556+R557)+R558+R559]
                      V_pin_16=332*(4.7+15)/[(4.7+15)+470+470]=6.81V
                      And I finally found 3.1V after changing the R558 and R559... what's the difference between the theory and the pratice ?
                        Glad to hear that it works.
                        • Chungalin
                          • Jul 2014
                          • 423
                          • Spain
                          Suprising coincidence!
                          Today I've received a DRX-730 with exactly the same symptom. After pressing power button, main relay switches on and two seconds later switches off. Nothing on display.
                          I've checked R558 and R559 without hesitation and in this case it's been R558 (open). Replaced by same value (bigger one, I don't have that small) and voila!
                          This coincidence reveals that this could be a common fault in this model.
                          Thanks a lot budm and frankie. You have saved me a lot of time.
                          • frankie31
                            • Dec 2013
                            • 27
                            • FRANCE
                            Hi !
                            Good work Chungalin !
                            • PAULO SOZA
                              • Mar 2016
                              • 11
                              • Chile
                              Hi! I have the same problem, but I'm not an expert, so, can you upload some photos?? Thanks!
                                Did you download the service manual?
                                • PAULO SOZA
                                  • Mar 2016
                                  • 11
                                  • Chile
                                  hello budm, thanks for responding so quickly!
                                  I have attached photos of the measurements that I made, I hope you can guide me ..
                                  Thanks again
                                    I would take both of them off the board and test them or at least unsolder one leg off the board and test them. R558 looks bad.
                                    If I were you I would replace them since they are known to go bad.
                                    • PAULO SOZA
                                      • Mar 2016
                                      • 11
                                      • Chile
                                      Hi again, I removed the resistors.
                                      I have attached photos of the measurements.
                                      It seems a success!
                                      I will answer when finished
                                      Thanks a lot!
                                        Same proble, R558 is bad, so you are lucky that it is the same common failure as other posters have found.
                                        Put in two new resistors and then you will be on your way.
                                        • CoinCoin88
                                          Garage door RX unit (Cardin S38C) does not short relay to send opening signal
                                          by CoinCoin88
                                          I'm turning to the Badcaps community to help me troubleshoot the radio Rx card from my (old) garage door opener. While I could just ditch that card and replace the whole system, I first would like to understand "why" it suddenly stopped working, because that's just how I am wired...!
                                          Some basics: the receiver works on a 30.875 Mhz frequency. Yes, I'm aware this is not in use anymore in a looot of places. It does not use any rolling code, it's just a regular dip-switch code that you have to set up on both the receiver and transmitter. The receiver...
                                          09-15-2025, 03:36 AM
                                        • jm1234
                                          9V relay temperature 40C
                                          by jm1234
                                          Hi, I'm seeing one 9V relay having temperature 40C on its 9V (primary) side. Does that seem right? I switched 2 relays on that board and the temperature was the same (on the same position), so I'm sure it's not a faulty relay. I measured voltage on that relay and it was 9.5V DC, so that looks good. I don't see any other relay on that board having that kind of temperature and they have 9V on them too.
                                          I thought maybe the transistor that is switching this relay keeps switching on/off, so I also checked for AC and there was almost none: 0.3V using mV range. No steady frequency was shown, but...
                                          05-09-2024, 03:03 AM
                                        • edugimeno
                                          Biomass Boiler not driving cleaner motor relay. ENERTRES BIOMASA BI-650
                                          by edugimeno
                                          Hi everyone!
                                          I have this board that suddenly stopped supplying power to an output that drives an interchanger cleaner motor.
                                          I checked while the board was in place with all wires attached and there's no AC voltage on the corresponding plug X5
                                          This X5 is driven by fuse F8 (tested OK) which comes from the second orange relay
                                          To make sure there are no charcoaled contacts inside the relay, I got a 24VDC power supply and got it ready to manually power up the coil side of these relays.
                                          I respected the polarity, positive to cathode of protecting diode
                                          So provided all...
                                          04-18-2024, 01:15 PM
                                          Mitsubishi CNC switching power supply board dead / relay board bad diode failure
                                          by sam_sam_sam
                                          I was working on this CNC machine today found no keyboard functioning no control relay powering on
                                          The screen powered on and was giving an operation error but the manual was not very clear about what the error exactly was but with a little bit of troubleshooting and finding out that the control relays not powering on and no keyboard functions we narrowed down to this one switching power supply which of course does not have any indicator LED light they are on the keyboard interface/relay controller board
                                          Found shorted diodes on main controller relays there are 3 of them that...
                                          01-07-2023, 05:43 PM
                                        • sanalelevenstar
                                          Yamaha RX-V485 Wn9711 Update
                                          by sanalelevenstar
                                          Help Needed: Yamaha RX-V485 Network Issue After Firmware Update (WN9711 Error)
                                          Hi everyone,
                                          I'm facing an issue with my Yamaha RX-V485 receiver. During a firmware update, the process failed, and now the USB, Bluetooth, and network functionalities are not working. Occasionally, the receiver displays the error code WN9711.
                                          I came across Yamaha Technical Bulletin No. 0103, which describes a similar issue for models like the RX-V4A, RX-V6A, and RX-A2A. According to the bulletin, the issue can be resolved by shorting soldering points (e.g., J260 for RX-V4A or...
                                          12-04-2024, 04:32 AM
