Sceptre x322bv-hd powers up w/sound-but no picture
  • cbr6861
    • Jun 2014
    • 32
    Hi everyone- new member to Badcaps and posting, but a long-time viewer/observer/admirer of this site. Trying to trouble shoot the picture problem with this Sceptre 32'' LCD TV. When plugged in-- the "red" standby light illuminates. Using the remote to turn on.... the unit powers up and "blue" light illuminates, sound comes on and can hear the station but no picture appears. By no picture, i mean Black, not blue, no logo, nada. I have included a pic to show the layout of the circuit boards inside and what i'm thinking they are. Firstly, I have limited knowledge/experience with advanced electronics diagnosis and some of the lingo, but do have a basic grasp and skills to do most along with determination a soldering iron my older analog multimeter . I went ahead and replaced 8 of the CapXon caps right off the bat on what i'm understanding is the power supply/inverter board based on read threads here. I did notice there were 3 more CapXon caps on the other board....(the main/logic board?) which i will also replace just to eliminate them as suspects.
    A close visual inspection shows no obvious problems. No hums or sizzles. This is a new and more technical troubleshooting area for me and am not really sure where to start the diagnosis process other than replacing the caps. Any help and/or guidance is much appreciated.
  • Dgtech
    E. Technician
    • Apr 2009
    • 1462
    • Steeler
    Re: Sceptre x322bv-hd powers up w/sound-but no picture
    Check ec14 and ec10 on the power board. These are the caps laying down. Also check all diodes on the secondary side.
    • cbr6861
      • Jun 2014
      • 32
      Thanks dgtech for your reply. I did a visual check on ec10 & ec14...they appear to be ok. No bulging or swelling noticed.Not sure if they can be checked with my analog multimeter in the circuit?
      Not sure what you mean by secondary side? Not to familiar w/ the language.
      Are you referring to the back side of the power board? BTW is this a combo power /inverter board?? Are the diodes you're talking about the ones I highlighted?
      D8, D12, D13. Also, forgot to mention in my 1st post, Tested the dcv output of the connectors. got 5v on the standby pins- nothing on the rest.(see pics).
      • Dgtech
        E. Technician
        • Apr 2009
        • 1462
        • Steeler
        Secondary side was the output side. Can you see a picture with a flashlight?
        We're the voltages taken when the sound was heard.
        • cbr6861
          • Jun 2014
          • 32
          let me reinstall power board & check it out.
            Check and see if the PFC voltage booster circuit is working or not since the inverter circuit (the big transformer with yellow tape, the two 3-pin power MOSFETs and the two red/brown caps) requires that voltage to work, you need to check the voltage RIGHT AT THE TWO legs of that main filter cap (the big black cap laying on its side).
            Are there any labels next to those white connectors, we need to verify if we do have BL_ON (INV_ON) or not.
            • cbr6861
              • Jun 2014
              • 32
              ok...dgtech...that would be a no with seeing a pic w/ the flashlight.
              also... the voltages were read when i had it on the bench & powered up only with NO tv cable or other input devices hooked up. So no to that too.
              A hello to Budm, thanks for jumping in. FYI, i did read through your Basic LCD monitors troubleshooting guide & LCD Flat panel TV troubleshooting guide. Nicely written i might add. Let me investigate your inquiry and get back with you both on that.
              Thank you.
              • cbr6861
                • Jun 2014
                • 32
                budm, The white connectors have no labeling on the board for them, however, the lower one heads down to the lower left side and the upper one heads to the lower right side of the tv panel.
                I checked the voltage @ the main filter cap(with the power on) but am unclear (through my inexperience) on what scale to read on the darn multimeter to get the correct reading ....so i took a pic of it.
                • cbr6861
                  • Jun 2014
                  • 32
                  looks like its reading approx. 375 volts
                  • cbr6861
                    • Jun 2014
                    • 32
                    i rechecked the voltage at the main cap and get 160 in standby & 380 with power.
                    From what i've read the seems about right. What would be a logical next place to check?
                    • cbr6861
                      • Jun 2014
                      • 32
                      Voltage readings from PS output connectors:
                      • cbr6861
                        • Jun 2014
                        • 32
                        *bump*
                        Can anybody help me out?
                          You have the right the right signals feeding the board, at this point the problem is in the backlight inverter section. Will need to look further in that section.
                          • Dgtech
                            E. Technician
                            • Apr 2009
                            • 1462
                            • Steeler
                            I don't think that there will be any voltages here without the proper load on the circuit. It is that circuit That has the problem.
                            This could be a solder joint issue. I would reflow the joints on the transformer. I have seen those little blue caps fail before too. How about a pic of the back of the power board.
                            • cbr6861
                              • Jun 2014
                              • 32
                              so the voltages look as they should on those 2 white connectors at the top?
                              the ones you asked about before that aren't labeled.
                              • cbr6861
                                • Jun 2014
                                • 32
                                will post it
                                  Those two connectors will have about the 2000V output for the lamps, do not try to measure them unless you want to destroy your meter. As I indicate, you have the correct voltages feeding and outputting to and from the power supply, but you do not have the high voltage to drive the lamps, which is done by the inverter circuits.
                                  • Dgtech
                                    E. Technician
                                    • Apr 2009
                                    • 1462
                                    • Steeler
                                    Those are high voltage connectors for the back lights. Sometimes the circuit senses whether or not the proper load is present or not. The board sometimes will not provide these voltages until the needed conditions are met.
                                      The inverter circuit will fire up first (load or no load), if it does not detect the lamp that fire up and stay conducts (or open lamp) in the in the first 3 seconds, it will go into shut down, it will fire up first and shutdown later. Right now he needs to look and see if the lamps even fired up at all.
                                        You can find out if the high voltage is even generated at all for seconds by using Neon lamp or using this:
                                        https://www.badcaps.net/forum/showth...x+dx-40l261a12
                                        • csmith
                                          Vizio D50u-D1 Powers up no picture
                                          by csmith
                                          I replaced the backlights all good. Two months later set was dead, had a shorted D9100, replaced all good again.
                                          Now months later set powers up,backlights light ok,no picture. 12volts missing from fuse on tcon. 12VA on power
                                          supply is 19 volts. Changed D9100 again, same, 12 volts measures 19. Am I looking at a power supply or mainboard
                                          issue. Set will power up with remote but not power off....
                                          07-11-2025, 11:52 AM
                                        • sergio_av
                                          Acer Aspire E5-571G-52NH powers on, no picture. PCH_ENVDD goes off and on.
                                          by sergio_av
                                          Hi, I'm unexperienced with troubleshooting and I'm not sure how to proceed with this laptop.
                                          Motherboard is A5WAH LA-B991P I think, i5-5200U and nvidia 820m.
                                          When I received the laptop, CMOS battery had 0V. I took it out and all the testing has been done without a CMOS battery and without the main battery plugged in, I haven't been able to see physical damage, burnt or missing components with a quick visual inspection, and no shorts were found.
                                          Laptop charges the battery, powers on when ON button is pressed when powered from charger and when powered from the battery, but...
                                          01-01-2025, 05:27 PM
                                        • KYBOSH
                                          Trying to Save - LG 60PH6700 60-inch plasma HDTV - Powers ON but no picture
                                          by KYBOSH
                                          Saved this beast from the landfill this weekend.
                                          Manfactured July 2013 in Mexico.
                                          I love working on plasma TVs.
                                          Its been a while but I was lucky enough to find 2 this week.
                                          The TV powers on and stays on but no picture. Havent checked for sound yet.
                                          No bulging caps although the insides are pretty dusty and the boards are discolored from many years of high heat.
                                          Will start troubleshooting tonight.
                                          10-17-2024, 01:17 PM
                                        • Tr0ll
                                          by Tr0ll
                                          Original T-con:
                                          First replacement T-con:
                                          10-07-2023, 07:48 PM
                                        • JJAAMM
                                          by JJAAMM
                                          Problem
                                          07-06-2023, 06:01 AM
